How do you bleed? Bench bleed that is... - Chevy Nova Forum
View Poll Results: How do you bleed...? Bench bleed your master cylinder that is...
With outputs plugged... 6 16.67%
With hoses running from outputs back into reservoirs... 26 72.22%
Other... 4 11.11%
Voters: 36. You may not vote on this poll
Old 19th-November-2012, 06:23 AM   #1
okeesignguy
okeesignguy's Avatar
Nova(s): 72 SS Clone
Do you prefer to bleed with plugs in the outputs or with tubes running from the outputs back into the reservoir...?
If "other"...please explain...
Thanx!
Old 19th-November-2012, 09:18 AM   #2
jimys72
jimys72's Avatar
Nova(s): 72 Nova, 78 Elcamino
I've always done it the old school way.
Old 19th-November-2012, 09:48 AM   #3
okeesignguy
And how's that...?
Old 19th-November-2012, 09:53 AM   #4
642doorhardtop
642doorhardtop's Avatar
Nova(s): 64 COUPE "Gracie Baby"
Are you having trouble with them?
There are two kinds of things in life; The things you can control, and the things you cannot.
Old 19th-November-2012, 10:12 AM   #5
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova -383
Thanx!
Either way works just fine.
72 Nova -383, AFR 195s, Lunati #60113, 11.70s, next pass will be an 11.50
Old 19th-November-2012, 10:14 AM   #6
tony
tony's Avatar
Nova(s): '63SS'64SS'654D'76HD'89HD
I do it like this:
'In dog beers I only had one'
Old 19th-November-2012, 10:26 AM   #7
65novaken
65novaken's Avatar
Nova(s): 65 ss
^^^^me to
A goal without a plan is a dream.
Old 19th-November-2012, 10:38 AM   #8
sbc1320
sbc1320's Avatar
I have done it both ways and the plastic plugs work just fine. Do it with whatever you have available.
Old 19th-November-2012, 10:43 AM   #9
okeesignguy
I am replacing it soon and was curious how most of you do it....
I've seen it done both ways....
Old 19th-November-2012, 05:26 PM   #10
kilowatt
kilowatt's Avatar
Nova(s): 67 hdtp
Hummmm.... I've never bench bled anything and never had a problem getting the air out of the system. I hate the thought of dripping brake fluid on anything.
'67 hdtp all steel body full interior 436 sbc 9.29 @ 144 NA on drag radials
Old 19th-November-2012, 09:27 PM   #11
steelrat
steelrat's Avatar
Nova(s): 70 406-488hp/504tq,700R4
I used the plugs this time. Just be prepared to pump that cylinder for a while to get the air out. The rear compartment seems to take longer than the front.
Drive break repair repeat
Enough tools, parts & money can repair all but the loose nut behind the wheel
Old 19th-November-2012, 11:50 PM   #12
TMack63nova
TMack63nova's Avatar
How do you bleed?
Step 1 - Get a sharp knife
Step 2 - Cut finger with sharp knife
Step 3 - bleed
Sorry I could not pass that up!!
Old 20th-November-2012, 12:07 AM   #13
65novaken
65novaken's Avatar
Nova(s): 65 ss
Step 3 - bleed
step 4- swear
step 5 - grab a beer
Old 20th-November-2012, 12:11 AM   #14
TMack63nova
Originally Posted by 65novaken View Post
step 4- swear
Yes!! To ease the pain and slow down the bleeding by holding onto the can with the cut finger!!
Old 20th-November-2012, 08:22 PM   #15
BLS 6T7
BLS 6T7's Avatar
Nova(s): 67 283 4 spd. HT
Recently replaced a MC and booster on my 71 Corvette. Those that have done this can appreciate it when I say it was no fun, ie: the upper left booster bolt!!! The instructions were to do the plug method, worked very well. Used to do the old standard bleed hoses back into the reservoir method. I think both methods work well if done correctly.
Can I bench bleed a new Master Cylinder in the car? elvera Drivetrain & Performance 11 19th-January-2010 02:47 PM
trying to bleed brakes 74stroker Steering, Suspension, and Chassis 5 6th-August-2009 12:31 PM
brakes won't bleed novaBRO Steering, Suspension, and Chassis 16 6th-March-2009 07:59 AM
Can't Bleed my brakes Ed's68 3rd Generation Chevy II/Nova's 13 16th-August-2007 05:30 PM
How Do I Bleed Radiator?? 66novass Drivetrain & Performance 17 6th-June-2007 02:50 PM
