Fuel line size? - Chevy Nova Forum
Old 6th-April-2006, 09:49 AM   #1
chevynuts88
(OP)
chevynuts88's Avatar
Nova(s): 66 SS
Fuel line size?
Whats the most horsepower that a 5/16" fuel line will handle[for a single carburated engine]? What are you guys using?
Old 6th-April-2006, 09:55 AM   #2
69NovaSS
69NovaSS's Avatar
this is from a link in our weblink library
Originally Posted by http://www.centuryperformance.com/fuel.asp
Use these figures as a fuel line sizing standard:
Up to 250HP = 5/16" or -04 AN
Up to 375HP = 3/8" or -06 AN
Up to 550HP = 1/2" or -08 AN
Up to 800HP = 5/8" or -10 AN
Up to 1200HP = 3/4" or -12 AN
NPHNP
Do you recognize this vin:114279W458662
Old 6th-April-2006, 09:59 AM   #3
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
I was just gonna post this. I used this page for help with my new fuel system
Don't worship false idles
Old 6th-April-2006, 11:16 AM   #4
Mike Goble
Mike Goble's Avatar
Nova(s): 67 wagon project
It depends on where your fuel pump is. If you have the pump at the rear and push fuel through the line, you will support a lot more power than if you are trying to suck fuel through the same line.
I'm Mike Goble and I approve this message.
Old 6th-April-2006, 11:25 AM   #5
69NovaSS
69NovaSS's Avatar
hmmm...that is interesting...so if you run an electric fuel pump you can support the same HP with a smaller fuel line than if you were running a mechanical fuel pump?
Very interesting
NPHNP
Old 6th-April-2006, 06:30 PM   #6
nova656567
Nova(s): 65 coupe 65 SS 67 Wagon
You can achieve higher flows with most of the electric pumps on the market than mechanicals. And fuel pumps are more efficient pushing the fuel than drawing it. I quess thats why they are fuel pumps not fuel suckers.
Old 5th-June-2008, 09:09 AM   #7
71'Nova 383
71'Nova 383's Avatar
Nova(s): 71 Nova
Updates?
Just curious if you guys have any new information on this subject?
Maybe some real field information from actual vehicles/applications, not from an article or mathematical equation. As I've found in reading tons of threads and articles, there's not one system that works the same every time. It depends on what size line, electric or mech pump, dead head or return regulator, stock pickup or sump, etc...
I have a sump in the gas tank, 383 Stroker with 510 hp, 700R4 Trans. Everything is new so I've been debating but think I'm going with a mechanical pump, the 130 or 170 from holley. So I'm down to determining whether I'm going to go with 3/8" or 1/2" line. I'd like to go with a 1/2" pre-bent, but I'm not sure it's made? If not then it's a roll of SS that I have to bend or just go with SS Braided.
Thanks.
Chad
Brake line question for 66 with disc brakes, dual master with proportioning valve. FunkyNova66 Steering, Suspension, and Chassis 59 20th-August-2010 10:33 AM
68 only fuel tanks Tommy 3rd Generation Chevy II/Nova's 34 13th-October-2008 07:09 PM
Fuel System Planning 72Orange Drivetrain & Performance 15 23rd-April-2006 04:24 PM
surge tank shaggy Drivetrain & Performance 6 1st-April-2006 01:14 PM
AN vs. NPT: Understanding port threads, adapter fittings and line sizes. DriveWFO Best of Drivetrain & Performance 0 23rd-March-2006 09:07 PM
