Brighter dash lights - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 30th-April-2006, 02:44 AM   #1
loneagle
(OP)
loneagle's Avatar
Any ideas on how to make my dash lights brighter? Maybe some different bulbs or LEDs or some extra lighting wired in?
'70 Nova 355 cid
Super T-10 4 speed
Old 30th-April-2006, 02:34 PM   #2
Chori
Chori's Avatar
Nova(s): 67 100 Series Sedan
Hey, that's really insightfull! the other way around LEDs.
Minds are like parachutes They only function when open- Lord Thomas Robert
Old 30th-April-2006, 02:51 PM   #3
loneagle
(OP)
loneagle's Avatar
Thanks for the info. I'll mess around with it some more today!
'70 Nova 355 cid
Super T-10 4 speed
Old 30th-April-2006, 03:35 PM   #4
Custom Jim
Custom Jim's Avatar
Title: Moderator
Nova(s): 1968,1973,1974,1977(Sold)
Garage
I would also make sure you are getting full voltage to the lights. You may have some poor connections or voltage drop at or before the headlight switch.
Old 30th-April-2006, 08:48 PM   #5
RED67
Grounds ??
Make sure the instrument cluster is grounded properly
"The Winning Story is Always the Shortest"
Old 4th-May-2006, 03:50 PM   #6
loneagle
(OP)
loneagle's Avatar
I added an extra ground wire to the back of the cluster and the lights are nice and bright now. I would like to try some red LEDs. Here are the ones I'm thinking about:
http://cgi.ebay.com/ebaymotors/10-HI...spagenameZWDVW
'70 Nova 355 cid
Super T-10 4 speed
Old 8th-May-2006, 04:08 PM   #7
YFH8SIT
YFH8SIT's Avatar
This may seem odd, but I put head light relays in a few months ago and the biggest difference I saw wasn't in brighter headlights but the dash lights. The head lights were a tad brighter but the dash lights were way brighter. Maybe becuase the headlights were draining all the juice from the dash and they now have a power source directly off the battery.
She just doesn't get the Chevy II - no AC
Getting greasy and putting in my cruising 406 soon.
Old 8th-May-2006, 04:53 PM   #8
72GreenRally
72GreenRally's Avatar
Nova(s): '72 Green Rally Nova
Get Jonesy outta yer car!!!! That guy can suck the brightness out of a million candle power spotlight!!!!
When I had to replace some of the dash lights in my Nova, I found that one of the light companies makes a "bright" version of the dash light bulbs. I think it was Sylvania. You might wanna check it out!
Randy (so bright, I don't need dash lights!!)
Are you pondering what I'm pondering?
Old 8th-May-2006, 06:47 PM   #9
loneagle
(OP)
loneagle's Avatar
Sylvania bulb #2825 are the ones!
'70 Nova 355 cid
Super T-10 4 speed
Old 8th-May-2006, 08:55 PM   #10
ovrdrive
ovrdrive's Avatar
Nova(s): 1971 V-8 A/C car
Would painting the backside with white instead of the metallic silver do the same? Or would it be worse?
Dan
Old 10th-May-2006, 11:17 AM   #11
chevynuts88
chevynuts88's Avatar
Nova(s): 66 SS
You can put in white backgrounds www.whitegauges.net pretty reasonable.
Old 13th-May-2006, 07:41 PM   #12
loneagle
(OP)
loneagle's Avatar
Nice job on the white gauges!
Well, I recieved the LEDs and installed em. They aren't bright enough to illuminate my Autometer gauges!
Looks like I'll be using the Sylvaina 2825 bulbs
'70 Nova 355 cid
Super T-10 4 speed
Old 14th-May-2006, 08:17 PM   #13
americangraffiti
Title: Guest
Posts: n/a
Speaking of grounds..........what (if any) if the best place to take ground from?
I always try to scrape paint off of a surface if I am ground there.......but is there the ideal spot on the car to draw a good ground? (especially under dash) Mr. Moderator?
Old 15th-May-2006, 12:18 AM   #14
loneagle
(OP)
loneagle's Avatar
I used the area just above the park brake pedal. I think this is where the factory ground wire is connected. After adding the extra ground wire, I cleaned the area and used a star washer to bite into the metal. My dash lights are nice and bright now.
'70 Nova 355 cid
Super T-10 4 speed
Old 15th-May-2006, 02:05 AM   #15
nasrock
nasrock's Avatar
Title: Nova Newbie
ok, wheres the best place to add the cable to the cluster? i need one bad because i can hardly read my spedo.
Ive got a 71 Nova and I'm doing a full interior and exterior restoration, but the engine ROARS like a Tiger
3rd Gen dash paint taz3 Body and Interior 34 23rd-January-2009 07:22 PM
Dim lights ? Fast Eddie II Electrical 7 24th-May-2006 12:15 AM
73 Backup Lights Switch ConcertinaKid Electrical 1 23rd-May-2006 12:00 PM
dash mounted tach 72Nova350 Electrical 2 29th-March-2006 11:33 PM
dash lights went out? theracer Electrical 2 29th-March-2006 12:37 AM
