what 10 bolt rear end has these dimensions - Chevy Nova Forum
Old 25th-November-2012, 07:12 PM   #1
darricks77nova
darricks77nova's Avatar
Nova(s): 1977 nova base
found the box for the rear axle oil seal the on the guy had put in was an SKF 538565 the inside diameter is 1.399 and an out side diameter of 1.964 and width of 15/64 now the reason im asking this is because i have tried to find this seal at local auto parts stores with no luck yet the housing looks to be an 8.5 housing but can not find any numbers on the rear end or axle tubes that is why i am hoping this might help me please any help would be greatfull
Old 25th-November-2012, 07:34 PM   #2
Bubba OEM
Bubba OEM's Avatar
Nova(s): 71 Nova
Maybe this will help.
http://www.novaresource.org/axle.htm
Album
Old 26th-November-2012, 05:37 PM   #3
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): To be determined...
If it's an 8.5 housing the axle seal should be an 8660S. The O.D. is 2.303", I.D. is 1.315" without distorting the seal lip, and .460" thick. This is measuring a brand new national seal off my shelf.
Hope that helps
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 26th-November-2012, 06:15 PM   #4
JBimmolate
JBimmolate's Avatar
Title: Moderator
After thinking about it it sounds like the seal from a saver bearing (aka repair bearing) If this is the case those seals were not meant to be changed, those bearings are for temporary use until a replacement axle can be found.
Miles
Old 27th-November-2012, 12:04 AM   #5
darricks77nova
Ok so now what I need a new rear or something this is frustrating the only thing is if I could find the numbers on it
Old 27th-November-2012, 12:21 PM   #6
PCPete
PCPete's Avatar
Nova(s): '72 Nova 383/TH350
Wait....What?
If you are looking at the seals to determine the housing, that seems backward to me. Which seal are you talking about? From the sound of things it's an axle seal on a repair bearing. JB, if the bearing is pressed into the housing properly, why do you say they are temporary? I'm not challenging your knowledge, just trying to understand. Understand I'm looking at this as a c clip axle, so the bearing goes into the tube with a tight press fit. My understanding is they are to save the housing when a bearing has damaged the housing a bit by spinning or a bad removal. The bearings themselves are a bit longer than stock and properly installed should ride flat on the axle. As long as the axle surface is good, the setup should last a long time. However, if the bearing surface on the axle is galled, then it's a get me home.
Derrick, pictures are really important here. It may be a matter if replacing that bearing which can be a challenge to find, but a whole new housing with gears is another whole challenge. Let's have a look at some pictures.
Pete
'lo ocifer, it's run what ya brung. Got a beer?
Old 27th-November-2012, 01:05 PM   #7
JBimmolate
JBimmolate's Avatar
Title: Moderator
The repair bearings can temporarily fix 2 issues. One is a slightly damaged axle and 2 is a damaged housing end. They are a temporary fix because the bearing is narrower than factory and the seals tend to puke after about a year in most cases. Some of the better ones have an inner & outer seal but still the bearing is still inferior to the original style. They were designed to get you back on the road if you are where replacement parts may not be readily available.
Oh and if you can take a picture of the housing & housing end where the seal goes we may be able to wrap up this mystery for you.
Miles
Old 27th-November-2012, 01:12 PM   #8
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
8.2 housing takes a 1 1/8" socket on the pinion and the 8.5 takes a 1 1/4". Now after rebuilding my 8.5 with a Motive install kit(I believe) my 8.5 takes a 1 5/16" nut on the pinion shaft.
Like stated post a picture up and these guys will tell you real quick what you have.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 27th-November-2012, 08:55 PM   #9
darricks77nova
i will try been having problems getting pics up may have to up load video of it and yes i am puking gear oil at least on the passenger side i was going to replace the seal see if that fixes it but like i said before no numbers any where on this accept for a number sequence that i have put on here before think it was something like 1234 or something but yea i will try to get a video up better than most pics lol have to do it tomarrow tho it is dark and my only camera is my phone wish i had light lol
Old 28th-November-2012, 03:26 PM   #10
darricks77nova
here you go here is the ol nova and her rear end lol i know she dont look all that good but its my baby and i have to get her fixed up and yes my daily driver. pretty bad when my 35 year old car is more reliable than most the new cars lol
Old 1st-December-2012, 02:09 AM   #11
darricks77nova
Was that a good enough shot of it or not
Old 1st-December-2012, 01:20 PM   #12
PCPete
PCPete's Avatar
Pictures
Thanks for the video. What we are looking for is something a bit more specific; like of the seal that's the problem, the end of the axle tube from the end and side. What we are trying to understand is what the problem area looks like and the condition of all that. I know that means taking some things apart, but to understand what the issues and opportunities are.
Pete
Old 1st-December-2012, 01:40 PM   #13
darricks77nova
k il have to wait till i can get some jack fluid for the ol jack as it seems my rear end aint the only thing leaking il probably try to get a new housing something that i know what it is mine has no means of finding out what gear or anything is with out pulling it apart what gear oil will work best for it for i will put oil in it till i get a new one i really dont wanna trust something with a temp bearing in it i found a mustang cobra 2 rear end for sale around where i live now is this rear able to be used on the 77
Old 1st-December-2012, 02:16 PM   #14
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
Here you go
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 1st-December-2012, 02:19 PM   #15
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
Your's looks to be an 8.5 bolt.
Can see it at 2:05 in the video.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
74 rear axle/chassis dimensions? kimmer71 Steering, Suspension, and Chassis 1 7th-April-2011 11:26 AM
WHat are the dimensions of a 69 rear ss panel? a69nova Body and Interior 2 30th-March-2010 08:33 PM
10 and 12 bolt rear dimensions. shaggy Steering, Suspension, and Chassis 1 26th-May-2009 03:21 PM
rear end hub dimensions arndog Steering, Suspension, and Chassis 0 21st-February-2007 03:47 PM
Rear Axel Dimensions Bluesman Drivetrain & Performance 2 16th-July-2006 11:23 AM
