How to hook up kick-down cable th350? - Chevy Nova Forum
Old 24th-February-2006, 01:15 PM   #1
NovaNate
NovaNate's Avatar
Nova(s): 71 Ventura
Anybody have a photo or good description of how to hook up the kick down cable from a th350 to a edelbrock carb? Any tricks to adjustment? I'm a little confused looking at the long slot on the kick down cable end, and the available holes in the carb throttle lever. Which hole do I stick it to? Outside or inside of throttle lever? What kind of fastner?
Old 24th-February-2006, 02:11 PM   #2
BTHOMAS67Wagon
BTHOMAS67Wagon's Avatar
Without posting a pic, I'll try to help...
First, you will want the Detent/Kick down to be on the "bottom part" of the throttle linkage on the carb, so that when you depress the pedal your accel linkage will pull the throttle linkage back and rotating the detent part of the linkage foward. (I hope that makes since ?!)
The detent cable as you mentioned, has the long slotted hole in it, which will attach to the throttle linkage and when the stud (can be bought anywhere) reaches the end of that slotted hole, it will pull the detent cable.
When you are at WOT (wide open throttle) you want the detent to be at the end of the pull. (and remember, just because you are pulling WOT at the carb, doesn't mean that your pedal is pulling it that far. So WOT, should be measured with the pedal.)
Hopefully that helps and maybe someone can explain it in words better then myself ?!
-Brent Thomas
Ohio
-96 Buick RMW
-94 Buick RMW
-67 ChevyII Wagon (13+ yr project)
-69 MGC GT
-91 GMC Syclone (Jan 2014)
Old 24th-February-2006, 03:07 PM   #3
DANNO
DANNO's Avatar
Nova(s): 72 Sedan
Here's mine:
My pics:
Old 24th-February-2006, 09:45 PM   #4
malcom2073
Title: Nova Newbie
Awesome, I've been wondering how to hook mine up as well, figured it was something like that, the pic helped thanks.
Old 25th-February-2006, 12:21 AM   #5
novacharlie
Nova(s): 1963 hardtop
I un hooked mine completely and soldered the end shut. I figure with the mega shift I can down shift just as well. Anyone else disconected theres?
Chuick
smilies
Old 25th-February-2006, 08:48 PM   #6
68chevyll
68chevyll's Avatar
Mine is not hooked up either.
Old 25th-February-2006, 11:28 PM   #7
footbrake68
Nova(s): 1974 Nova, 1968 Camaro RS
Yep ... good pic Danno - we hooked ours up to hit about 7/8 throttle input after installing the new motor ... then the new cable was promptly melted by the new headers ... so just make sure you route it away from the hot stuff in the engine bay.
We just got in a hurry to hear it run and drive it down the road .
Scott
1968 Camaro SS/RS 461 (... 496 Stroker - Project Underway)
1974 Nova Custom 350
1998 Firebird TA Ram Air Conv LS1
Old 25th-February-2006, 11:42 PM   #8
BTHOMAS67Wagon
Okay, you all offically threw me for a loop on this ?!
You didn't hook up your kick down ?!
Why!!!
How do you pass?
How do you "get up and go"?
Did you switch you valvebodies or soemthing from stock?
-Brent Thomas
Ohio
-96 Buick RMW
-94 Buick RMW
-69 MGC GT
Old 26th-February-2006, 12:16 AM   #9
DANNO
DANNO's Avatar
Nova(s): 72 Sedan
The kickdown is just a way to downshift with your foot (what we used to call, "passing gear"). If it's not hooked up, you just manually downshift.
Dan (but mine's hooked up)
My pics:
Old 26th-February-2006, 12:00 PM   #10
novacharlie
No valve body changes. If you manually shift there's no need for a kick down, the 4 barrel has enough power in its self. Most street rodders disconnect them.
Chuck
smilies
Old 26th-February-2006, 12:09 PM   #11
Carl Stevenson
Carl Stevenson's Avatar
I welcome correction if I'm wrong, but I thought a TH350 needed the cable hooked up to make correct/more pressure in the transmission for the shifts. What I mean by that is I thought the shifts were on the lame side if the cable is not pulled out as the the throttle opens. For example, if the cable was permanently pulled 3/4 of the way out, would the shifts not be firmer than if it was at rest?
Carl
Carl (in the prairies...)
65 Canso Sport Deluxe (Sold)
67 SS 327 (Sold)
Old 26th-February-2006, 02:37 PM   #12
BTHOMAS67Wagon
Forgive me for sounding argumentative, but I completely disagree !!
(IT makes no sense !!)
Again, Why not just hook it up?
So, you are telling me that if you jump on the freeway are you need to pass someone at 50-60 mph, you drop it down to "D2" ?!
Have you ever missed "D2" and dropped down to "D1" (and listened to your engine and transmission loose a little life)?
I have only been in and floored a couple of cars that the detent was not hooked up (all being 350's w/4bls) and never have I had one "get up and go", but instead boog down and slowly gain speed. Again, why not just hook it up?!
I ONLY couple of reasons I can think of is that so that someone can make it sound like they are "manually shifting", they don't know how to hook it up, or they are jump too lazy.
There are NO reasons I can think of that they would be against hooking it up?!
PLEASE, someone chim in if they can change my way of thinking ?!
-Brent Thomas
Ohio
-96 Buick RMW
-94 Buick RMW
-69 MGC GT
Old 26th-February-2006, 03:45 PM   #13
Repointer
Repointer's Avatar
Nova(s): 1967 SS 1966 Post
This is what I understood. I never had mine hooked up all last year. Use my hand instead of foot for passing. (Or I should say hand and then foot ) Not a problem for me. I did ask the guy who just rebuilt my turbo 350 about it and he said it IS harder on the tranny if you leave it unhooked and manually shift. I couldn't tell you why though.
1967SS
357ci/TH350, 8.5" 3.73
RHS Vortecs
N/A
60' 1.63
7.49 @ 90.14
11.89 @ 111.30
1966 Post
6cyl
Old 26th-February-2006, 07:46 PM   #14
DANNO
DANNO's Avatar
Nova(s): 72 Sedan
Carl
You may be thinking of the Throttle Valve cable in overdrive trannys. Those must be hooked up and properly adjusted.
Dan (maybe?)
My pics:
Old 26th-February-2006, 08:23 PM   #15
Ray_McAvoy
Ray_McAvoy's Avatar
Nova(s): 1974 & 1977
Carl
I agree with Carl. According to the service manual, the TH350 detent (kickdown) cable connects to both a detent valve and a detent pressure regulator inside the valve body. In addition to downshifting, it also increases the line pressure that's applied to the clutches. That increased pressure helps prevent the clutches from slipping.
The reduced pressure is what would make it harder on the transmission. It could allow the clutches to slip under the load of hard acceleration.
68-74 kick panels? 74customnova Originality 8 25th-July-2014 10:07 AM
TH350 Kickdown too tight....could I have damaged my tranny? NovaNate Drivetrain & Performance 2 10th-June-2006 11:44 AM
TH350 Speedometer Cable Leak DriveWFO Drivetrain & Performance 10 14th-May-2006 03:34 PM
PowerGlide in my 66 SS for a TH350 Question Mad_Max Drivetrain & Performance 0 25th-April-2006 07:14 PM
Are 1965 Corvair kick panels the same as Nova? novamaniac Body and Interior 3 3rd-April-2006 08:20 AM
