Clutch Pedal Vibration - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 4th Generation Nova's
Old 19th-November-2012, 04:38 PM   #1
kimrobertson
kimrobertson's Avatar
Nova(s): 1979 Pontiac Phoenix
My clutch pedal has an annoying vibration noise at certain RPM or speeds. It goes away if I hold my foot against the side of the pedal (but who wants to do that!) I converted from an automatic to a manual trans. When I got my pedals I got the shaft (long bolt), the pedals and the old pedal bushings which I replaced. Is there supposed to be a rubber bushing or something between the clutch pedal and the bracket that holds the pedals under the dash? I would think that could possibly eliminate the vibration noise. I've tried tightening the nut on the end of the pedal shaft but I don't think I should tighten it further.
Old 19th-November-2012, 05:12 PM   #2
Pragmatist
Pragmatist's Avatar
Changing a cars transmission from an automatic to a manual is similar to an organ transplant. Sometimes the treatment is unsuccessful and not all therapies work. Have you considered an automotive psychologist? Nervous tics, sometimes called vibrations are common and are tough to diagnose. Quite often in these situations a throw out bearing or an unbalanced pressure plate and or flywheel will create mild rejection interpreted as a nervous tic. It is always good advice to consult a licensed professional.
66 & 67 hard top, Work in progress
http://s116.photobucket.com/albums/o30/argrandawg/
Old 19th-November-2012, 05:35 PM   #3
kimrobertson
I did put in an inexpensive "made in China" clutch pressure plate & throwout bearing... that I got from Rock Auto. Perhaps that's creating an abnormal vibration. On the other hand there has to be some vibration with any machine. So, I was wondering if I got all the parts when I bought my clutch pedal & linkage. Maybe I'm missing a bushing or something that's supposed to dampen the vibration in the pedal. I'm not sure the Phoenix is willing yet to see a psychologist yet but sometimes I think it may be just what I need!
Old 19th-November-2012, 06:13 PM   #4
Pragmatist
Pragmatist's Avatar
Originally Posted by kimrobertson View Post
[SIZE="3"]I did put in an inexpensive "made in China" clutch pressure plate & throwout bearing...
Serious organ rejection right there!
I always balance my stuff but often folks getaway with just bolting parts in. Maybe others will chime in.
Old 19th-November-2012, 09:19 PM   #5
Philip
Philip's Avatar
Title: Moderator
Nova(s): 1977
There is a rubber bumper that the clutch pedal rests against. Should also have a return spring to hold it against the bumper.
click on link to see what it looks like, should be available locally. GM used the same one on lots of models.
http://www.classicindustries.com/sea...&y=1977&m=nova
Here is where it mounts
77 Nova
"WORRYING does not take away tomorrow's TROUBLES;
it takes away today's PEACE."
Old 19th-November-2012, 10:08 PM   #6
kimrobertson
Philip, I did get the bumper and also put in a retun spring that holds the pedal firmly against the bumper. That did help considerably from where it was back in the spring when I first got it on the road. But there is still an annoying vibration which seems like a back & forth movement rather than up and down movement. That's why I was wondering if maybe there is supposed to be a rubber spacer or gromet on the shaft to keep the pedal from vibrating against the bracket under the dash.
Old 20th-November-2012, 12:52 AM   #7
Philip
Philip's Avatar
Title: Moderator
Nova(s): 1977
I remembered that conversation, did not realize it was done. Getting old has its drawbacks, especially on memory but I do get a discount at Denny's and the movie theater
With disc wear the free play needs to be adjusted. Maybe the vibration is from the throw out bearing slightly touching the pressure plate.
77 Nova
Old 20th-November-2012, 07:25 AM   #8
kimrobertson
I'll experiment with the clutch adjustment and see if that is the issue. Otherwise perhaps it is as Pragmatist suspects...my cheap & possibly unbalanced parts. My flywheel is an OEM unit they put on 67-69 Camaros that I found in the trunk of a 75 Nova. There isn't any abnormal vibration from the engine itself...just when I drive at certain speeds--consistently vibrates at freeway speeds.
Old 20th-November-2012, 09:42 AM   #9
Knuckle Dragger
Knuckle Dragger's Avatar
Isn't there supposed to be a shouldered bushing at the pedal pivot shaft?
Thinking outside the shoebox
Old 21st-November-2012, 10:07 AM   #10
kimrobertson
That's what I'm wondering. I started with nothing so I don't have anything to compare to. Along with the pedals and clutch linkage there were only a few other parts. One was a hard plastic/nylon bushing (not the thin shaft bushings). I couldn't see a logical use for it at the time so I just put it in the spare parts pile.
Old 21st-November-2012, 10:48 AM   #11
kimrobertson
I did take it out yesterday. As usual, vibration noise from the pedal. I reached down with my hand. I could hardly feel the vibration with my hand. No visible movement. A very fine (high frequency?) vibration noise coming from up where the pedal butts up against the bracket that holds the pedals under the dash.
Old 21st-November-2012, 10:56 AM   #12
Knuckle Dragger
Will that hard plastic/nylon bushing fit between the pedal and the bracket? If not I'd find one that will to isolate the two pieces and probably eliminate the issue.
Old 21st-November-2012, 11:52 AM   #13
Roger Connolly
Roger Connolly's Avatar
Nova(s): 1972 Novas 2
Theres 2 plastic bushings that go on shaft, the one that is in the pedal assembly. If there not in it could cause a vibration. Good Luck
Old 21st-November-2012, 01:07 PM   #14
kimrobertson
I've got the thin ones that go between the pedal and the shaft where the pedal pivots. I put new ones in. Is there another bushing on the shaft that dampens vibration between the pedal and mounting bracket?
Old 21st-November-2012, 05:24 PM   #15
Nova1978
Nova1978's Avatar
Nova(s): 1978
There should also be a steel sleeve that goes in between the plastic bushings and the bolt. So from outside to inside it would be: Pedal tube, plastic bushings, steel sleeve, mounting bolt.
1978, Vortec 383, 200-4r, 3.73, 8.5 10 Bolt
clutch pedal Q's nova-hatch 4th Generation Nova's 31 28th-October-2010 05:27 PM
Clutch Pedal ?'s TRAXXAS14 4th Generation Nova's 1 14th-June-2010 03:36 PM
Clutch pedal for 66 or 67 ??? Carl Stevenson 1st & 2nd Generation Chevy II/Nova's 9 1st-January-2008 12:29 AM
Clutch pedal David&Melissa_h Drivetrain & Performance 12 9th-May-2007 09:59 AM
Clutch Pedal ? b cooper Steering, Suspension, and Chassis 1 18th-December-2006 11:28 AM
