Welding new frame rails - Chevy Nova Forum
Old 23rd-February-2006, 09:23 PM   #1
mac67nova
(OP)
mac67nova's Avatar
Title: Nova Newbie
Just got a pair of S&W frame rails and would like to Know what is the best way to weld them onto the stock body? Old rails are removed. Plug weld? any pictures would help.
Old 25th-February-2006, 05:15 AM   #2
Nova SS
Nova SS's Avatar
Nova(s): 1965 Nova SS
Ill email you tonight
DOGFISH HEAD Craft Brewery and Distillery
Lead Maintenance
USS SUBMARINE SERVICE
SSN 575 SSN 683
Old 25th-February-2006, 10:21 AM   #3
jeff64
jeff64's Avatar
Title: Nova Newbie
Mac-
I'm curious to hear what you find out on this...How well do those rails line up with the stock floorpan?
Thanks-
Jeff
Old 25th-February-2006, 03:41 PM   #4
Nova SS
Nova SS's Avatar
Which frame rail did you get? The universal one or the "direct fit" frame rails?
Lead Maintenance
SSN 575 SSN 683
Old 25th-February-2006, 04:41 PM   #5
mac67nova
(OP)
mac67nova's Avatar
Title: Nova Newbie
I bought the direct fit frame rails and sub connectors
Old 25th-February-2006, 07:12 PM   #6
Nova SS
Nova SS's Avatar
** NOTE , you will not need to remove the factory rails until all the welding is done, they can be completey removed or just section were you add the tubs.
The only place of interferance is the trunk floor, when installing the new S&W frame rails inside of the factory rail position they would need to pass threw the bottom of the trunk floor.
The best way is to remove the entire recessed trunk floor , just cut around the top , when removed it will look like this.
(This is the part that can be purchased from many of the classic parts houses.)
It is easiest to do this first ( cut out the trunk floor) then weld in the new rails butted up against the old frame rails. ( at the front and against the rear panel at the back of the trunk) Next cut out a narrow section down the center of the removed trunk floor and weld it back together forming a new narrow " mini trunk floor". When reistalled you will have to weld in a flat peice on either side to compensate for the narrrowed trunk floor and it will look stock.
If you use ladder bars you will have to fabricate an upper shock mounts. If you use leaf springs I would suggest sliders in the rear to replace shackles. You may want to move the axle back an inch to give you more clearance athe front of the wheel well lip to help clear tall tires.
This is my 65 with leafs and sliders. With the rails welded just inboard of the factory rail 12" tires are no problem, It gives me about 16" between rails and the wheel well lip.
Lead Maintenance
SSN 575 SSN 683
Old 25th-February-2006, 08:43 PM   #7
nova65ss
nova65ss's Avatar
Nova(s): 63 SS Convertible
Garage
I've always wondered this as well, I guess it will basically be better to weld them solid. Or is it just overkill and plugging them like the factory sufficient? Which way did you go Mike? Thanks,
Jimmy
Jimmy
Old 25th-February-2006, 09:32 PM   #8
Nova SS
Nova SS's Avatar
I "stiched welded" the rails. Short section about 1" long every 6 inches.
I also reinforced the factory frame rail aera before I welded in the new rails, A small plate along the rail and a plate above it
Lead Maintenance
SSN 575 SSN 683
Old 25th-February-2006, 11:45 PM   #9
jeff64
jeff64's Avatar
Title: Nova Newbie
Nova SS-
Thanks for the input, I know it'll come in handy when I'm ready to tackle this...soon!
I've been thinking I would do just as you say "butt the new rails against the old", and then remove. The only problem (maybe I'm just overthinking this) is the old rails have a lip that is actually spot welded to the floor. Kind of like this...
__ __
l l
l___l
How did you handle that?
-Jeff
Old 26th-February-2006, 02:18 AM   #10
mac67nova
(OP)
mac67nova's Avatar
Title: Nova Newbie
Thanks for all the info I'll let you know how it turns out
Old 21st-March-2006, 06:39 PM   #11
NIGHTSHADE
NIGHTSHADE's Avatar
Title: Moderator
Nova(s): NONE! It's a Chevy
Where do you get S&W direct fit frame rails?
Old 21st-March-2006, 08:31 PM   #12
Ox65
Ox65's Avatar
Nova(s): 65' Chevy II
S&W makes them,I looked them up last week.
Old 21st-March-2006, 09:07 PM   #13
NIGHTSHADE
NIGHTSHADE's Avatar
Title: Moderator
I was on their web site (I think) S&W Racing. And they had no listings in their frame rails section.
Old 21st-March-2006, 10:09 PM   #14
hwy NOVA
Nova(s): 62 Conv 62 Coupe
S&W Racing Catalog............. Frame Rails & Components........... Page 1.
--ET
62 Conv
62 2-dr Coupe
Old 21st-March-2006, 10:11 PM   #15
hwy NOVA
Gas Tank Question......
This has probably been asked many times, but does the stock gas tank still fit?
--ET
62 Conv
62 2-dr Coupe
D.I.Y. How to do it yourself. NIGHTSHADE Best of Body and Interior 8 16th-September-2006 03:12 PM
Frame Rails 67deuce Steering, Suspension, and Chassis 2 13th-June-2006 04:06 PM
Another frame mount dilema... DHoskins 3rd Generation Chevy II/Nova's 3 20th-May-2006 06:41 AM
S&W Rear frame rails???? NOVACA1N Steering, Suspension, and Chassis 6 20th-April-2006 01:44 AM
stock frame rails and ladder bar ?'s novas4life Steering, Suspension, and Chassis 3 28th-March-2006 05:58 AM
