What causes Glowing headers? - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > Best of Drivetrain & Performance
Old 20th-August-2005, 10:10 PM   #1
BRETTZER
(OP)
BRETTZER's Avatar
Nova(s): 1967 Super Sport
We broke the cam in as per Comps directions, and everything seems good. About an hour of run time now on it. Oil was changed right after break in. The question I have is the headers are getting glowing hot. Will this take care of itself after more run time, or is something wrong ? Temp is only 185
1967 SUPER SPORT
383 STROKER
MUNCIE 4 SP
SCOTT'S SUPER SLAM air ride IFS
HEIDTS SUPER RIDE IRS W/ 9" & air ride
Old 20th-August-2005, 10:12 PM   #2
69NovaSS
69NovaSS's Avatar
Wasnt this talked about before in the context of using coated headers during break in?...I believe something in those threads touched on glowing headers.....BTW what is your timing set at?
NPHNP
Do you recognize this vin:114279W458662
Old 23rd-August-2005, 10:35 PM   #3
BRETTZER
(OP)
BRETTZER's Avatar
well It seems it was the timing to retarded. I thought we had it set at 6 degrees, but it was apparently a few less than that. We bumped it up to 10 and it idles nice in park about 750 Starts better too. The header glow is also no longer. The outside temp is down quite a bit today also, and car is running 20 degrees cooler. Although my shifter cable melted from all the exhaust heat
Is this too much advance now ?
1967 SUPER SPORT
383 STROKER
MUNCIE 4 SP
Old 23rd-August-2005, 10:38 PM   #4
DriveWFO
DriveWFO's Avatar
Nova(s): 74 Nova...R.I.P
Not sure what heads you are running, but the SBC typically likes 36-38 degrees of TOTAL timing (static + mechanical advance). If you are running some type of fast-burn heads (like the Vortecs for instance), you'll want less total timing - around 32-34 degrees.
Don't worship false idles
Old 23rd-August-2005, 10:46 PM   #5
BRETTZER
(OP)
BRETTZER's Avatar
202 camel humps reworked
383 stroker
11:1 Keith Blacks
Comp Cams 280H
Harland Sharp 1.6 Rollers
Thanks for the info. I am just learning in his dept
1967 SUPER SPORT
383 STROKER
MUNCIE 4 SP
Old 24th-August-2005, 11:20 AM   #6
undercvrSS
undercvrSS's Avatar
Nova(s): 67 SS 67 Sedan project
Is it running too lean. That will also make the headers glow.
Old 24th-August-2005, 11:22 PM   #7
nova656567
Nova(s): 65 coupe 65 SS 67 Wagon
Sounds like it was from the timing being retarded. That's a pretty common problem. We have done it purposely to help car make it through emissions. If your not getting any ping, and the motor turns over good, it's not too much advance.
Old 24th-August-2005, 11:48 PM   #8
NovatoriusRex
NovatoriusRex's Avatar
Nova(s): 67 Chevy II Nova Hardtop
I had Goble prove his timing theory when he helped me fired up my car for the first time. No glow was to be seen with the initial timing set to 12* BTDC.
-Brent
I want a new duck. One that won't steal my beer... - Weird Al
Old 25th-August-2005, 10:29 PM   #9
BRETTZER
(OP)
BRETTZER's Avatar
Thanks to all you guys. It's not my Nova, but it has the motor built for the Nova in it now to run until it gets done.
my 67 Camaro (with my 67 Nova motor transplanted in it)
1967 SUPER SPORT
383 STROKER
MUNCIE 4 SP
Old 25th-August-2005, 10:45 PM   #10
Paul Wright
Paul Wright's Avatar
What's Mike's theory?
Originally Posted by Paul Wright
Building a small, high rpm engine
with the perfect bore, stroke and rod ratio is very impressive...
like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar.
Cubic inches is like Indiana Jones with a cheap pistol.
Old 25th-August-2005, 10:54 PM   #11
DriveWFO
DriveWFO's Avatar
Goble's Theory of Timing Relativity
Old 25th-August-2005, 11:39 PM   #12
NovatoriusRex
Pretty much.
From previous discussions around here I got the impression that he strongly believes that most of the glowing header reports are a result of improper timing during break-in.
My experiences in this area just add fuel to support his little fire.
-Brent
Old 24th-September-2005, 10:42 PM   #13
johnnymo63
johnnymo63's Avatar
Nova(s): 63 ProStreet sedan
Headers glowing red hot
I have a problem. My block-hugger headers (chrome) are getting red hot when I'm idling after a couple of minutes after start up. Does this happen with chrome normally? I adjusted the valves last week and am running a 4bbl Edelbrock carb, hyd. cam & aluminum heads with RC12YC plugs on my freshly rebuilt 350. Am I lean? Timing too high? Too low of an octane (89)? Engine was getting hot when I took it out for its break-in run. Any help would be appreciated.
63 NOVA / 94 Corvette
Old 24th-September-2005, 11:16 PM   #14
1965proSTREET
1965proSTREET's Avatar
Nova(s): 1965 Sedan (sold)
Garage
My headers were glowing red because it was running too lean, i bought a carb spacer, and eventually got a taller intake which has elimated the problem. also had to do some carb adjusting.
Tony
PROJECT WHITE NOISE
Old 24th-September-2005, 11:40 PM   #15
BRETTZER
(OP)
BRETTZER's Avatar
I have just recently had the same issue on break in of my 383. The headers would glow and the operating temp was high. We bumped the timing up and header glow went away, temp came down, and actually oil pressure was a little better. I was told it was either timing or too lean, and too far retarded timing was the culprit. I would check timing first.
1967 SUPER SPORT
383 STROKER
MUNCIE 4 SP
White Headers Scooter Drivetrain & Performance 16 27th-April-2012 05:56 AM
Headers Suggestions!! motone82 Drivetrain & Performance 9 21st-June-2010 10:27 PM
FlowTech Headers 72novaNigel Drivetrain & Performance 12 14th-June-2006 04:21 AM
Are headers really that bad? NovaNate Drivetrain & Performance 32 6th-April-2006 06:44 PM
Headers Won,t Clear A/c GOTWHEELS Drivetrain & Performance 6 1st-April-2006 08:36 PM
