Column confusion - Chevy Nova Forum
Old 4th-January-2013, 04:50 PM   #1
Dotrix
Title: Nova Newbie
Nova(s): 1971 Nova
Question Column confusion
What a mess I have... So here goes... I have a 1971 Nova that has a automatic trans. with a column shiftier. I bought a 75-76 column shiftier with tilt and floor shiftier,but, the 75-76 column is longer (steering box must have been on the front side cross frame) so how can I make this work. I have both columns mostly apart but I can't figure how to get the shifting collar off of either one.
Yours truly lost
Old 4th-January-2013, 08:50 PM   #2
Ray_McAvoy
Ray_McAvoy's Avatar
Nova(s): 1974 & 1977
Yes, the 75-79 Novas did have the steering box mounted up at the front of the subframe ahead of the engine crossmember. I think the column itself is about the same length as the 69-74 columns but 75-79's have an added intermediate shaft to join the column to the box.
I haven't personally done this, but I remember reading a post here on Steves about someone who put a 75-79 column in a 69-74 Nova. I believe they simply removed the coupler flange from the lower end of the intermediate shaft and re-installed it directly onto the lower splined end of the column. Not sure what they used to secure it in place though.
Old 6th-January-2013, 11:36 AM   #3
Dotrix
Title: Nova Newbie
Nova(s): 1971 Nova
Thats what I did and worked great, but, The key now won't turn back to accessories.
Old 6th-January-2013, 01:34 PM   #4
PCPete
PCPete's Avatar
Nova(s): '72 Nova 383/TH350
Tooth off
There is a slider operated by key rotation that is connected to a rod that goes to the ignition switch on the column. If you have that slider a tooth off it limits the rotation of the key.....not that it happened to me.
Thing is you have to take so much apart to get to it, then you'll probably have to readjust the ignition switch.
Pete
http://s1230.photobucket.com/albums/ee490/pcpete1/
'lo ocifer, it's run what ya brung. Got a beer?
Bellhousing confusion JonNova1973 Drivetrain & Performance 4 10th-August-2012 07:16 AM
Solenoid confusion? SpeedWhore Electrical 15 12th-July-2011 04:06 PM
Flywheel Confusion kayneh Drivetrain & Performance 19 7th-December-2009 10:39 PM
Electrical confusion! Richardlss Electrical 1 25th-July-2008 11:18 PM
Cowl tag confusion tsimpson Originality 4 16th-March-2008 04:08 PM
