Hey guys, my name is Mitch. I will apologize now to anyone who doesn't like to read because this is going to be a long first post.
I currently have a 2002 camaro Z28 with a cam and some other goodies that runs high 11's and is show car clean with 65k miles. Pic here:
However I am thinking of trading this cherry camaro for a nova. I've always wanted one since my father had one when I was a kid, and a guy my father works with has this 1972 Nova 350/350 numbers matching california car with 13,000 original miles in almost restored condition. Here is the spec sheet.
Body
1972 Chevy Nova California car
13000 actual miles
All factory glass
All factory body panels under primer
Floor pans have been replaced due to leaking front and rear windows
New poly body mounts
Repair front panel under front glass, 90% complete
Repair rear panel under rear glass, 90% complete
New door pin kit installed
Interior
Factory interior no upgrades
Recovered rear bench seat
Recovered front bench seat
Chassis
All new steering linkage
Resealed power steering box
New ball joints
New front sway bar, upgrade
Longer front wheel studs
New poly bushings in A-frames
2 inch lowering springs
2 inch drop spindles
New front and rear Bilstein shocks
Cooling System
New water pump
Newer radiator
Rear axle
10 bolt rear end
Posi track
3:73 gear ratio
New poly bushings in rear springs
New u-joints
Exhaust
2.5 inch flow master mufflers
2.5 inch aluminized dual exhaust
Engine
Numbers matching engine
350 cubic inch engine
Standard bore
Engine completely rebuilt
Heads rebuilt by Schmidt Automotive
Competition Cam
New oil pump
Elderbrock air gap intake
New engine mounts
New ring gear
New MSD wires
New speedy sleeve on damper
Transmission
Numbers matching transmission
New front seal
New rear seal
New modulator
New filter
New transmission trick shift fluid
New transmission mount
Accessories
Factory air conditioning
Factory power steering
After market power brakes upgrade
After market front disc brakes upgrade
Extra Parts
New Goodmark 2 inch steel cowl hood
New dash pad
New Goodmark front bumper
New Goodmark rear bumper
New rear deck board
New complete body seal kit
New matching valve cover, timing cover and air cleaner
Here are the only pics I have so far.
A couple of these pics are a little out of date because the engine has been completed and is running and driving. It's not driveable currently just due to the glass and interior not being in.
I am also in contact with the guy selling this:
http://bloomington.craigslist.org/cto/3508444432.html
Now here is where I am at between the two. The primer car is going to be a lot better and worth a bit more with a little work and a little money, but the red car is done right now and doesn't NEED that much. The bad thing is it was built by someone I don't know, isn't original in any sense of the word, has a saginaw trans behind that stroker which won't last long, has manual drum brakes, no AC, broken heat, and cheap drag suspension, so it won't ride, stop, or steer as well as the primer car...but it will GO a little better.
I'm pretty set on the primer car for a lot of reasons, but would like to hear everyone's opinions on it. I'm on a limited budget(college) but labor is a non-issue. I am hoping to get a couple thousand in cash my way trading my Z28 for the primer nova(haven't seen the car in person or negotiated yet though) which can at least get it a decent paint job, I can install the glass and interior and it will be on the road.
Let me know what you think guys. I'll put a poll in the thread.
