Old 14th-March-2006, 03:21 PM   #1
Baby
Nova(s): 1973 Nova
Bought 73 nova $400
Hey guys just bought a 1973 nova for 400 dollars. They said that it ran but couldn't start it because of a bad battery. So after 17hrs of driveing got it home a tryed to start it and it did'nt fire. Next morning i went out and bought a new battery, battery cables,and a new starter and it fired right up. Has a straight 6 and a two speed auto. I am haveing a problem with it the carb chokeing itself out when loading the engine. Whould rebuilding it be the best thing to do or can i just adj. it? On the other hand the car is solid. Found a little rust on the p/s floor board and some under the hood. The rear quarters need to be replaced because the last owner put a larg offset on and it chewed through the quarter lip. This is on both sides. I can just put half panels on to get rid of that. I will post pic's when i can.
Old 14th-March-2006, 03:52 PM   #2
Maxturbo
Depending on how long she's been sitting...you may want to drop the gas tank and flush & re-fill it. That and replace the fuel filter and THEN you may still need to rebuild the carb next. If you rebuild the carb now and it's the gas, you may just crap up your rebuilt carb.
Congrats on your find BTW.
Any pics?
The choke isn't hung closed is it?
You could try some spray carb cleaner down the throat and in the bowl (through that over-flow tube inside / top of the carb air inlet). Might help.
Old 14th-March-2006, 06:51 PM   #3
YENKO DEUCE REG
YENKO DEUCE REG's Avatar
Nova(s): 1970 Yenko Deuce 1969 Super Sport
One tidbit of advice regarding the one barrell rochester carbs that I learned with my first Nova: there are 4 (I think) screws that hold the top and bottom of the carb together. These screws go in from the bottom, ie; the head is down - very difficult (read:impossible) to get a screwdriver on. These screws will loosen up, causing a vacuum leak as the engine sucks air. The trick, is to purchase an inexpensive tool: a 90degree, ratcheting screwdriver, from Sears. This tool is about 4-5 inches long, and has a slotted driver on one side and a philips driver on the other, and a tiny direction toggle.
First make sure you have a vacuum leak, which is easy to do by simply placing our hand over the top of the carb while the engine is idling. If the idle speed increases, then you have a vacuum leak. To find the vacuum leak, simply spray some carb cleaner around the seals and vacuum ports until you notice the idle speed pick up - "there's your sign!"
Simply tighten these 4 screws and an off-idle stumble from a vacuum leak will go away.
M
70 Yenko Nova
69 SS L78 Nova = 8yr old Benjamin's Nova
67 RS 327 Camaro = 2yr old Danny's Nova
Old 14th-March-2006, 07:02 PM   #4
nova64000
nova64000's Avatar
I have a 64 with a 350 and a 600 holley carb . I go to collage out of state.
the nova just sits in the garage and my dad never bothers to even start it
When Im home over break I only drive it around the block a few times since my parents will not put it back on their insurance polacy. I put a new HEI distributor in it and timed it but it still runs rough. At first I thought the carb needs to be rebuilt but now I am starting to think the fuel system should be flushed also.
Old 14th-March-2006, 11:28 PM   #5
Baby
Nova(s): 1973 Nova
Thanks for advise, tonight i replaced the cap, rotor, wires, and plugs. It didn't help any so i was thinking of rebuilding the carb and replaceing all the gaskets. i willl also remove gas tank and drain the gas, and replace the filter. yea about the pic's my camer craped itself and my friend just has to send the pic's i took on her camera to my e-mail. As soon as she does that i will post them. How would i post them if my account says i cant put attchments to my account? But again thanks for the advise. Will post pic's as soon as i can.
Old 15th-March-2006, 02:53 AM   #6
Colin
Colin's Avatar
Get an account somewhere like www.photobucket.com
Upload your pics there then copy and paste the link to your post here.
Old 15th-March-2006, 07:29 AM   #7
Maxturbo
You can also donate toward this site and get pic posting privileges or as Colin pointed out, link them to the web.
See...
http://stevesnovasite.com/forums/showthread.php?t=27716
Ya' got her running any better yet?
Old 15th-March-2006, 01:01 PM   #8
Baby
Nova(s): 1973 Nova
Talking
She's running but not that strong. Plus it's only a I6 so if it run's i'll drive it for now until i get my 383 done and my t350 trani. But i'll drive it till then with the six in it. Again you guys thanx for all the help. I 'm not sure if i said this but this is my first restoration. So everything is taken in and looked at
Old 15th-March-2006, 04:28 PM   #9
Maxturbo
Check your timing.
Have fun on your 1st big project.
Old 15th-March-2006, 08:01 PM   #10
YENKO DEUCE REG
Ha! You'll never be the same
Make sure you have plenty of these
M
70 Yenko Nova
Old 15th-March-2006, 09:45 PM   #11
Baby
Nova(s): 1973 Nova
Your right yenko i started on a 1973 for my first car and sold it because of highschool sports and other things. And i don't want to be that guy that says i wish i would have never sold that.
How do you guys feel about a big block in these cars? Just woundering because that what i might do. I am look for a 396-402 375hp to rebuild. And put a turbo 400 behind it any comments? I also would like to know what you guys would say if i can get a t400 for $200. And trust me,myself and my jarhead buddies will have lots of during this project.
Old 15th-March-2006, 09:49 PM   #12
2doorpost
2doorpost's Avatar
Nova(s): 1974 Hatchback
GO FOR IT!!!!- worlds first sub 10 second 1000.00 race car.
"Just Passing Thru"
Old 16th-March-2006, 01:06 AM   #13
Baby
Nova(s): 1973 Nova
Does any body know of a 375hp 396-402 is for sale and where. If you find on around NC and or around in Michigan please let me know. Pref. a motor to rebuild. thanx
Old 16th-March-2006, 07:38 AM   #14
Maxturbo
If you head on over to the Charlotte Auto Fair in a couple of weeks, I'm sure you'll find what you need.
http://www.charlotte-autofair.com/
Old 16th-March-2006, 03:32 PM   #15
Baby
Nova(s): 1973 Nova
Yea i'll try that, are you going to be there Maxturbo if so let me know were your going to be. I would like to meet you and see your car. Agin thanx for the help
71SS....Came with either bench or buckets ?? John'sCustoms Body and Interior 13 5th-July-2009 07:55 AM
more 76 nova parts 67 supersport Ebay, etc. Discussion 0 28th-April-2006 11:16 PM
Bought another 65 nova. Bucksatan 1st & 2nd Generation Chevy II/Nova's 8 26th-March-2006 04:39 AM
"SS" identification clues NPHNP Best of Body and Interior 3 1st-November-2005 04:24 AM
