TH350 Jumping/Erratic Speedo - Chevy Nova Forum
Old 19th-November-2012, 07:43 PM   #1
65Coupe
65Coupe's Avatar
Nova(s): 1965 Chevy II Nova 400 HT
Question TH350 Jumping/Erratic Speedo
Hey guys, I'm trying to figure out a jumping speedo issue that's getting worse. I thought it was the mechanical cable, and the problem would go away when I recently switched to an electronic speedo with SN16 pulse generator. Still the same problem with the electronic speedo. I just inspected the gear that inserts in the tail shaft, both the teeth and inner square bore that turn the sensor are fine. Could there be an issue with the gear on the tail shaft slipping? I peaked in the trans at the gear isn't stripped or anything, so I'm not sure what's going on. Any advice? Thanks.
Old 19th-November-2012, 09:09 PM   #2
badbowtie557
badbowtie557's Avatar
Nova(s): 72
Have seen the drive gear in the trans slip. There is a metal retaining clip that holds the drive gear in place! The bad you have to remove the tailshaft housing pretty easy fix though!
Old 19th-November-2012, 09:18 PM   #3
LandShark
Nova(s): 1971
Can you spin up the pulse generator with a drill or something to see if it still jumps? Might help you eliminate some possibilities...
Good luck!
Old 19th-November-2012, 09:23 PM   #4
65Coupe
65Coupe's Avatar
I put a drill on the signal generator, speedo works just fine with no jumping around...so it's got to be in one of the gears. I noticed quite a bit of play in the gear shaft that fits into the bullet, almost like the bullet is worn. I'm wondering if this could allow the gear to disengage intermittently from the tail shaft gear. I'll try a new bullet and gear first before I go removing the tail shaft assembly. Hopefully the local trans shop carries the bullet?
Old 20th-November-2012, 06:56 PM   #5
65Coupe
65Coupe's Avatar
Quick update, installed a new steel bullet and plastic 22 tooth gear today and the speedo is reading better but is still jumping around +/- 5 mph. Only thing left to replace us the tail shaft gear.
Old 21st-November-2012, 09:54 AM   #6
72novaproject
72novaproject's Avatar
Nova(s): 72, 67
The clip coming loose is a very common problem. When you replace the drive gear get a new clip just in case.
To each problem...exists a solution...now think.
http://www.picturetrail.com/zdnova
Half built 383, MT Tires, and 20 lb of Mig wire.
Fuel level erratic!!! Nasty_74 Electrical 8 20th-November-2011 09:40 AM
how to figure out speedo gear in th350 Bucknaked Racing Drivetrain & Performance 7 17th-November-2011 04:52 PM
erratic idle ratboy74 Drivetrain & Performance 0 29th-January-2010 11:35 PM
th350 speedo siderman Drivetrain & Performance 4 13th-December-2008 02:02 PM
TH350 Speedo Gear balljoint Drivetrain & Performance 5 31st-August-2008 09:27 AM
