flush brake system with alcahol ? - Chevy Nova Forum
Old 25th-February-2013, 03:07 PM   #1
lil green nova
Title: Nova Newbie
Nova(s): 1971 2nd owner
will flushing your brake system with alcahol hurt any of your rubber componets?thought is to break open bleeders on wheel cylinders,pump out all the brake fluid I can.then fill system with alc. bleed it out & repeat till system bleeds only alc.then change out master cyl. and start bleeding through sinthetic brake fluid till all the alc. is out.should pull all the moisture out of system and clean very well.any thoughts on this willy coyote idea please chimm in.thanks
Old 25th-February-2013, 03:44 PM   #2
nvscott5
nvscott5's Avatar
Nova(s): 1962 Chevy II 300 V8 327
Re: flush brake system with alcahol ?
You should elevate the rear. Then suck all the fluid put of the master cylinder. And fill the master cylinder with your desired fluid. Just keep bleeding until its all new stuff and you be just fine. This is the standard way of manually 'flushing' the brakes for newer type of fluid. It will most likely take a couple bottles at least to get it real good for certain.
Sent from my ADR6350 using AutoGuide.Com Free App
Old 25th-February-2013, 04:22 PM   #3
surfdog
surfdog's Avatar
Nova(s): 64wagon, 67wagon
I flushed my system with alcohol this weekend
John
Old 25th-February-2013, 05:00 PM   #4
Branded
Branded's Avatar
Nova(s): 67 Nova SS Marina blue
Heard Dat......
Flush Mount Glass System Pragmatist Body and Interior 16 11th-November-2011 07:21 PM
Brake system testcase Steering, Suspension, and Chassis 2 26th-March-2010 08:32 AM
Brake system testcase Drag Racing Forum 0 24th-March-2010 09:48 PM
Brake System Questions Pop-A-Top Steering, Suspension, and Chassis 3 16th-February-2009 07:42 AM
