1969 lt1 350 - Chevy Nova Forum
Old 29th-May-2013, 09:24 PM   #1
Steves 70SS
(OP)
Steves 70SS's Avatar
Nova(s): 1970 SS Crate ZZ430 Munci
1969 lt1 350
Came across a guy that has a 1969 LT1 350 that he would like to sell. He told me it was in his 1969 camaro SS he had way back when. He did put different heads on it at sometime but not any good. I don't need a motor but is this something worth buying and putting away?? Not sure if this was worth any money. He wants $100 for the complete motor. Hasn't run in years also.
casting # were 3956618
Any thoughts?
Steves 70SS
Old 29th-May-2013, 11:20 PM   #2
73ss406
73ss406's Avatar
Nova(s): 73 nova ss 1 owner
id buy it for 100 bucks if the block isnt cracked or rusted too bad,steel crank maybe? a good block is easily worth 100.00
alright, hold tight, im a highway star...
support breast cancer awareness...help save second base.
Old 29th-May-2013, 11:23 PM   #3
ken125
Nova(s): 1962 2dr post
Garage
if indead its a true lt1 it is well worth it....
Sent from AutoGuide.com App
Old 29th-May-2013, 11:27 PM   #4
1quik69
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
x2. If the short block is original it should have some good parts in it.
Old 29th-May-2013, 11:32 PM   #5
ccvair
ccvair's Avatar
Nova(s): 1970 ss 396 1974 ss 350 1
Garage
If I am right LT/1 came out in 70. with that said,that could be a L-48 300 hp with 10.25-1 compression. Check for the suffix code on the block on the front passenger side. that should give you the info you need. LT/1 engine were 4 bolt main, steel crank floating rist pins ect.basically a bigger 302 as far as the hardware goes.
Old 30th-May-2013, 07:09 AM   #6
wht73
wht73's Avatar
Nova(s): 73 nova custom
X2 what he said! My uncle has 3 '70 vetts with them in it and m22 rock crusher 4spd's.
It should have what was mentioned above in side and 11.5:1 domed pistons.
3515#,all steel,406ci N/A,10.6/122.38, short shifting, N/A
Old 30th-May-2013, 08:42 AM   #7
ChevyII MD
ChevyII MD's Avatar
Nova(s): 63 Hardtop
I'd say the same thing, 1970 for the first LT-1...
Yes check the suffix code of the block like ccvair said to confirm or deny...
My first year of college, I became friends with with a guy that had a 70 Nova with an LT-t in it...
I remember him always complaining about buying premium gas
for it at about 60-70 cents a gallon! (1976)
But one he stepped on it... that thing was fast..., peg leg 3:08 gears and smoke any time he wanted!
Good times!
Mark
"It's amazing that we know what we know, that we don't know"
Mick Weiand, 21st Century Philosopher
Old 30th-May-2013, 08:49 AM   #8
photoman
photoman's Avatar
Wow. Any decent, non-damaged 350 SBC is worth $100 in my book.
1969 Nova
350
TH400
8.5" 10 Bolt
Old 30th-May-2013, 08:54 AM   #9
CNC BLOCKS
CNC BLOCKS's Avatar
That block should have the 2482 4 bolt center caps.
Old 30th-May-2013, 09:36 AM   #10
63-Deuce
63-Deuce's Avatar
Title: Nova Newbie
Nova(s): 63' Coupe
Something that is very helpful and for some reason is not general knowledge, all 4-bolt main blocks always have a Casting Number that ends in "101" (the casting number on top of the bell housing pad drivers side) This bit of information puts to bed all the closed motor claims. One quick glance at the Number that is typically always visible will tell. The only alternate consideration, this is true for all 4-Bolt Mains, even truck motors 331's and tall blocks so pay attention to the prefix numbers also or you could end up with a pig.
Old 30th-May-2013, 11:49 AM   #11
bowtie0069
bowtie0069's Avatar
Nova(s): 69
Can't say I've ever seen ANY Chevy block ending in "101" Maybe you meant "010"?
But, even that is no guarantee of having 4 bolt mains. As far as I know, there is absolutely no way to know without looking.
69 Nova 410" small block-Driven to track
6.39 E.T./105 MPH--6.11/112.89 w/N2O
Old 30th-May-2013, 11:58 AM   #12
mfeller
mfeller's Avatar
Nova(s): '63 2 dr Sedan '69 2 dr
When I came home from Nam in Nov 70 I bought my first Nova, a 69 SS that had an LT-1 transplant. That's the engine that replaced the 302 in Z28s. I'd say for $100 you can't go wrong even if it is just the 300 HP engine. If it is really an LT1 - BONUS!!
Mark
63 Chevy II 2dr Sedan/TKO600
69 Nova Black on Black
14 Impala Black on Black
~ the Sedan Society ~
Old 30th-May-2013, 11:58 AM   #13
bowtie0069
bowtie0069's Avatar
Nova(s): 69
That casting number could be a 2 or 4 bolt block from 68-79 302/327/350
A 1970 should have a CTK or CTU suffix on the pad of an 010 block. No 69 LT1's that I know about.
Old 30th-May-2013, 12:01 PM   #14
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
What he said. ^^^^
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 30th-May-2013, 01:44 PM   #15
ken125
Garage
i have a 010 block in my 73 c10 but it is 2 bolt mains........
1969 427 bbc Prostreet513 Originality 7 4th-February-2009 06:51 PM
1969 Ss 350 HockleySS Member Introductions 21 8th-October-2008 07:42 AM
1969 SS 350 i.d. sYc_12B Originality 13 9th-August-2007 04:43 PM
1969 zz 502 rollerrat Drivetrain & Performance 17 28th-June-2007 01:13 AM
