bolt on VS Weld on sub frame connectors - Chevy Nova Forum
Old 26th-April-2006, 03:23 PM   #1
Ironcross25
(OP)
Nova(s): 1971 406 sbc
does any one have an opinion on the strength of bolt on subframe connecters versus the strength of weld on ones. Any input would be great.
Old 26th-April-2006, 03:33 PM   #2
wskaiser
wskaiser's Avatar
Weld on will offer the most strength but bolt on is a vast improvement over none at all. Guess the choice is up to you depending on what you want. I personally have bolt on and have no complaints but I don't abuse mine to the point where it would make any difference.
65 SS L30 327, M21 Muncie, 331ratio 12 bolt rear, factory air
NNN member since 1986
"You can't cure stupid"
Old 26th-April-2006, 03:42 PM   #3
NovatoriusRex
NovatoriusRex's Avatar
Nova(s): 67 Chevy II Nova Hardtop
You could get the best of both worlds by initially bolting on a set of connectors and then getting them welded on when time/money allow.
From what I've seen, there isn't much difference in the actual structure of the two different types of connectors. The only real difference is how they connect to the car at the end points.
With the bolt on connectors actually contacting more metal on the car before being welded in, might they actually be stronger at the end points than weld-on only connectors?
-Brent
I want a new duck. One that won't steal my beer... - Weird Al
Old 26th-April-2006, 05:19 PM   #4
chevy2inreno
That's what I did. I installed bolt-on connectors from Competition Engineering on my 63 vert. Then, about a year later, had them welded on when I had a new exhaust installed. The difference was noticable when I bolted them on and noticable again after they were welded. In addition, I had the exhaust shop jack the car up a couple inches in the middle of the door when they welded up the connectors in an attempt to square up the door openings to a degree. If I had it to do over though, I'd use the Gloabl West connectors and not the Comp pieces.
On a related note, I also noticed the car got stiffer when I replaced the rotted trunk floor with a new solid floor.
Dave
Old 26th-April-2006, 05:21 PM   #5
Ox65
Ox65's Avatar
Nova(s): 65' Chevy II
weld ons, I think there easier to install then bolt on ones. I have home made ones. But I'm making new ones because I'm putting in new rear framerails.
Just my .02
Old 29th-April-2006, 06:27 PM   #6
intruder
intruder's Avatar
Title: Nova Newbie
Nova(s): 1963 wagon
Don't you have to move the springs inboard on one or the other? And doesn't Chevy2Only have tubular connectors? Anyone tried those?
  • 1963 Chevy II, wagon
  • 1994 9C1
"Just because I rock, doesn't mean I'm made of stone."
"If there must be trouble, let it be in my day, that my child may have peace." -Thomas Paine"
Psalm 144:1
Old 29th-April-2006, 06:43 PM   #7
wskaiser
wskaiser's Avatar
I don't think neither weld on or bolt on require moving the springs. I know my bolt on did not.
Old 30th-April-2006, 05:57 AM   #8
Colin
Colin's Avatar
Comp Engineering weld in connectors for 3rd gen Nova's require the use of their rear frame rails, which are designed to move the springs in.
Old 30th-April-2006, 03:19 PM   #9
mychevyii20
Nova(s): 1966 More Door 350hp 350
Originally Posted by chevy2inreno
....... If I had it to do over though, I'd use the Gloabl West connectors ........
Dave
I used the Global West weld in connectors. Fit well, no interference with the floor or cables.
Old 6th-July-2009, 04:19 PM   #10
Ourtopless63
Title: Nova Newbie
Nova(s): 63 Convertible, 350, auto
I have a 63 convertible. Global West and Comp Engineering both told me their sub frame connectors will not fit my car. Has anyone tried them? Can they be modified to fit?
Old 6th-July-2009, 05:25 PM   #11
luepke75
luepke75's Avatar
Nova(s): 63SS,63LR,68
Garage
Comp. Eng. weld in connectors have the front spring box mount welded on them and are designed to be used with their rear rails. They can be modified to work by cutting the mount off. I did this to use their rear rails with the connectors I already had. If I ever do it again I will save the money and make my own. All you need is 2"x2" box tube. Something around .063 should work fine. It will cost you around $20-$30. There are many ways to do it. I used the CW ones and have been very happy with them. Using the 2x2 will require cutting the floor. welding them in will be stronger it connects them to the car in more places. Like others have said you can use the bolt in ones and then weld every where they touch the car.
Old 6th-July-2009, 07:50 PM   #12
dh63ss
dh63ss's Avatar
Title: Nova Newbie
Nova(s): 1963 SS
X2! I also have the Global West weld ins. I have considered welding a 2 inch section of angle iron from the seat braces to the connectors where they pass underneath, just for another tie-in point.
Old 6th-July-2009, 08:21 PM   #13
Fast Eddie
Fast Eddie's Avatar
Nova(s): 1966 Nova
Great product, moved the springs inbound and used them in the opposite position. Hit the jackpot they fit perfectly.
Fast Eddie
1966 Nova
408 cu in SBC
Aqua
Old 7th-July-2009, 02:58 AM   #14
JRouche
JRouche's Avatar
Just go buy some heavy wall tube in either 2x4 or 2x3 and make them, weld in. You will be surprised at how inexpensive a couple sticks of tubing is compared to the "kits" that are available. Its just simple tubing... Weld in is my choice. JR
Old 27th-September-2009, 03:17 PM   #15
hexrob
Title: Nova Newbie
Nova(s): 65 nova coupe
I just bought a 20ft. stick of 2x3 from my local metal shop for $24.50
8.5 = 8.78 or how to turn a 10 bolt 8.5 in to a 12 bolt! well almost. veno Drivetrain & Performance 15 24th-March-2010 03:16 PM
D.I.Y. How to do it yourself. NIGHTSHADE Best of Body and Interior 8 16th-September-2006 04:12 PM
Another frame mount dilema... DHoskins 3rd Generation Chevy II/Nova's 3 20th-May-2006 07:41 AM
Frame mount question... DHoskins 3rd Generation Chevy II/Nova's 5 13th-May-2006 03:21 PM
New welder! NIGHTSHADE Body and Interior 45 10th-April-2006 12:15 AM
