Electric choke power source? - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 27th-November-2013, 01:53 PM   #1
epfatboy
(OP)
epfatboy's Avatar
Nova(s): 1964 Chevy Nova SS
Where are you guys tapping into for you power source for the electric chokes?
I was thinking of using the windshield wiper motor but I'm not sure which wire on the wiper motor to tap?
Here is a pic of my wiper motor any ideas?
Name:	ImageUploadedByAG Free1385574819.174474.jpg
Sent from AutoGuide.com Free App
'64 Nova
2015 Transformation
Old 27th-November-2013, 02:19 PM   #2
Jackel
Jackel's Avatar
Nova(s): 70 Nova SS I bought new.
Here is a pic of my wiper motor any ideas?Attachment 53881
That is what I did for a quick hook up. Just take do a voltage check on the suspect wire and make sure it is 12 volt (Ign ON) and 0 (Ign OFF).
Retired Bum...The transition was easy
Old 27th-November-2013, 03:26 PM   #3
Darth
Darth's Avatar
Nova(s): 1970 nova
Did the same here
3rd Gens Unite
Old 27th-November-2013, 07:47 PM   #4
72novaproject
72novaproject's Avatar
Nova(s): 72, 67
It's a good idea to wire it through an oil pressure switch so the choke won't begin to heat until the engine has oil pressure. That's how the factory wired them.
To each problem...exists a solution...now think.
Half built 383, MT Tires, and 20 lb of Mig wire.
Old 27th-November-2013, 10:16 PM   #5
nvscott5
nvscott5's Avatar
Nova(s): 1962 Chevy II LM7 5.3L
Simplest way is to wire it from the coil positive wire or "HEI wire". All the coil or HEI wire is is a switched ignition power feed that has power during cranking as well as during run.
Old 27th-November-2013, 11:10 PM   #6
TMack63nova
TMack63nova's Avatar
Nova(s): Nova Less
Garage
I'm running an I6, I ran my positive to the coil and the ground to the coil mounting bracket. It works great.
Just my
Old 28th-November-2013, 12:02 AM   #7
epfatboy
(OP)
epfatboy's Avatar
I thought about the HEI wire as well but read that it might not be a good idea to steal power from the HEI... When I looked around the engine bay the next best candidate seemed like the wiper motor..
I have a mechanical oil pressure gauge so I think wiring thru the sender is not an option.
'64 Nova
2015 Transformation
Old 28th-November-2013, 12:31 AM   #8
ces63ss
ces63ss's Avatar
Nova(s): 63 nova ss
I wouldnt steal power from the ignition. We do everything to get more juice there and then we steal from it??? Go to the wiper motor. I did that. What I did was just used my light tester to check for power with ignition on/off.
Old 28th-November-2013, 02:03 AM   #9
nvscott5
nvscott5's Avatar
There is no power loss at the ignition circuit whatsoever when wiring the choke to it. If it was wired in series to the coil then it would be so minimal that you would have to hook an oscilloscope to see the difference in voltage and plus no "loads" on these cars are wired in series, unless you wire in something in series on your own. Wiring it in parallel, the alternator carries the task of the extra load...which again is minimal. I don't say anything for electrical if it isn't true, everything I state is in fact, fact. Tried and true, tested and proven. There is no if's or maybe's, or kinda's.
Old 28th-November-2013, 02:51 AM   #10
ces63ss
ces63ss's Avatar
Nova(s): 63 nova ss
But what if... lol
Old 28th-November-2013, 11:52 AM   #11
72novaproject
Nova(s): 72, 67
Not the sender. This would be a simple on/off switch. The same one you would use for a warning light. Depending on how you want to wire it you could incorporate a low oil pressure warning light and control your choke with the same switch. I used a three prong switch and use it for an oil pressure warning light and a fuel pump cut off safety switch.
Old 28th-November-2013, 01:20 PM   #12
epfatboy
(OP)
epfatboy's Avatar
Nvscott, I only wish I knew what you were talking about! I barely know enough to hook up a tester to see if a wire is switched. Hell I'm not even sure how to use my multi tester correctly, I stumble about and eventually find the right setting so i make sure I have the right voltage.
Either way I hooked it to the wiper motor and I did a hell of a job. Found the right wire, exposed some copper, wrapped the new wire around the old and soldered a splice. Sealed it with shrink tape and ran the new choke wire in a black fabric wrap, looks pretty clean.
'64 Nova
2015 Transformation
Old 28th-November-2013, 09:53 PM   #13
EdwardsSS
Nova(s): 1 -'63 Nova hdtp
I had an open space in the fuse box so created a new circuit.
Old 28th-November-2013, 11:17 PM   #14
jackb
Nova(s): 1968
thats what i did also.
electric choke ?? coupe ss Electrical 5 15th-May-2012 11:43 PM
electric choke power question justsomeguy Electrical 17 15th-April-2011 01:26 PM
Help With Electric Choke BecketMANova Drivetrain & Performance 7 8th-July-2010 06:32 PM
Electric Choke sirart Drivetrain & Performance 8 20th-March-2010 08:52 PM
