Old 14th-October-2005, 10:52 PM   #1
RatNova71
RatNova71's Avatar
Big block heater core question (Need help)
My original heater core sprung a few leaks tonite. My car has the small block core/ heater box now and i would like to do a factory big block type set up. Is there anything i need other than a factory big block heater core? I know i will need to drill holes in my heater box in the correct location, but is there any other parts i need to buy other than the core?
Thanks for any help you can give me
Andy
2 Novas
71 Rat 402/th350 (Big Brother)
20K mile 72 250/3 on the tree (little sister)
Painting the 72 start to finish
My 72 with poverty caps and new BFGs
Old 14th-October-2005, 11:21 PM   #2
71SS
That should be all you need. Do you know they repop the BB heater core covers also.
71 Nova SS SOLD
Next Project 70 Nova SS
Old 15th-October-2005, 12:11 AM   #3
RatNova71
RatNova71's Avatar
Ya I know, I'm CHEAP!!! lol
Andy
2 Novas
Old 15th-October-2005, 10:15 AM   #4
Toms73NovaSS
Toms73NovaSS's Avatar
Becides drilling the holes I needed to modify the passenger side clip that holds the heater core into the heater box.
Other than making a outer coverplate to dressup the holes with a gasket it is an easy job. The cover plate and gasket also stabilize the tubes so that they dont rub against the inner holes.
here is a pic of my home made cover plate:
Click the image to open in full size.
--Tom
'73 Nova 461 Rat
1/2" gas sender mod:Link Pics
Old 15th-October-2005, 01:38 PM   #5
RatNova71
RatNova71's Avatar
Thanks alot Tom. Just what i needed
Andy
2 Novas
Old 16th-October-2005, 08:09 AM   #6
americangraffiti
Title: Guest
Posts: n/a
There was a question on another thread about a bb heater core and core support.
Does anyone know if a sb core support on a 68-70 Nova will work for a bb transplant? I know the shroud is different.
If there is a difference, how difficult is it to change out core support?
Old 16th-October-2005, 11:03 AM   #7
RatNova71
RatNova71's Avatar
Are you talking about the heater box, or the radiator support ?
Andy
2 Novas
Old 16th-October-2005, 12:19 PM   #8
americangraffiti
Title: Guest
Posts: n/a
Rat......radiator support.
I didn't think you had to change radiator support when going from small block to big block.....just the shroud
AG
Old 16th-October-2005, 03:38 PM   #9
RatNova71
RatNova71's Avatar
Hi american, let's just say you have very good taste in cars and color combos...
Yes, the radiator support has a bigger opening cut out of it on the factory big block cars, due to the radiator being a few inches wider. Other than that, I don't think there is any difference. (Maybe a Guru could confirm this ). However, if you are not trying to make a 100% correct clone the small block stuff can be made to work. With a smaller aftermarket fan for instance. I still have the six banger shroud on mine which is really just a cover, not a true shroud.
I have a small block 3 row radiator on mine too. Cools OK, but would be better with a shroud. I'll get around to putting one in, one of these days.
btw, I hope your not thinking of switching out your small block, that thing is perfect just like it is! Is your car a factory SS? 70 or 71? and, what color is that? Thanks
Andy
2 Novas
Old 16th-October-2005, 04:10 PM   #10
americangraffiti
Title: Guest
Posts: n/a
Hey Rat...
Yeah, I found a vintage 427 last summer and am in the process of having it built.....also I am installing one of the Keisler Tremec 5 speeds behind it.
Engine bay will be done in correct hoses, clamps etc.
The car is a 5 owner true SS that was purchased new just 20 minutes from where I live. I even have talked with original owner. I've got the protecto plate.
Engine and tranny will be bagged and stored since they are all numbers matching.
I'm not buthering anything up for the install.....just in case I take it back original later.
I am going to be using my current three core radiator but with a big block shroud........anyway I'll post some pics when I'm done.
AG
Old 16th-October-2005, 04:19 PM   #11
RatNova71
RatNova71's Avatar
Hey, that is really, really cool. Can't wait to see it!!!
Andy
Andy
2 Novas
Old 16th-October-2005, 10:30 PM   #12
americangraffiti
Title: Guest
Posts: n/a
Rat........hey, we're twins
Old 17th-October-2005, 08:32 PM   #13
RatNova71
RatNova71's Avatar
Well, got the old leaky core out tonight (real fun job! ) Picking up my Autozone replacement tomorrow (better be for a big block!) and I'll probably pick up a new blower motor as well, seeing as its a bitch to get to.
Whole lotta trouble for a car that hardly ever sees cold weather driving, but at least it will be working correctly.
Andy
2 Novas
Old 18th-October-2005, 10:36 PM   #14
RatNova71
RatNova71's Avatar
Well, guess what... Autozone replacement says big block but its for small block, as well as advance auto... so much for getting one cheap.
Ordered one from NPD for a 69 No A/C big block camaro $49.95, should be here in 2 days. Did alot of checking and they ranged from $49 all the way up to $85 from yearone.
Anyone know what would be good to use to seal the blower box back to the firewall? I used to have a roll of refrigerator caulking, but I lost or threw it out somewhere along the way. Think maybe a home improvement center might carry something like that?
Andy
2 Novas
Old 19th-October-2005, 07:46 AM   #15
Toms73NovaSS
What I did for the seal between the outer box and the firewall is:
First I place it in place and noted where the most gap was (in my case where the cowel sides and fire wall met) and I then put seam sealer on the outer box inside lip. Built it up a bit more in the areas where it needed it. Then let it dry. Basically creating a semi flexable gasket. I'm sure silicone would work also.
The reason that I did this is I did not want to mess up the nice paint job of the firewall and heater box by just spreading something in the gap.
--Tom
'73 Nova 461 Rat
removing heater core on a 67 67 supersport 1st & 2nd Generation Chevy II/Nova's 18 4th-August-2006 09:32 PM
heater core hose chevyii Body and Interior 2 14th-June-2006 02:31 PM
Frame mount question... DHoskins 3rd Generation Chevy II/Nova's 5 13th-May-2006 03:21 PM
Big Block swap drag_77 Drag Racing Forum 4 25th-April-2006 12:23 AM
big block shroud question BillsNogo 3rd Generation Chevy II/Nova's 0 2nd-April-2006 10:57 PM
