what is a good way to run a nitrous fuel line? - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 15th-January-2013, 07:45 PM   #1
Sanbravo
Title: Nova Newbie
Nova(s): 1966 nova. It used to be
I have A-1000 fuel pump filter and 13204 return style regulator with – 10 line. I would like to shoot 150 shot with my nitrous express hitman plus. Can I run just the one fuel pump, what's the best way?
Old 15th-January-2013, 08:06 PM   #2
Real McCoy
Real McCoy's Avatar
Title: Moderator
You make no mention of your combo and how much power you have. I run an A2000 on my 582 single carb car and it feeds the carb and my 200 hp plate nitrous system just fine. I have no idea if an A1000 can or not. My pump will supply a gallon of fuel to the carb in 13 seconds if you time it. That would be the type test I would run to decide what you can expect. You do not want to lean out so be careful.
God Bless America, land that I love
2010 PRTA 5.30 Index Champion
Old 15th-January-2013, 08:15 PM   #3
Sanbravo
Title: Nova Newbie
sbc 406 a strong 575 HP with a power glide and trans break, also going to run E85 fuel, not sure what gear is at this point.
Old 16th-January-2013, 12:52 AM   #4
Pete 63
Pete 63's Avatar
Nova(s): 1963 station wagon
An A1000 with a 13204 regulator will easily support your horsepower level and additional nitrous use on E85. The easiest way to plumb the fuel solenoid in your particular application would be to install a "T" fitting in the fuel regulator gauge port and route a 6AN hose to the fuel solenoid inlet.
If you want to be able to individually tune fuel pressure to the carb and to the fuel solenoid then you will have to install a "Y" fitting in the fuel pressure line, a second return-style fuel pressure regulator, and another return line to the fuel tank. This regulator could then be plumbed only to the solenoid in order to allow additional tuning of the nitrous system.
Old 16th-January-2013, 02:43 PM   #5
Sanbravo
Title: Nova Newbie
thanks, I'm a little concerned about putting the T on the carburetor side of the regulator to go to the nitrous if I'm understanding you correctly.
Old 16th-January-2013, 05:49 PM   #6
Pete 63
Pete 63's Avatar
I was referring to installing a fitting in the gauge port of the regulator. You actually could "T" off one of the carb fittings as well. You have to use regulated pressure to the fuel solenoid. Your pump provides sufficient pressure and volume that you will have no issues with fuel pressure drop or volume when the fuel solenoid opens.
Old 16th-January-2013, 06:04 PM   #7
sYcNova
sYcNova's Avatar
Nova(s): 71 Rally
The pretty blue flash will only work once.
˙uʍop ʇıs oƃ oʇ pǝǝu ʎllɐǝɹ noʎ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
O=====O
Old 16th-January-2013, 06:42 PM   #8
Sanbravo
Title: Nova Newbie
thanks Pete 63, I hadn't thought about running off the gauge port. Won't there be quite a bit of fluctuation in the reading of the pressure gauge and will that be enough fuel for the nitrous express?
Old 16th-January-2013, 09:38 PM   #9
crazyspeed
crazyspeed's Avatar
Nova(s): 1972 Chev Nova
Get a 3 port regulator??
Tire Burning 6.77 @ 112mph
Old 17th-January-2013, 11:05 AM   #10
Pete 63
Pete 63's Avatar
The A1000 is a high-pressure fuel pump. You may observe a very, very minor and momentary drop in fuel pressure when the fuel solenoid first opens, but the drop should be less than 1-PSI, and will recover in about 1 - 2 tenths of a second.
The restriction in the system is the fuel jet. The orifice in the gauge port is much larger than the orifice in your fuel jet, so restriction to fuel flow is not going to be a concern.
Another alternative would be to remove the 13204 regulator and install a 13202 regulator. The 13202 features an inlet, return, (4) outlet ports, and a gauge port. You're accomplishing the same thing any which way you plumb the solenoid.
Old 17th-January-2013, 01:13 PM   #11
Sanbravo
Title: Nova Newbie
I will be doing mostly bracket racing what do you think the fuel pressure drop will affect my consistency on time if I use the regulator I have or would it be better in my case to go ahead and spend the money for the 13202 regulator
Old 17th-January-2013, 02:39 PM   #12
Pete 63
Pete 63's Avatar
As long as the pump and regulator are functioning correctly the pressure drop is so insignificant and recovers so quickly that is has zero impact on performance or consistency.
Old 17th-January-2013, 04:25 PM   #13
Sanbravo
Title: Nova Newbie
thanks for the information I think I'll give it a try. Do you race?
Old 17th-January-2013, 07:54 PM   #14
crazyspeed
crazyspeed's Avatar
Talking
That's what I said!
Old 17th-January-2013, 11:27 PM   #15
Pete 63
Pete 63's Avatar
Been about a year since I've been down a drag strip, and now ours are getting shut down. I've ran through enough bottles to get a fairly decent handle on the basics of nitrous operating theory and tuning. I've ran a variety of systems on a variety of engines and have been very fortunate to have not hurt any parts due to nitrous use. I'm certainly no expert, and learn something new all the time.
Braided Stainless Nitrous Line Length 72novaproject Drivetrain & Performance 5 28th-April-2012 01:02 AM
nitrous fuel line size? fossilrunner Drag Racing Forum 11 15th-December-2009 11:15 AM
new starter and nitrous line TY70SS Drag Racing Forum 11 27th-July-2008 12:24 PM
What is 5/16 fuel line good up to? Dawg Drivetrain & Performance 26 5th-June-2008 08:00 AM
fuel line for nitrous SSavon69 Drivetrain & Performance 5 29th-October-2006 06:05 PM
