LED Tail light Conversion - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 26th-August-2005, 04:24 AM   #1
SuperNova69
Nova(s): 69 Nova
Anybody know of anyone that makes these for 69's? I just saw in the latest Super Chevy that C2O has a kit for 66-67's. I think I might be able to use that since it's basically the same thing as a 3rd gen tail light, only vertical...and rounded at the top...
Think it'll work? Or does anyone know of any other companies that make them for 3rd gens?
Matt
Matt
69 Nova - 357, TKO600, Tru-Turn, awaiting LS1 swap
Old 26th-August-2005, 10:42 AM   #2
Maxturbo
Somebody has a site on "How To" LED the 3rd Gen lights as I have seen it before. Can't seem to locate it now though. You're talking about the complete lense background area not just the replacement multi LED bulb arrangement that plugs into the existing socket, huh.
Like these...
http://www.superbrightleds.com/led_prods.htm
Old 26th-August-2005, 10:52 AM   #3
69NovaSS
69NovaSS's Avatar
What Max suggested, getting an LED replacement bulb, for your existing fixture to me would be the easiest and cheapest way to do it. I will be going that route when the time comes. It will be nice not having to ever change a bulb again. Plus they are brighter too. Sorta a win win IMO
NPHNP
Do you recognize this vin:114279W458662
Old 26th-August-2005, 10:54 AM   #4
Maxturbo
The "CAMARO" AND "CHEVELLE" boys can buy em' all day long...
http://www.trimparts.com/Pages/Resul...&ProductCat=53
Old 26th-August-2005, 01:24 PM   #5
tpinova
Title: Guest
Posts: n/a
I spent three years working on the lights on police cars and emergency vehicles. This gave me a lot of exposure to LEDs. The 1157 LED replacement bulbs aren't a good option for third gen Novas. The LED bulbs are only bright when you look at them straight on. The factory angle of the bulb fixture is wrong for this. The best option seems to be the circuit boards with bulbs attached and a plug that fits the original socket. The great thing about LEDS is they are bright, have a very long life, put off very little heat, and draw very low amperage. Because of the low amperage, your factory flasher will not work. The aftermarket has address this but a LED specific flasher should be on your shopping list if plan to change over. Some manufacturers add a resistor to their light assembly to cure this issue. I have been waiting for a LED conversion kit to be released for for these cars for years. I think a new taillight lense design would be needed to get the most out of LEDS. The original looks like it would defuse the LEDs too much.
Old 26th-August-2005, 01:43 PM   #6
69NovaSS
69NovaSS's Avatar
Nothing better then the voice of experence. That is good to know info. Thanks
NPHNP
Old 26th-August-2005, 05:45 PM   #7
Allen_396
Allen_396's Avatar
I agree with all of this. The optics on the lens is designed for incandescent bulbs. LEDs put out a different light pattern and the objective of the lens is to capture the light and toss it out there at the correct (and legal) viewing angles mandated by the FMVSS.
Although they look neat and have other benefits mentioned above, I'd never stick any behind the old lenses designed for bulbs without testing it. I want people to see my lights from all necessary angles.
Allen (safety first.... plus I work in the automotive/truck/trailer lighting industry)
1970 Nova SS 396
1969 Corvette
Old 26th-August-2005, 06:38 PM   #8
SuperNova69
Nova(s): 69 Nova
Actually, the ones in Super Chevy said it had a sort of "hard drive" for the lights, and the LED's themselves were on a type of circuit board that went behind the lens. The whole reason I want LED lights isn't because they look cool (I actually think they look kind of ugly on 3rd gens), it's because I've seen how dim my lights really are compared to new cars with LED brakes/taillights.
Just trying to make my car more visible (without getting one of those 3rd brake lights).
I also remember someone on these boards made their own LED tail lights for their car (a 3rd gen, but not sure on the year). They said they accidentally left them on overnight and the wires/lights weren't even hot the next day.
Anyone remember?
Matt
Matt
Old 26th-August-2005, 11:39 PM   #9
tpinova
Title: Guest
Posts: n/a
If you are wanting more rear visibility, maybe I could suggest what I have on my car. I purchased a strip of eight LEDs under a red lense and mounted it at the top of the rear glass. This is wired directly to the brake switch under the dash (with a 10A fuse). Third brake lights have been standard on cars for twenty years now. That is longer than a large number of todays drivers have been lisensed. They are conditioned to identify this third light as 'the brake light.' Also with the thin LED strip, they are almost invisible until you touch the brake pedal. It's been good for a grin or two.
Old 27th-August-2005, 06:56 AM   #10
SuperNova69
Nova(s): 69 Nova
I've thought about those, but I dunno. Not really a fan of them on older cars. I do like it on my mom and dad's cars, but on mine...I dunno.
I guess I'll look into it anyway.
Thanks,
Matt
Matt
Old 27th-August-2005, 10:47 AM   #11
chevynuts88
chevynuts88's Avatar
Nova(s): 66 SS
I made my own
Someone on this site helped me connect them correctly. They are sitting on the shelf now because the "ARE NOT" bright.I was getting the finger from everyone because they cuoldn,t see brake or tailights unless in dark. Apparently what I did wrong is I didn,t use " super bright bulbs".The cost here for regular is 10cents each and for super brights is $1.00 each.
Old 29th-August-2005, 08:12 PM   #12
new2novas
new2novas's Avatar
Nova(s): 63 custom convertible
unless you know a bit about electronics, just buy the bulbs that have leds, the direct replacement kind....and let me know how they work
Old 29th-August-2005, 09:35 PM   #13
tpinova
Title: Guest
Posts: n/a
A friend had some of the 1157 LED replacement bulbs so we tried them in my car. They were without question, "the dimmest taillights I have ever seem." About half as bright as the factory bulbs. Please let me clarify,"You should only run these bulbs if really want your car to be rearended." You can't see them well at all. If you are wondering why, you should read my prior posts.
Old 29th-August-2005, 09:47 PM   #14
mychevyii20
Nova(s): 1966 More Door 350hp 350
Many of the replacement LED bulbs, often in fine print, say for "offroad use only". I use the LED array from Technostalgia. Good bright, and very bright brake lights. Also eliminated all the bulb, ground problems.
Old 3rd-October-2005, 08:58 PM   #15
SuperNova69
Nova(s): 69 Nova
Just a bit of info for all the 3rd gen-ers out there. I emailed Technostalgia and asked if they had a universal type of conversion or if the Camaro kit would work and they said they were working on a kit for 3rd gen Novas as we speak, and it should be ready by January 1st, 2006. Sorry it took so long to post this, not having internet really blows.
Matt
Matt
Tail Panel 67Chevelleguy Body and Interior 7 19th-June-2006 11:24 PM
Light problems lz07rp Electrical 7 17th-June-2006 08:35 PM
Backup light conversion sterho Electrical 3 20th-May-2006 10:52 AM
tail light that you might like 63droptop Ebay, etc. Discussion 5 13th-May-2006 04:21 PM
Tail Panel Replacement Nova73Hatchback Body and Interior 10 19th-April-2006 07:37 PM
