Hardened fuel pump pushrod needed for billet roller cams? - Chevy Nova Forum
Old 12th-April-2006, 09:31 PM   #1
NovatoriusRex
(OP)
NovatoriusRex's Avatar
Nova(s): 67 Chevy II Nova Hardtop
I was reading the new issue of CHP today and there was a small writeup in their Q&A column about needing a hardened fuel pump pushrod for use with the ZZ4 cam.
Since this cam is what I have in my motor, I am wondering if I have the correct pushrod installed in the block now. I am using ARP-134-9701 (Summit part #) which is listed as a lightweight chromemoly pushrod, but it says nothing about being hardened.
Need I be concerned?
*Edit - I did some searching online and it is more confusing now since a lot of people online are saying to use a bronze-tipped pushrod. I hate conflicting stories. It is confusing and frustrating.
-Brent
I want a new duck. One that won't steal my beer... - Weird Al
Old 13th-April-2006, 06:39 AM   #2
65 Post
65 Post's Avatar
Nova(s): 65 Post
I don't know what a HARDENED fuel pump pushrod is. ALL fp pushrods are hardened. They might mean lightened. As in the hollow pump rod with the hardened tips. It's lighter and won't float the fuel pump. Dave
"Are you the hunter, or the prey?"
65 Post 11.59 @ 115mph
2002 GORDY 150" RED, 7.91@ 167
Old 13th-April-2006, 12:34 PM   #3
NovatoriusRex
(OP)
According to what I was reading, the billet steel roller cams can cause problems with the fuel pump pushrod; at least regarding GM's ZZ4 cam.
It wasn't really explained very well regarding whether the fuel pump cam lobe was likely to get chewed up or if the fuel pump pushrod was likely to get chewed up if there was a problem with an improper pushrod.
At this point I'm inclined not to worry about it due to the inconsistency of the info available. I think my motor may have bigger problems on the horizon that are going to require a tear-down.
-Brent
Old 13th-April-2006, 08:00 PM   #4
68SSGrandpa
68SSGrandpa's Avatar
Billet Cams, must use a Bronze tipped fuel pump push rod.
Comp sells a bronze tip fuel pump push rod part # 249-4607
Billet cams require a bronze tip on the fuel pump rod, or you will wear off that fuel pump lobe off the cam in a big hurry.
Other companies make bronze tip pushes as well, not just comp.
68SS Nova
SB Dart 440"
Street tune 640HP 600TQ
TKO-600 Moser 4:11
Old 14th-April-2006, 01:38 AM   #5
NovatoriusRex
(OP)
Here's one of the sites that posts conflicting info. Sallee is usually my first source of info for ZZ4 related info. The two guys discussing the topic here appear to have two different perspectives.
The "Scott" person sounds like he works for Sallee, but it isn't clear.
http://www.sallee-chevrolet.com/Disc...tml?1091136581
Also, the guy in the June '06 issue of Chevy High Performance says to use GM part number 3704817 which uses some "special heat-treat process" on the pushrod for use with a billet cam.
Thanks for your input 68.
-Brent
Old 14th-April-2006, 03:06 AM   #6
NovatoriusRex
(OP)
FYI - I dug a little deeper into that GM part number. It appears that Sallee includes that pushrod in their turn-key crate kit (Fastburn 383 w/ ZZ4 cam), so if they're going to warranty those motors with that pushrod, it seems like that'd be the correct one to use.
I think I'm going to take out the ARP one I had been using and put in the GM part before I do some real damage; assuming I haven't already.
-Brent
Old 14th-April-2006, 06:36 AM   #7
65 Post
65 Post's Avatar
Nova(s): 65 Post
Well, I learned something today! Dave
Old 21st-April-2006, 01:15 AM   #8
NovatoriusRex
(OP)
Update
I pulled my ARP pushrod out tonight to look for any signs of damage and the end of the pushrod that rides against the cam's pump lobe was perfectly clean and smooth still. It doesn't appear that this entire topic was an issue.
Just to be on the safe side though, I did replace it with the GM part I referenced earlier.
FYI - Replacing the fuel pump pushrod with the motor installed in the car is a PITA!!! AND, this one sorta PO'ed me, the bolt hole on the front of the block that's supposed to be tapped all the way through the block to hold the pushrod up ISN'T tapped all the way through on 1985+ production (not aftermarket GM) blocks, or at least it's not on mine. After fighting with the pushrod for a while, I had to get in my real car and go buy some grease to use to hold the pushrod in.
It's all back together and purring again. Next up, fuel mixture adjustments; this thing is running RICH! Stinky.
-Brent
Fuel Pump and Pressure Question Racinfan83 Drivetrain & Performance 11 29th-May-2006 03:37 PM
Electric Fuel Pump MNYPIT Drivetrain & Performance 14 25th-April-2006 12:45 AM
Fuel Pump john67 Drivetrain & Performance 10 16th-April-2006 03:36 PM
surge tank shaggy Drivetrain & Performance 6 1st-April-2006 02:14 PM
