Old 11th-April-2006, 07:52 PM   #1
big dog ss
big dog ss's Avatar
Nova(s): 1970 SS
coolant overflow tanks
just wondering what you guys with 68-72 nova's are using for an overflow tank? ive seen the moroso ones are there any other options out there?? thanks
bigdog
"Igitur qui desiderat pacem, praeparet bellum"
Old 11th-April-2006, 08:19 PM   #2
Woody
Nova(s): 71 nova
I ran a line to my washer resorvoir. I never used the washers anyways.
Old 11th-April-2006, 08:50 PM   #3
TY70SS
TY70SS's Avatar
Nova(s): 70SS nova
I got one from advance.It's universal for many places.
Old 11th-April-2006, 09:53 PM   #4
patman
patman's Avatar
Title: Moderator
Nova(s): 1964 Nova SS
I made one out of an aluminum backpacking fuel bottle. They come in a bunch of sizes and are very light, and they're cheap.
like these:
http://moontrail.com/stoves/msr_al_fuel-bottle.html
Click the image to open in full size.
1964 Nova SS - 406 - 700R4 - 10-bolt posi http://www.bracketracer.com
Old 11th-April-2006, 10:44 PM   #5
Nova_Guy
Nova_Guy's Avatar
Nova(s): 68 Chevy II SS
I bought a stainless steel tube style at a Goodguyst for ten bucks. It holds about a quart, it can with mounting brackets and bolts. Best of all it was made in Taiwan!
My web site
Webshots photo albums
1968 Chevy II National Nostalgic Nova Member
Old 11th-April-2006, 10:49 PM   #6
MNYenko
The 4th gen over flow bottle works best. It fits in the passenger fender behind the battery box. They are no longer in stock. You have to pick one up used. Earl
69 SS 396/375 Fathom Green 4spd buckets
70 SS 350 Black Cherry buckets auto F41
Old 11th-April-2006, 11:21 PM   #7
WILMASBOYL78
Thumbs up Overflow...
Bought a universal one and installed behind the battery box and ran hose down by the front fender brace. Works good in this spot..
wilma
A garage full, Karen says she is a Nova widow.
See the cars at http://www.chevynova.org/TomWilliamsCollection.html
Join National Nostalgic Nova Today! Click on the link at the top of this page.
Old 11th-April-2006, 11:51 PM   #8
big dog ss
big dog ss's Avatar
Nova(s): 1970 SS
thanks guys,, i like the idea of a working overflow tank and not just one that holds it til i reuse it.
Old 11th-April-2006, 11:53 PM   #9
Custom Jim
Custom Jim's Avatar
Nova(s): 1973 Nova Custom Coupe, 1974 Spirit of
I used a similiar aluminum canister/bottle like what Patman did but I used an old fire extinguisher bottle. I modified the top portion of it including the internal valve, cut off some things like the release handle but left the gauge on the top of the bottle (but it doesn't function) and also drilled another hole up high into the bottle to allow me to install and secure with epoxy a 180 degree elbow. The one half of the elbow goes into the container and the end on the outside of the container has a longer length of hose attached to it. What this hose and elbow are for is if the container does fill up I can route the excess from the filled overflow container to another location. I ran this longer tube off of the 180 degree elbow down below the bottle and then ran it inside the frame with the end by the rear subframe bushing. This way if the overflow container does become full the excess will be directed out of it, down the tube inside the frame and away from the front tire. Hopefully this would still allow me to still steer although it might cause a loss of traction on the rear tire on that side. I've seen some installs with the overflows tube ending in front of the front tire and I just think that would be more dangerous and you would have more of a chance of a loss of steering with it exiting in that area.
To secure mine I used a pair of large worm clamps to wrap around the bottle and a bracket off of the radiator support.
1973 Custom and Pro-Street, 1974 Spirit of America, 1977 Hatchback
Homepage: http://hometown.aol.com/krystaldesigns/page1.html New links just added January 2007 in more pictures and Steve Bailey's Benefit Car Show
Old 12th-April-2006, 02:24 AM   #10
Nova1194
Nova(s): 74 SS Hatchback
My 74 AC car came with one mounted on the right inner fender, much like the 4th gen cars, but it was bigger than I wanted, so I converted my washer jug, pulled the screen off but left the hose on so it will function properly.
Mike
Put your checkbook on the dash, and hammer down
Old 12th-April-2006, 09:47 AM   #11
NovaSS396L34
NovaSS396L34's Avatar
Like Earl said, the 4th generation bottles fit perfectly behind the battery under the fender in the 69-74 Novas. Tucked out of the way!
1974 Nova 692 HP 496 BB,
Best 1/8 6.242, @ 112.80
Best 1/4 9.936 @ 136.61
Best 60 ft 1.368
Old 12th-April-2006, 11:00 AM   #12
68chevyll
68chevyll's Avatar
I got a polished one from summit. Real nice for like 50 bucks. Later.
Mark!
Old 12th-April-2006, 01:06 PM   #13
74nova350ss
74nova350ss's Avatar
Mark!
same here
Eric
1975 Nova--1974 Nova Pro Street--1974 Nova Hatchback--1974 Nova SS--1973 Nova--1973 Nova Pro-Street. . . . . . . . I'm a Nova-Nut
Old 12th-April-2006, 05:07 PM   #14
C_Farley
C_Farley's Avatar
Title: Nova Newbie
I got one like this, but cheaper:
http://www.macsradiator.com/index.as...PROD&ProdID=27
Old 13th-April-2006, 10:16 PM   #15
72Orange
72Orange's Avatar
Nova(s): 1972, 383, Vortec Heads
Originally Posted by 74nova350ss
same here
Eric
Me too, here's a pic of mine installed.
68 only fuel tanks Tommy 3rd Generation Chevy II/Nova's 34 13th-October-2008 08:09 PM
Coolant at head bolt recess NEVER FINISHED64 Drivetrain & Performance 2 14th-June-2006 01:32 PM
Coolant flying out of tranny line opening!! Is this normal? NovaNate Drivetrain & Performance 9 2nd-June-2006 12:10 AM
What is optimum Coolant Temp? Oil Pressure? NovaNate Drivetrain & Performance 12 26th-March-2006 10:59 AM
