Old 4th-April-2006, 12:02 PM   #1
SyncroMush
Title: Nova Newbie
BBC owners... What baffled oil pan ?
What aftermarket baffled oil pans fit 3rd gen with BBC? Do you have clearance issues, ground header or other ?
I noticed a thread that showed a notched cross member, I would rather stay away from that....
Thanks for any feedback.
Dale
Old 4th-April-2006, 12:14 PM   #2
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's and a 69
Not to worry the nocthed sub frame was for stroked BB I use a 7qt Moroso no issues at stock ride height.
2 L78's both, blue,51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 4th-April-2006, 09:49 PM   #3
SyncroMush
Title: Nova Newbie
Does the lowest part hang below the crossmember ?
Do you happen to know the Moroso pan you have 9" ?
Dale
Old 4th-April-2006, 09:58 PM   #4
americangraffiti
Title: Guest
Posts: n/a
Just an FYI........I purchased an aftermarket stock pan off of EBay and have had no issues........I put in a 427 this past winter.
AG
Old 4th-April-2006, 11:44 PM   #5
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Matt King used Moroso's Eliminator pan with the kicked out side rail like the one on my small block, when he had the big motor in Project Super Nova. Milodon also makes a similar kick out piece--both are worth 20-25h.p. more than a stock pan. Fit is tight, but it does fit if you get a later version pan; some early units needed clearancing.
69 Nova 410" pump gas small block-6.63/101
http://bowtie0069.fotki.com/
http://www.thefunnycarfarm.com
Old 4th-April-2006, 11:57 PM   #6
taz3
taz3's Avatar
Title: Moderator
Dale
Dale it is 9" pan don't remember if it hangs below cross member I think it is about the same.Engine is out right now.If you want I can measure to figure it out.
Paul
Old 5th-April-2006, 12:21 AM   #7
SyncroMush
Title: Nova Newbie
Hey, thanks for the replies. I am probably just paranoid. I plan to use the car mostly at the strip, and occasionally on the road. I don't want to have the pan scape on driveways.
Dale
Old 5th-April-2006, 02:23 AM   #8
bowtie0069
bowtie0069's Avatar
Nova(s): 69
The pan I mentioned is only 8" deep: http://moroso.com/catalog/categorydi...?catcode=11916
FelPro one-piece oil pan gasket questions & PN's 70Deuce Best of Drivetrain & Performance 58 5th-May-2009 09:10 PM
Oil Pan! DuDe Drivetrain & Performance 13 19th-June-2006 01:20 AM
Need a New Oil Pan for 65 w/Inline Fredsgarage Drivetrain & Performance 5 24th-May-2006 08:00 PM
Oil pump, pickup, pan DriveWFO Drivetrain & Performance 10 18th-May-2006 09:28 AM
Oil pan removal update Nova1194 3rd Generation Chevy II/Nova's 2 12th-April-2006 02:15 AM
