Keep 10 bolt or go with a 9" - Chevy Nova Forum
Old 17th-February-2013, 05:20 PM   #1
408 Nova SS
Title: Nova Newbie
Nova(s): 76 Nova SS Coupe 408 SBC
I need lower gears in the stock rearend (2.41 now) and am trying to decide whether to just put my posi and lower gears in the 10 bolt and some leaf spring wrap bars, or go ahead and switch to a narrowed 9" and whole different suspension. What do you guys recommend?
408 sbc 500-550 HP 700r4 tranny. This is a street rod that may see the track occasionally.
Can anyone give me recommendations for manufacturer's, suspension options, size of tire I can fit now vs narrowed without tubbing, etc.?
Any advice is appreciated this is my first build and I always like to learn from other's wisdom.
Thanks!
Old 17th-February-2013, 05:36 PM   #2
Gr8apmech
Gr8apmech's Avatar
Nova(s): 62 2 door HT
Two Options:
A: Street/Strip - 10 bolt, build it up with good parts, will hold up for awhile. I've heard lots of guys running these for quite some time - especially on the street. Focus is on the street with this setup.
B: Strip/Street - 9", build it up with good parts.
Stronger, can handle future mods better and you can get one with axels and housing cut to fit your car...then go out and buy a 3rd member and set up your gears (or have someone else do it). Focus is on the strip with this setup. I'm going with this setup myself, but my direction is strip car that drives to/from the track - little street - not a daily driver but man I'm building a Thumper of an engine!
http://www.quickperformance.com/GM-X...y-II_c_41.html
62 RED 2D Hard Top
283 4bbl, TH350
Garage
Old 17th-February-2013, 06:07 PM   #3
RPM Nova
RPM Nova's Avatar
Nova(s): 71 Nova 350ci/TH350 2dr
Which 10-bolt?
The 8.5 is pretty strong and I would just keep that and improve it if the car is going to be mostly street with occasional track use, even at the power levels you have suggested.
If it's one of the other 10-bolts, then I would probably get something different for the suggested power level.
If it was going to be purely a race car, then might as well get the 9". But in that case I would also take a pass on the 700R4 and get a TH400/Powerglide.
1971 Nova SS | 1998 Camaro Z28 | 2002 Camaro Z28
Old 17th-February-2013, 06:56 PM   #4
The Big Al
The Big Al's Avatar
Title: Supporting Vendor
Nova(s): 68ss,70ss
It all boils down to your budget.
Do not underestimate the big 10 8.5 rear (should have been stock in your 74)
They are very close to the 12 bolt, pinion bearing are the same, carrier is .300 smaller and the carrier bearing are a little smaller, they are strong rear ends.
FYI
AL
“The bitterness of poor quality & Service remains long after the sweetness of low price is forgotten”
Old 18th-February-2013, 07:06 PM   #5
FrankyM
Nova(s): 66 coupe
10 bolt
Cliff Ruggles from Cliff's performance runs an 11.30 in his 74 GTO Ventura with a 3.42:1 8.5 10 bolt. DD with lots of runs.
FrankyM
Old 18th-February-2013, 08:24 PM   #6
sonnyt
sonnyt's Avatar
Nova(s): 73 nova custom
Re: Keep 10 bolt or go with a 9"
I agree w Big Al. If you are using the 10 8.5 along with 700r4, You should be able to get a way with it for a while.
I have the same set up, w/3.73. It's a nice strong combo. But I'm only throwing out lil over 350hp.
Are planning to throw a shift kit in the 700?
Sent from my GT-P3113 using AutoGuide.Com Free App
Old 18th-February-2013, 09:07 PM   #7
levisnteeshirt
Nova(s): shopping for the 6th one
you can get some good parts for 'em now ,, 33 spline axles ,, etc etc
Old 18th-February-2013, 11:02 PM   #8
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): 1965 Chevy II 2 door Seda
An 8.5 built up can handle some pretty good power, heck a 8.2 can hold 500+ hp on our cars.
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
Old 19th-February-2013, 04:41 PM   #9
oreowizard98
oreowizard98's Avatar
Nova(s): '67 II
Miles
Intersting that you mention the 8.2. That's what I have in my car stock. We added homemade limited slip by welding the spider gears at 12 and 6 o'clock. Just a temp solution and I dont launch the car without locking it first. I'm wanting to upgrade the rear end now. I'm considering a 8.5 and somewhere near a 3.55 gear. Thoughts?
'67 Deuce stroked and maybe soon to be blown.
327 "Bolt On" Build, Your Ideas Appreciated acr Drivetrain & Performance 15 4th-February-2012 09:55 AM
Wheels / Tires "4" bolt pattern ideas. taters Steering, Suspension, and Chassis 0 14th-March-2010 06:17 PM
10 bolt-12 bolt "conversion" trick72nova Ebay, etc. Discussion 1 20th-March-2008 09:16 PM
7/16"Bolt CPP upper cont. arm to a 1/2"? T. Jerman Steering, Suspension, and Chassis 6 24th-October-2006 10:34 PM
