Old 19th-April-2006, 11:55 PM   #1
72Orange
72Orange's Avatar
Nova(s): 1972, 383, Vortec Heads
Weighed my 72 tonight
With about 5/16 tank of gas and without me:
Overall Weight : 3267 lbs
Front/Rear Ratio: 52.3%/47.7%
Left/Right Ratio: 50.7%/49.3%
Weight modifications:
aluminum radiator saved around 8 lbs
front disc setup increased around 18 lbs
2" front drop spindles increased front weight distribution
removed a/c condensor, evaporator, compressor and heater core
aluminum intake
Old 20th-April-2006, 12:05 AM   #2
burningsquirrels
burningsquirrels's Avatar
correct me if i'm wrong, but isn't that f/r weight ratio pretty darn good and close to 50/50? i thought novas were like 60/40 stock...
<<--- Moron for neglecting his Nova.
Old 20th-April-2006, 12:12 AM   #3
strtlegal
strtlegal's Avatar
hey orange...
what motor?? aluminum heads??
Old 20th-April-2006, 12:13 AM   #4
72Orange
72Orange's Avatar
Yeah, I was pretty surprised by that too. I guess it's because the battery is in the trunk.
What does a Optima Red Top weigh? I'll do a quick calculation and see what that would've done to the ratio.
Old 20th-April-2006, 12:19 AM   #5
72Orange
72Orange's Avatar
Optima Red Top weighs 40 lbs according to this
Adding a couple pounds for cables and the battery box then if the battery was in the front it would be :
Front 53.6%
Rear 46.4%
It's a 383 with iron vortecs.
Old 20th-April-2006, 12:33 AM   #6
chevy72nova
chevy72nova's Avatar
Nova(s): 72, 74, 69, 63
is everything else stock equipment for the car? ie. steel hood, bumpers, retains inner fenders and interior? power steering? steel wheels? just wondering what to expect when i weigh my 72.
thanks
Ian
Old 20th-April-2006, 12:48 AM   #7
72Orange
72Orange's Avatar
Pretty much everything except what I previously mentioned is stock.
has inner fenders
has new repop bumpers
all steel body panels including steel 2" cowl hood
has power steering
has front bench seat (for now)
rear seat still installed
has a spare in the trunk (but no jack)
no radio or speakers
has headers (I think they are lighter than exhaust manifolds)
I'm not sure what the wheels are made of but they are Cragar Street Stars
185/60/15's up front 245/6015's in rear
subframe connectors add a few ounds
That pretty much covers everything
Old 20th-April-2006, 10:15 AM   #8
chevy72nova
good to know. im shooting for gettin my 72 under 3000 lbs with an iron headed small block.
Old 20th-April-2006, 10:25 AM   #9
69NovaSS
I've read many times that moving your battery to the trunk has the same effect of weight distrubition as moving your motor back several inches (I've actually read a few that said "up to ten inches back")...these results would sorta support what those magazine articles stated...
Very cool...
NPHNP
Old 20th-April-2006, 10:30 AM   #10
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
Very cool...
I've read (hey, must be true right?!?!) that when placing the battery as far back as possible in the trunk (behind passenger side tire), it has the same effect as adding TWO batteries right over the tire due to the lever effect.
Don't worship false idles
Old 20th-April-2006, 10:31 AM   #11
69NovaSS
Front 53.6%
Rear 46.4%
thats not quite right....your missing the effect that leverage would have on the overal weight balance....Normally the battery is right near the very front of the car....when you move it to the trunk you have moved that weight at least 12-13 feet from its original location...that will make a big difference...
Just look at it this way...pick up your battery and hold it... that took 40 lbs worth of force...now pick it up and hold it straight out at arms length in front of your body...that takes more than 40 lbs worth of force to do that....NOW try picking that battery up on the end of a 12 foot pole.... ....I gurantee it will take WAY more than 40-50lbs worth of force to pick that thing up....that is roughly the effect it has on your car when you move it to the trunk....
NPHNP
Old 20th-April-2006, 10:35 AM   #12
DriveWFO
DriveWFO's Avatar
thats not quite right....your missing the effect that leverage would have on the overal weight balance....Normally the battery is right near the very front of the car....when you move it to the truck you have moved that weight at least 12-13 feet from its original location...that will make a big difference...
I hear an echo in here
Old 20th-April-2006, 10:39 AM   #13
69NovaSS
NPHNP
Old 20th-April-2006, 11:46 AM   #14
burningsquirrels
not quite a 12 foot pole since the center of gravity is somewhere in the middle, but we got the gist of it.
i wonder what my nova weighs. on the old rod knockin' motor i hit the brakes way before i crossed the line and i ran a 14.4 at 100mph at 3000 altitude at LACR.
my car has very little in it, no fenderwells, no power brakes, no power steering (chopped the pump off), aluminum intake, missing lots of upholstery, and cross-drilled floorpans (oops, was that rust?)
Old 20th-April-2006, 01:23 PM   #15
69NovaSS
Absolutely....that is why I said "roughly the effect"
Ae you still using the power steering box only without a pump????? Isnt that stiff as heck?
NPHNP
Irwindale tonight? undercvrSS South Western US 1 15th-June-2006 03:52 PM
Any one going to LACR tonight? Dr. Denny Drag Racing Forum 2 29th-April-2006 07:05 PM
java hut tonight novacars Canadian Owners 5 25th-April-2006 02:35 AM
Drag's tonight? undercvrSS South Western US 9 24th-March-2006 01:25 AM
