1st Gen Hydraulic Clutch Master Cylinder??? - Chevy Nova Forum
Old 9th-December-2012, 11:06 PM   #1
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Question 1st Gen Hydraulic Clutch Master Cylinder???
What are you guys running for a Hydraulic clutch master cylinder on your 1st gen cars? How does it mount to the firewall? Any bracing required? Anyone have a photo or two of their installation? Thanks in advance. I a
Ronm thinking of pulling my 700R4 and putting in a manual transmission.
My 62:
Old 9th-December-2012, 11:21 PM   #2
joeseeno
joeseeno's Avatar
Nova(s): 64 400 series wagon 63 n
Garage
I'm running a factory 98 to 02 f body clutch set up works great. Got a bracket off eBay to mount master and modified my clutch pedal to work.
Old 10th-December-2012, 12:54 AM   #3
David&Melissa_h
Does that setup work with power brakes?
Old 10th-December-2012, 01:19 AM   #4
62LS6
62LS6's Avatar
Nova(s): 1962 Nova Coupe
I am working on the same thing myself. From my understanding Wilwood 260-3376 should work. Alot of people that have done this swap from what I can tell have used stock pedals that they have adapted to work. I think that is the route I am going to go myself.
Old 10th-December-2012, 02:05 AM   #5
Lil'Deuce II
Lil'Deuce II's Avatar
Nova(s): 63 SS
For which transmission would this be for?
Old 10th-December-2012, 09:38 AM   #6
joeseeno
joeseeno's Avatar
Garage
Yes it will
Old 10th-December-2012, 10:42 AM   #7
David&Melissa_h
Yes it will
Cool I talked to the guy selling them many times and he never tried it on a power brake car so I never bought one to try out...
I used a wilwood master and once I got the unit setup so it pushes the rod straight in it has worked flawless for two years now. before that I had the unit mounted on the firewall at a angle and it was eating the seals.
Making the connection to the pedal was easy
Old 10th-December-2012, 04:11 PM   #8
62civa
(OP)
62civa's Avatar
Nova(s): 62 Coupe
Hi Dave,
Are you using the Wilwood master #260-3376 listed inthe above post?
Ron
My 62:
No Brake or Clutch master cylinder jayjay4540 Steering, Suspension, and Chassis 1 18th-July-2011 01:08 PM
Hydraulic clutch master pls help Len66 1st & 2nd Generation Chevy II/Nova's 8 20th-January-2010 08:52 PM
Hydraulic master cylinder help David&Melissa_h Drivetrain & Performance 5 19th-May-2007 12:59 PM
hydro clutch master cylinder bkhotrod Drivetrain & Performance 15 16th-May-2007 01:32 AM
TKO 500 or 600 clutch master cylinder jh99 Drivetrain & Performance 1 24th-January-2007 11:20 AM
