Will a 76 tilt steering fit a 72....... - Chevy Nova Forum
Old 24th-January-2013, 09:11 AM   #1
1972novafever
1972novafever's Avatar
Nova(s): 72 rally nova 355/4speed
Like the title says will a 76 tilt steering colume floor shift fit a 72 floor shift...
Thanks in advance
Tom
(Never look down on ANYBODY unless you're helping them up)
Old 24th-January-2013, 05:35 PM   #2
PCPete
PCPete's Avatar
Nova(s): '72 Nova 383/TH350
Somewhat foggy memory says not really. From what I've seen in salvage yards, it looks close until you really look at it. The fooler for me was the dash. I thought I could make one fit in my 72, but as I began to really look at it I found a bunch of subtle differences.
Along about then, Federal law about steering column compression caused a change for the 4th gens. The column goes through the firewall at a shallower angle then has a u-joint before heading to the steering box. Take a look in some salvage yards around you if you can find a 4th gen. I think the steering lugs on the spindles went from behind the axle on 3rd gens to in front on the 4th's
Pete
'lo ocifer, it's run what ya brung. Got a beer?
Old 24th-January-2013, 09:58 PM   #3
1972novafever
Thank you sir for the reply i will keep looking for one that fits Thanks again.
Tom
Old 25th-January-2013, 02:19 PM   #4
Hemi Nova
Hemi Nova's Avatar
Nova(s): 69 Low Pro
From what i can remember you can but it won't be a direct bolt in. I used a column from a 3rd gen Firebird in my car. It's been a long time but from what i can vaguely remember. The end of the 2 columns are different. The later one uses a splined shaft but you can buy a U-joint that will adapt the 2 together. There also is a minor difference in the turn signal switch, you have to swap a couple wires.
Old 25th-January-2013, 04:23 PM   #5
ovrdrive
ovrdrive's Avatar
Nova(s): 1971 V-8 A/C car
Look into the early S-10's. NNN did a write-up some time ago where someone added the S-10 column to a 3rd Gen....
1971 2-dr Nova A/C car 355 200-4R
Old 26th-January-2013, 06:26 AM   #6
1972novafever
Thanks guys for the info but i think ill keep looking for the right one i was looking at that because it was close and cheap but it sounds more like a headache....Thanks again...........
Tom
Old 26th-January-2013, 04:13 PM   #7
PCPete
PCPete's Avatar
GM had more common parts than most people think. The trick is to get some part numbers or cross reference chart to work from. That S-10 column may, if fact be the same column with a different firewall plate that just slides off. You might look at a site like Ididit to see what column fits what, then you can reverse that information to what will fit yours.
Early Camaro/Firebird may be a good candidate and don't forget the sister cars, Omega and Skylark.
Pete
Old 20th-October-2013, 12:49 AM   #8
72ss427
Nova(s): 73 Nova Drag Car
No, but I made a 74 Monte Carlo tilt fit my 72. I think there are some pictures in my Photobucket showing how I did it. I shortened the MC column and welded the flange onto the shaft for the Nova gear box. Worked great.
http://s411.photobucket.com/user/72s...?sort=2&page=1
Old 21st-October-2013, 01:38 AM   #9
sshrop
sshrop's Avatar
Nova(s): 73 Nova, LQ4, T-56 Pro Tu
Garage
I am using a 75 camaro tilt work in my 73. Ididit has this part 'http://www.summitracing.com/parts/id...4331/overview/.
I have yet to install it to verify it works but all my research says it should.
steering tilt no fit 77-427-5sp 4th Generation Nova's 9 15th-June-2016 07:44 AM
tilt steering column bcnova400 1st & 2nd Generation Chevy II/Nova's 0 3rd-August-2009 06:48 PM
Tilt Steering 406Boy Originality 12 27th-July-2009 03:30 PM
tilt steering voodoochikin04 Steering, Suspension, and Chassis 4 20th-April-2007 04:33 PM
tilt steering column,any others harleynovaman Steering, Suspension, and Chassis 10 24th-February-2007 07:18 PM
