Street single turbo SBC - Chevy Nova Forum
Old 1st-December-2012, 05:54 PM   #1
Fredsgarage
Fredsgarage's Avatar
Nova(s): 65 Coupe 63 Mo-Door
I am about to finish my 355/TH350 conversion of my 65.
I'm just dreaming right now as I am looking at all the EBAY single turbo kits for my 9.5 compression stock mild V8 .
Has anyone thrown one of these on a stock carb motor with success?
Bring it on!
Sent from my iPhone using AutoGuide.com App
Scraps 65 HT- 355 4bolt/ TH350-BOP trans
MO-Door 63-4dr 400 Series inline/glide
Nor Cal Novas NPHNP
Old 1st-December-2012, 08:14 PM   #2
pinstripe_chuck
pinstripe_chuck's Avatar
Nova(s): 72 in progress
9.5:1 is a little high for forced induction i think.
Old 1st-December-2012, 10:21 PM   #3
Melonhead
Melonhead's Avatar
Nova(s): 62 wagon
plenty of stuff to do, to just "throw" one on there and use e85
Old 2nd-December-2012, 02:52 AM   #4
lktna
lktna's Avatar
Nova(s): 1971 Nova SS- sold 62 Ch
Bring it on!
First thing is you will need a blow threw carb. 9.5 compression will be fine for your motor just with a mild stock sb keep the boost down to about 10 psi and you will be fine. You are better off doing some reading and no wasting you money on the Ebay junk kits and build what you need yourself. Buy a good turbo, headers, ect. You can find all of the pieces.
Old 2nd-December-2012, 08:33 AM   #5
MarkW
http://www.carcraft.com/techarticles..._block_engine/
Old 2nd-December-2012, 11:30 AM   #6
Fredsgarage
I totally realize you just don't bolt on and get 500hp. But if I leave my 355 4 bolt main motor totally stock and add parts necessary, blow thru carb, turbo header and all the Turbo pieces could I expect
500hp?
Nor Cal Novas NPHNP
Old 2nd-December-2012, 12:48 PM   #7
lktna
lktna's Avatar
500hp?
It still depends on a lot of things. What kind of heads? Do you have flow numbers? What cam? Specs on the cam? Without knowing that you could go with a 76mm turbo, T4 flange and you would be close to the 500 mark with tuning.
Single turbo 6.0 jtheaceman LSx Forum 5 18th-May-2012 12:41 AM
1st Gen single turbo JRichard Drivetrain & Performance 0 6th-April-2012 03:32 PM
Show me TWINS, or A SINGLE TURBO setup in a third gen slownova73 3rd Generation Chevy II/Nova's 4 14th-September-2009 10:16 PM
Single turbo sbc on a 1st gen stock front end? 1964novass Drivetrain & Performance 8 22nd-July-2009 02:45 PM
Single vs Dual Plane for High Perf Street Motor leejoy Drivetrain & Performance 26 26th-October-2007 05:00 PM
