Rag joint size issues???!!! - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 4th Generation Nova's
Old 13th-December-2012, 04:01 PM   #1
Rude88
Rude88's Avatar
Title: Nova Newbie
Nova(s): 1977 Chevy Nova Coupe
Unhappy Rag joint size issues???!!!
For my 77 im running a new steering pump and my old rag joint wont fit onto the shaft, its a rebuilt steering pump and the previous own said it was from a quick steer camero, does anyone know the size or what too look for in the junkyard? I looked em up n i cant really afford to take a shot in the dark buy a new one Plus there friggin expensive!!!!!!!!
Old 13th-December-2012, 04:07 PM   #2
77-427-5sp
77-427-5sp's Avatar
Nova(s): 1977 nova bb 427 5sp tko
1976 is size the split i think it is a easy fix first you need to tell use why it does note fit is the rag joint to big or to small then we can tell what you need
my guess is that the rag joint is to big in that case a rag joint from a pre 76 nova or camoro should work fine
77 fake ss 5 sp tko 427 big block hyd roller cam 3.73 9 inch 4 wheel disc brakes
Old 13th-December-2012, 04:14 PM   #3
Rude88
Rude88's Avatar
Title: Nova Newbie
Actually its a hair too small from the original ill try n post a pic for u too see
Old 13th-December-2012, 04:17 PM   #4
77-427-5sp
77-427-5sp's Avatar
you do know that the only fit one way if you are a tooth off they do not slide on ?
Old 13th-December-2012, 05:26 PM   #5
Rude88
Rude88's Avatar
Title: Nova Newbie
No when i try to line up thr teeth n put it in its too small, even after taking off the bolt that clamps the joint to the shaft is too small.
Old 13th-December-2012, 05:31 PM   #6
Rude88
Rude88's Avatar
Title: Nova Newbie
Sorry that sounds confusing from the steering colum to rag joint its fine but from the rag joint to the steering shaft its too small
Old 13th-December-2012, 07:08 PM   #7
Philip
Philip's Avatar
Title: Moderator
Nova(s): 1977
77 and newer uses a 3/4" diameter splined shaft and the 76 and older used a 13/16" splined shaft.
77 Nova
"WORRYING does not take away tomorrow's TROUBLES;
it takes away today's PEACE."
Old 13th-December-2012, 10:02 PM   #8
Rude88
Rude88's Avatar
Title: Nova Newbie
Is there any way to tell what year the steering box is by the #s on it?
Old 13th-December-2012, 10:13 PM   #9
Philip
Philip's Avatar
Title: Moderator
Nova(s): 1977
Not really, but if the coupler you have now does not fit, then you need the larger size. Only 2 to choose from.
If you have some 12 point sockets, see which one will fit over the splined shaft. That should indicate if it is 3/4" or 13/16".
77 Nova
Old 13th-December-2012, 10:16 PM   #10
Jim383
Jim383's Avatar
Nova(s): I help with my nephew's63 sport coupe
Rock Auto sells rag joints pretty cheap,the rubber in them deteriorates.
Old 13th-December-2012, 11:23 PM   #11
Rude88
Rude88's Avatar
Title: Nova Newbie
Ok cool thanks alot guys big help
screen size issues... HELP!!! the FLYER StevesNovaSite.com News and Help 7 15th-February-2011 08:30 PM
Mcgaughy's 62-67 2" drop spindles - ball joint size question Notch Johnson Steering, Suspension, and Chassis 17 18th-January-2009 10:55 AM
not factory spindle and having ball joint issues yumarattler Steering, Suspension, and Chassis 2 7th-December-2008 04:02 AM
12 bolt u.joint size novanut64 Drivetrain & Performance 0 18th-March-2007 01:27 PM
