Opinion on this cam - Chevy Nova Forum
Old 1st-January-2013, 10:53 PM   #1
cranker
cranker's Avatar
Nova(s): 67 canso sport deluxe
Opinion on this cam
Comp 08-433-8
Adv dur
Int. ex
288. 294
Duration# .050
236. 242
Lift
520. 540
Lobe sep. 110
Would this be a good cam for a 383 with 195 Afrs air gap. 3000 stall 700 r4 3.55 gear? Thanks
Old 1st-January-2013, 11:14 PM   #2
boucher-racing
boucher-racing's Avatar
Title: Nova Newbie
cam selection
I cannot give you any advice about if that cam will be any good or not but here is what I used.
Have you called a Lunati, Comp, Isky's tech lines? They were extremely helpful for me. I got a douche sometimes, but I'd just call back or another company until I talked to someone that was helpful.
Specs:
1964 Chevy II. SBC, Alum. heads, Hyd Flat Cam (276/284, .474/.474 lift, 110 lsa), 1.5rr, BG 750, air gap intake, flowmasters, Richmond 5 spd, Halibrand 5 spokes, static drop
What it sounds like:
http://youtu.be/l3NOohR9LPk
Old 1st-January-2013, 11:16 PM   #3
cranker
cranker's Avatar
From what I hear lunati has been bought by comp....but I will give comp a call and see what they say,I was just curious if someone on here had run this cam
Old 1st-January-2013, 11:19 PM   #4
Glenn
Glenn's Avatar
Nova(s): 1966 Chevy II Wagon
I highly recommend Bullet Cams: http://www.bulletcams.com/
You will get the right camshaft, period!
"Real Race Cars Have Tailgates"
Old 1st-January-2013, 11:24 PM   #5
cranker
cranker's Avatar
I know there is a bunch of option but found a deal on the one I have listed so jus trying to get some info
Old 1st-January-2013, 11:27 PM   #6
nova7chevy4
nova7chevy4's Avatar
Nova(s): 1973 copperhead color wit
My cam is really close to that almost identical to the T It's a roller cam from comp cams.The spec's are with 1.5 rockers and with the 1.6 rockers it changes the lift to 576. and this cam is in my 383 and i love it great power all ranges
Old 1st-January-2013, 11:30 PM   #7
cranker
cranker's Avatar
So how does it work for you?
Old 1st-January-2013, 11:43 PM   #8
nova7chevy4
Love it!! 523HP i got 30x12.50-15 Et streets on and can spin threw all gears! I'm running Brodix (alum heads) 2.02 0.30 over 6inch rods 10.1 compression. i have a 3.89 gear but am going to go to 4.11
Old 1st-January-2013, 11:49 PM   #9
cranker
cranker's Avatar
Nice piece... Is that a stroker?
Old 1st-January-2013, 11:50 PM   #10
nova7chevy4
yes! 383 all forged built for spray! I havent yet but thinking this summer! Best of all on pump gas!
Old 2nd-January-2013, 12:01 AM   #11
cranker
cranker's Avatar
Is that a front sump pan on it?
Old 2nd-January-2013, 12:05 AM   #12
the tree man
Nova(s): 1965 chevy2
I have the one step up from this (XR294) in my 408,195's w/1.6 rockers and air gap.I really like it.Nice lopey idle and lights up big time at about 2500 and pulls hard to 6000+.I can gurgle around town at 1500 comfortably also without any stumbling or loading up.With your 383 I would expect similar results from the slightly smaller profile to match the auto and gears.I actually have an XR300 sitting on the shelf but with the 1.6 rockers it's beyond the max lift for 195's.I'm itching to try it though.I think it would be great with my M22 and 4.11's.If biggers better,too much is just right!
Old 2nd-January-2013, 12:14 AM   #13
nova7chevy4
No! just stock style (alum)6qt.
Old 2nd-January-2013, 12:19 AM   #14
Sooner1
Sooner1's Avatar
Originally Posted by cranker View Post
Comp 08-433-8
Adv dur
Int. ex
288. 294
Duration# .050
236. 242
Lift
520. 540
Lobe sep. 110
Set up in my 66 is similar but a
Little less rowdy:
383 with rhs torquer 170cc heads, voodoo 227/233 with .489/504 lift,
2500k converter in 700r4 with 3.55 posi.
Yes I think that would be a good cam. Idle better on a 112lsa but sound better on 110. You might rip off 12.0's et or better with good working suspension.
Do you already have the 3k converter?
With 27" tire I'm cruising 60mph about 2200rpms.
I guess you are pretty similar?!
'66 Hard Top
'67 Hard Top
'72 Nova
Old 2nd-January-2013, 12:40 AM   #15
cranker
cranker's Avatar
Yes I have the converter already...although its not a high quality one
your opinion... solrac7d2 Wheels and Tires 2 20th-December-2011 09:39 PM
need your opinion duggravs 1st & 2nd Generation Chevy II/Nova's 21 2nd-November-2009 01:06 AM
