Has my car been lowered? - Chevy Nova Forum
Old 5th-December-2012, 04:24 PM   #1
bs46488
Nova(s): 1970 Nova
Newbie here....
not the best shot of my new project car, but I was curious if you were able to tell if the car has been lowered at all?
The PO has done some changes to the front, but not able to tell what/how much. It has a BB, so he only said "Has BB springs". The brakes were also converted to factory disk brakes with new spindles, calipers, etc.
Last edited by bs46488; 5th-December-2012 at 04:25 PM. Reason: Forgot to include picture
Old 5th-December-2012, 04:36 PM   #2
friskiersaucer
friskiersaucer's Avatar
Nova(s): 1964 Nova SS
Picture is kindve hard to tell, looks stock height though, depending on how old those springs are they might have sagged a little. I have BB springs on my SB now and when i set the car down the springs compress a ton..
Old 5th-December-2012, 04:43 PM   #3
bs46488
Nova(s): 1970 Nova
From what I can see of the springs, they are compressed a ton as the vehicle sits.
I'm looking to lower the vehicle just a little up front and was considering doing Hotchkis springs to drop the front. I'm also looking to stiffen things up a little for performance reasons.
Old 5th-December-2012, 04:45 PM   #4
63-Deuce
63-Deuce's Avatar
Title: Nova Newbie
Nova(s): 63' Coupe
Looks like a standard stance to me compared to my 69'.
Hard to tell from the picture but I would venture to say the rear springs are sagging.
Old 5th-December-2012, 04:55 PM   #5
friskiersaucer
Thumbs up
Insted of going with a drop spring, I suggest going with a stock height spring and drop spindles, The car will handle better and have more room before bottoming out. I went through the same thing with my nova and I had to return my drop springs from CPP because the car bottomed out easy w/ big block springs in a small block car, also when I jacked the car up the springs were soo short that they would come dislodged! I returned them and went with stock height and drop spindle and the ride was a lot better but wasn't as stiff as I would have liked, I then changed out my Monroe sensatracs and went with some KYB's and now it handles like a dream and never bottoms out and is very low!!
Old 5th-December-2012, 04:57 PM   #6
Jeffs63NovaSS
Jeffs63NovaSS's Avatar
Nova(s): 1963 Chevy II 400 Series
-- why go low...? e v e r y b o d y goes low.....
Old 5th-December-2012, 05:03 PM   #7
friskiersaucer
low looks good..
Wheel gap is like a vagina.. the more fingers the worse it is
Old 5th-December-2012, 05:15 PM   #8
bs46488
Nova(s): 1970 Nova
I need to do shocks all the way around. The front only has 1 shock (drivers side). No shocks in the rear.
The rear leafs are new 5 leaf units. You can still see the shipping tags on them. No shock mounts on the rear, so I have to address that. I was thinking about relocating the shocks inward.
I was going to originally do drop spindles, but most of my reading on this site said spindles are junk and go with spring.
Old 5th-December-2012, 05:28 PM   #9
friskiersaucer
I believe in drop spindles...
If you got the money, Definetly invest in some coilover shocks! since you dont have mounting brackets for shocks in the back, it may be easier to just go with a coil over setup.
Old 5th-December-2012, 05:31 PM   #10
RatNova71
RatNova71's Avatar
Nova(s): 71 72
I say get some paint on that fender while you still have a fender!!! LOL
Andy
1971 Hot Rod & 1972 Granny Getter
http://s1075.photobucket.com/profile...aintshop/index
Old 5th-December-2012, 05:34 PM   #11
bs46488
Nova(s): 1970 Nova
the trunk and half of the roof match that fender!
I have a date with a DA and some primer all weekend. Its mainly just surface rust.
So your a fan of drop spindles....any brand in particular?
Old 5th-December-2012, 05:40 PM   #12
RatNova71
RatNova71's Avatar
Nova(s): 71 72
I cut one coil on my 72. Cost zero $. Dropped it 2 - 2 1/2 inches... handles fine for what I use it for.
Andy
Old 5th-December-2012, 05:46 PM   #13
friskiersaucer
That always works if your not interested in spending a ton of money! But since you have warn out springs I suggest that if you do this you don't go cheap on the shocks or it will bottom out a ton! (KYB's)
CPP makes a really good drop spindle that wont break the bank!
BTW, when your done sanding that fender make sure you use Epoxy primer!!! If you use any other type of primer than it wont stick very well since it is bare metal!!! Epoxy will seal the metal and prevent rust! I use a brand of primer called "Custom Shop" there prices are great for the quality that you get!
http://www.tcpglobal.com/Customshop/kspepoprime.aspx
How much has this car been lowered? novasrule Steering, Suspension, and Chassis 5 11th-February-2011 11:47 PM
lowered 69 thatguycruz Steering, Suspension, and Chassis 5 18th-April-2010 02:48 AM
Lowered? Super_Nova 3rd Generation Chevy II/Nova's 37 5th-January-2009 11:26 PM
Lowered Springs or Lowered Spindles? Fredsgarage Steering, Suspension, and Chassis 2 10th-May-2006 01:10 PM
