DommerEOD - My take on someone else take - 1969, Nova - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Car Profiles
Old 8th-December-2012, 09:34 PM   #1
DommerEOD
(OP)
DommerEOD's Avatar
Title: Nova Newbie
Nova(s): '69 Nova, '13 Boss, JERRV
DommerEOD - My take on someone elses take - 1969, Nova
DommerEOD - Dominic
So this will be my build page..
My story: I'm a 24y/o from southern CA. I enlisted in the Army back in mid-2009. Became an EOD Tech a tad over a year later, and was in Afghanistan by the beginning of 2011. 13 months and enough stories for a lifetime later i came home. Reenlisted, bought a new daily driver and changed duty stations from Germany to Colorado. Still miss the Nurburgring!
I've been addicted to cars since before i could talk. I generally love all kinds of cars from trucks to imports.. except there are three things i can't stand in the automotive world and those are FWD, I4's and V6's. I started out with aircooled VW's when i was a bit younger. Graduated up to a Toyota FJ Cruiser back in early 2006. Spent thousands and thousands and thousands on it, changing it's purpose from crawler, to expedition rig, to race truck. After spending $11k in just the front suspension last year, i said **** this.. I must move on! So while trying to sell it, i found someone that wanted to sell or trade their Nova. American Muscle.. Something I've wanted all my life just never had that opportunity. I traded off my FJ like it meant nothing to me.
Somewhere in there I bought a 2011 Subaru Impreza STI, then i arrived here:
It's been de-polished
Year: 1969
Model: Nova
Engine:
383 Stroker:
1969 Original SS 350 Block - 4 bolt main (3970010 cast numbers)
- block had been resin filled for strength
Eagle - 4340 Forged 3.75" crank (this is an actual 383 specific crank, not a 400 crank milled down to a 383)
-Knife Edged and Lightened
Eagle H-Beam 4340 Forged Rods (6" rods)
JE 4340 Forged Pancake Pistons (full floating pins and nitrous reliefs) (11:1 Compression = Runs just fine on 91 octane pump gas, but loves 103 octane)
- Pistons were Ceramic Coated for Nitrous but nitours has never been run on it.
64cc Edelbrock Performer RPM Heads (Aluminum)
-Fully ported and port matched to the intake and exhaust
-Valves Sizes increased from 2.02/1.60 to 2.08/1.60
-Rev Kit / K-Motion Springs
-Comp Full Roller Rockers
Holley Strip Dominator Intake Manifold
-Port-matched to heads
Holley 830cfm Mechanical Double Pumper Carb (re-jetted with jet kit included)
-fuel pump is mounted right next to the Fuel Cell and is fully plummed with dash 8 AN fittings and dash 8 steel braded fuel lines.
All Transmission lines are done the same way as well
Iski Cam - Solid Roller Cam - .602/.602 lift 300/300 duration with 1.6' rockers = .642 final lift
Ignition:
MSD 6AL Box with changeable rev limiter chips
MSD Distributor
Griffin 2 - 1 inch core radiator
Black Magic Electric Fan
Remote Trans Cooler with onboard electric fan
Entire assembly has been blueprinted, matched and balanced to each corresponding part.
Body/Exterior: Cowl, 4-pin hood. Fairly straight body.. A good detail is in need.
Front End: Stock w/disc brakes (stock?)
Transmission:
TH350 with a Full Forward Manual Valve Body
10" 4000 Stall with Anti-Balloon Plates
Rear End:
12-Bolt GM, 4.11 Motive gears, TrueTrac diff built by Sutton Performance in La Habra, CA
Exhaust:
Working on some XR1 mufflers
Wheels/Tires:
I believe they are SS wheels.. If you can identify them post up! Will be upgrading current tires to MT E/T streets.
Interior:
10 point cage (NHRA Approved)
5 Point Racing Seatbelts (NHRA Approved)
2 Jaz Bucket Seats w/ covers
Autometer Gauge Cluster for OEM instrument cluster replacement with 5 Autometer gauges and 3 heavy duty switches for fans and fuel pump
Guages: oil pressure, water temp, trans temp, fuel level - Big Gauges: Speed and RPM
15gal Jaz Fuel Cell
Battery in the rear w/ an aluminum enclosed battery housing
Rear Aluminum Firewall which is carpeted and insulated on the inside (NHRA Approved)
On/Off cuttoff switch (located over the rear bumper - passenger side) (NHRA Approved)
Electrical: Painless wiring kit.
Sound system: Music? racecar.
Additional Comments:
I'm not going to lie.. I don't know much about Nova's in general. I'm here to learn, and utilize the mass of wisdom for my future endeavors with this car.
Some things i plan on doing:
Borla XR1 Mufflers
New seats
Not to impressed with the fuel cell.. might be changing that out.
Swap out tires for MT E/T Streets.
AFR 227 heads
What I'm currently doing:
Sutton Performance is building me a GM 12-Bolt w/ 4.11 gears and a TrueTrac differential. Previously had a GM 8.2 10-bolt w/4.56 gears and a mini-spool. Had a pretty gnarly axle failure and the diff itself was sloppy and needed a serious rebuild, so i did what i do best and upgraded now instead of later... Because i plan on more power.
Past rides and the new DD:
Bought this baby Dec 15th.. Yeah, I'm not very loyal when it comes to brands.
Old 9th-December-2012, 01:33 AM   #2
novajoe1973
novajoe1973's Avatar
Nova(s): 73 nova 383 th350 3.73
Garage
Thats a very clean nova you got there. I like the sleeper look . Have you had a chance to take it to the track? If so, how fast?
383 solid roller/th350/3.73
10.85 @ 122mph on pump gas through the mufflers
Old 9th-December-2012, 01:34 PM   #3
DommerEOD
(OP)
DommerEOD's Avatar
Title: Nova Newbie
Thanks!
I have not had it to the track yet. The previous owner was running low-mid 11's with 3.73's and a 3500 stall. When I got it, it was setup with 4.56 gears and a 4000 stall. Currently I'm putting in 4.11s with the 4000 stall. Hopefully I'll have a chance to get it to the track over Christmas when I'm back in socal for leave.
With that, no it's not here in colorado with me Car is in socal under the watch of my dad. I live in the barracks, so no garage + winter weather.. yeah, no, it'll stay in the good weather
Also it's not stated above, but the engine was dyno'd at 633hp/577tq (@ the fly) by Superior Automotive of Anaheim on 103 octane. Wheel HP is up in the air right now.. With this new rear end going in I'm sure there will be a greater loss in power but it will be made up! Stay tuned for a Dyno run in late December
Updated first post with some more photos!
Old 9th-December-2012, 07:57 PM   #4
orange_roc
orange_roc's Avatar
Nova(s): 1967 Nova SS
nice ride!!!
12.06@112mph
NA 406 TH350 3.08
Old 9th-December-2012, 08:03 PM   #5
70oneNova
70oneNova's Avatar
How did you de polish your chrome? Looks good
1971 Nova
My Build Thread:
Old 9th-December-2012, 09:16 PM   #6
65Nova-SoCal
65Nova-SoCal's Avatar
Nova(s): 65 SS Coupe 62 Vert -pro
Nice looking ride - oh and thanks for your service!
Sent from my iPhone using AutoGuide.com App
Why wait..
Old 9th-December-2012, 09:21 PM   #7
DommerEOD
(OP)
DommerEOD's Avatar
Title: Nova Newbie
Thanks all.
PFM
Old 9th-December-2012, 09:55 PM   #8
sYcNova
sYcNova's Avatar
Nova(s): 72 SS BBC, 71 Rally(sold)
Garage
˙uʍop ʇıs oƃ oʇ pǝǝu ʎllɐǝɹ noʎ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
O=====O
Old 12th-December-2012, 04:59 AM   #9
asteeler4life
asteeler4life's Avatar
Nova(s): 1962 'VERT 1966 SS
AWESOME RIDE MAN,
62
INLINE 6 GROUP
66 NOVA SS COUPE INC.
Old 12th-December-2012, 07:25 AM   #10
carcrazy615
carcrazy615's Avatar
Nova(s): 63ss convertible
Nice looking ride. Bet it's a lot of fun to drive.
Old 12th-December-2012, 07:44 AM   #11
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
I like how clean it looks!
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 12th-December-2012, 08:01 AM   #12
onecarnut
onecarnut's Avatar
Nova(s): 1968 Chevy II
Glad you are back safely in the USA and the fact you have joined a great website for Nova owners.
Great looking car. Looking forward for more updates.
Gone but not forgotten
Old 2nd-January-2013, 09:22 PM   #13
DommerEOD
(OP)
DommerEOD's Avatar
Title: Nova Newbie
12 bolt is in!
Next time I'm back in SoCal, The front end will be getting revamped. It's sloppy and old. Not going to spend thousands on it, just going to freshen it up. Also, Door and window rubber. It all sucks. Hard and cracking or just missing. Nothing to difficult.
Regarding the worry about the tight looking fuel lines; It has solid motor mounts so i'm not to concerned with it.
Pic time:
Old 3rd-January-2013, 12:35 AM   #14
65Nova-SoCal
Very nice looking ride...
Why wait..
Old 29th-April-2013, 12:56 PM   #15
DommerEOD
(OP)
DommerEOD's Avatar
Title: Nova Newbie
^Thanks.
Only update.. it had a really nice paint correction done early March.
[/URL]
Just got another Nova-1969 RobCab14 3rd Generation Chevy II/Nova's 18 4th-August-2011 12:17 AM
Looking for my 1969 nova Kerry Hunter South Eastern US 0 11th-June-2010 08:20 AM
1969 nova ss racer115 Body and Interior 2 14th-February-2007 09:29 PM
1969 SS Nova Michael396 Ebay, etc. Discussion 2 20th-May-2006 11:29 AM
