Need help with 69 panel alignments - Chevy Nova Forum
Old 20th-January-2013, 07:53 PM   #1
publicenemy
publicenemy's Avatar
Title: Nova Newbie
Nova(s): 1969 Nova project
Does anyone have any suggestions how I can adjust this out. I have a lot of time in trying to get everything to line up, (20 plus hours). My main issue is the lower body line at the door and fender, both sides. And the fender to hood at the front. Like the fender is twisted. Attachment 24381Attachment 24382Attachment 24383
Sent from my iPhone using AutoGuide.com App
Joel Johnson
69 Nova LS 408 EFI
4L80E Mini Tubbed
Old 20th-January-2013, 10:23 PM   #2
TechNova
TechNova's Avatar
Title: Moderator
Nova(s): 73, (2) 69's
I'm not seeing what you are talking about from the pics.
Forget your front end for now. Align the door to the 1/4 first. Get it perfect then move on to the rear of the fenders, they have to match the doors. Then align the hood and adjust the front of the fenders and rad. support as needed to get the front of the hood aligned.
You cannot adjust the 1/4 or rocker so you have to make the door fit them.
Once you do, you cannot adjust the door again or it will not fit the 1/4.
America has become a country full of people looking to be offended.
Old 20th-January-2013, 11:04 PM   #3
publicenemy
Title: Nova Newbie
I have the doors to quarter and rocker at generous 3/16". If you look at the lower body line, door to fender, the fender is a good 1/2" high, but the top lines up good. Both sides are consistent, so I am sure it is something I am doing wrong. I am thinking, maybe, the fender needs to go forward and down at the top, which will lower the entire fender, but I can't get 1/2" out of it.
Old 20th-January-2013, 11:26 PM   #4
Branded
Branded's Avatar
Nova(s): 67 Nova SS Marina blue
Are the fenders repops or GM. The repop fenders have been known to have issues with body lines aligning and mounting points being wrong.
Old 21st-January-2013, 12:29 AM   #5
publicenemy
Title: Nova Newbie
Repop, along with most of the body.
Joel Johnson
69 Nova LS 408 EFI
4L80E Mini Tubbed
Old 21st-January-2013, 12:42 AM   #6
PCPete
PCPete's Avatar
Nova(s): '72 Nova 383/TH350
Like Tech said, get the door to match as best you can, then you may have to "convince" the fender to match. If your door to fender gap is even all the way, you may have to work on the firewall mounts a bit to get the half inch. I'm assuming you have the subframe torqued and the core support also torqued into position. My fenders flopped around quite a bit until the inners were all bolted up and seemed twisted.
Pete
'lo ocifer, it's run what ya brung. Got a beer?
Old 21st-January-2013, 12:49 AM   #7
dealer-deuce
dealer-deuce's Avatar
Nova(s): A FAKE 63 NOVA
Sheet metal
You need alot of patience!! you may need to elongate mouting holes do not
be afraid to tweak things a liitle bit here and there just keep working at it you
will get it right. those 3rd. gens were not great on fit from the factory.
that means you can do better than the factory!!
Old 21st-January-2013, 11:50 AM   #8
publicenemy
Title: Nova Newbie
I could not get the fender to rocker fit even close with the sub frame bolted tight. I actually have jack stands on my frame connectors just behind the subframe, and the firewall body mounts loosened up to get the subframe to droop. This is the only way I have been able to fit the fender and rocker correctly.
I have elongated the fender hole behind to door already, which also helped.
Joel Johnson
69 Nova LS 408 EFI
4L80E Mini Tubbed
Old 21st-January-2013, 02:00 PM   #9
Branded
Branded's Avatar
I had the same issues with a 69 Camaro I built a couple years ago using reproduction fenders. Had to cut and repostion the fender brackets just to get the fenders to come close to fitting. Never did get them to fit like GM fenders would have. Not beating on repops but if I was to do it over I would have found NOS fenders or good used GM fenders.
Old 21st-January-2013, 02:03 PM   #10
PCPete
PCPete's Avatar
You may have to get a bit more aggressive with that body mount on the fender, and it may mean cutting a bit out of it and welding back together. The mount at the top of the firewall may be the one holding the fender up at this point.
Pete
Old 26th-February-2013, 10:13 PM   #11
publicenemy
Title: Nova Newbie
Here is my current problem
Here is my current problem. The fender looks twisted. Look at the hood to fender gap closely.
Any ideas?
Old 27th-February-2013, 12:51 AM   #12
Custom Jim
Custom Jim's Avatar
Title: Moderator
Nova(s): 1968,1973,1974,1977(Sold)
Garage
I have a feeling that there may be problems with the subframe mounts.
On my 74 I had the frame in wrong due to incorrect bushings. I had too thin of ones on the firewall base while I had the correct thickness ones on the radiator core support and under the seat. When it was like this the door to fender gap was good at the top but wide at the bottom by the end of the rocker sill. The reason this happened was the frame with the wrong thickness firewall bushings pitched the radiator support up higher and since the fender sits on top of the radiator support it pulls the bottom back edge of the fender by the rocker sill away. If I would have left the wrong thickness firewall base bushings in place and pried the bottom back edge of the fender rearward to close the gap it would affect other things like what you have now with a poor uneven fender to hood gap.
Hindsight I think this is the problem I had on my 73 years ago and it looks very much like the problems you have now.
Alignments Pro19Nova67 Steering, Suspension, and Chassis 14 3rd-July-2009 07:44 PM
Frame dimensions and alignments walkerjay Steering, Suspension, and Chassis 6 17th-April-2009 10:46 PM
Wheel Size and Alignments... grooves12 Steering, Suspension, and Chassis 6 14th-June-2007 02:03 AM
Wheel alignments RallyNova350 Steering, Suspension, and Chassis 4 11th-May-2007 11:23 AM
