Need to see some cowl hoods - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Show and Shine
Old 28th-November-2012, 05:32 PM   #1
edge04
First, on the 66's. might need to go from a flat hood to a cowl. Don't want more than 2 inches prefer 1. Any pics out there you can post.
If I put a straight edge across the fenders, is the bottom of the edge really the clearance or do the flat hoods have a bit of a curve? Would test myself but my hood is in a different location then the body.
Is this 1 inch? Is this a factory hood or aftermarket?
http://i283.photobucket.com/albums/k...roject/1-1.jpg
Old 28th-November-2012, 06:10 PM   #2
tbills66
tbills66's Avatar
Nova(s): 66 SS
My steel cowl hood looks like the one in the picture. The only difference between the flat hood and my cowl hood is a round cutout under the hood for an air cleaner. Not sure if that is what you are asking.
Old 28th-November-2012, 06:13 PM   #3
edge04
So is that a 1 inch? Do you know how much extra clearance you get with that?
Old 28th-November-2012, 06:14 PM   #4
3DTim
3DTim's Avatar
Nova(s): 66 ProStreet-74 GTO
That is an aftermarket 2" cowl hood.
PROSTREET FRATERNITY
Old 28th-November-2012, 06:21 PM   #5
tbills66
tbills66's Avatar
Nova(s): 66 SS
It is a 2 inch. The only room that is gained is right above the carb. I run a single plane intake with a spacer and a 14" air cleaner with no problems. It also fit under my stock hood though. The bottom of the hood follows the curvature of the cowl.
Old 28th-November-2012, 06:33 PM   #6
edge04
Well I am looking for about 11.5-12 inches of clearance. Looks like there is about 11 using a straight edge across the fenders.
Old 28th-November-2012, 07:26 PM   #7
SKTurner
SKTurner's Avatar
Title: Nova Newbie
Nova(s): 1966 SS
is the hood in the pic a steel or fiberglass? Who's car is that? i am looking for hood also. Like the wheels to.
Old 28th-November-2012, 08:29 PM   #8
Pandora's Box
Pandora's Box's Avatar
Nova(s): 67 Nova Wagon 408"/700R4
2 inch 'glass hood.
On the first day God created Hot Rods and Harleys-then came the Demo Derby to get rid of all the rest!
Old 28th-November-2012, 08:39 PM   #9
edge04
^^does that give you an actual 2 inches of additional clearance? Is it all the way down the hood or just a round cut out like mentioned above?
Should have mentioned there is an LS in it.
Old 28th-November-2012, 08:50 PM   #10
Pandora's Box
Never really checked! I just knew I needed it.
However, I'm running a 2" spacer and an air cleaner and still have enough room to close the hood. Obviously!
Old 29th-November-2012, 06:28 AM   #11
fastone27
fastone27's Avatar
Nova(s): 67 Nova
I just put my Goodmark 2" cowl hood on last week! Love it!
Old 29th-November-2012, 07:36 AM   #12
edge04
So looks like all the cowls just have the round cut out for the air cleaner and the rest is as flat as a stock flat hood? Can someone measure the depth and radius of that cut out? Thanks.
Old 29th-November-2012, 10:43 AM   #13
fastone27
fastone27's Avatar
Nova(s): 67 Nova
Just went out and measured mine.. The opening is 15-3/4in dia. and its 2-3/8 from base of support to the top of he raised cowl hood section Hope this helps!
Old 29th-November-2012, 03:25 PM   #14
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova -383
Mines a different gen Nova, but I like those 2" cowl hoods and that is what I run on mine.
72 Nova -383, AFR 195s, Lunati #60113, 11.70s, next pass will be an 11.50
Old 30th-November-2012, 08:45 AM   #15
edge04
the glassmark is only $430 that's cheap! What's a factory flat hood worth. Be nice to find someone to trade.
Cowl Hoods tubbed73 Body and Interior 12 20th-February-2011 01:59 AM
Cowl Hoods TomM Body and Interior 35 16th-September-2009 09:55 PM
Cowl Hoods 77Concours 4th Generation Nova's 39 11th-June-2009 02:08 AM
cowl hoods boosted75 4th Generation Nova's 15 12th-February-2008 08:40 PM
pic of 73 cowl hoods? onephatz28 3rd Generation Chevy II/Nova's 5 11th-February-2007 07:57 PM
