Fat Man spindles - Chevy Nova Forum
Old 18th-November-2012, 10:46 PM   #1
mr.murf
mr.murf's Avatar
Nova(s): 1973
Fat Man spindles
Has anyone used the 2" drop spindles from Fat Man Fabrications?
Old 20th-November-2012, 09:34 AM   #2
72novaproject
72novaproject's Avatar
Nova(s): 72, 67
All the drop spindles are pretty much the same. Heidt’s has what they call a 2” drop “TALL” spindle that moves the upper ball joint hole up 1.5” for a better camber curve. Most drop spindles are around 300.00US.
To each problem...exists a solution...now think.
http://www.picturetrail.com/zdnova
Half built 383, MT Tires, and 20 lb of Mig wire.
Old 20th-November-2012, 09:54 AM   #3
mr.murf
mr.murf's Avatar
Nova(s): 1973
Yes and the fat man spindles are also a "tall" spindle. I'm just worried about tie rod issues with the wheels that i have. I'm running 17x7 with 4" of backspacing.
Most of the camaro forums (they use the same front suspension as 3rd gens) guys have run into problems with the tie rods hitting the wheel/tire with drop spindles.
I just want to know if anybody here has used the tall drop spindles without any tie rod issues.. and what backspacing they have.
Old 20th-November-2012, 10:16 AM   #4
carguy502
The FatMan spindles are the same as the RideTech True Turn spindles. If you get the True Turn kit, They include high clearence steering arms that also eliminate bump steer common to taller spindles. I went this route and could not be happier.
Don
Old 20th-November-2012, 02:32 PM   #5
jakeg214
Title: Nova Newbie
Nova(s): 1972
Does that problem exist when using 2" lowering springs? Just wondering.
Old 20th-November-2012, 02:55 PM   #6
mr.murf
mr.murf's Avatar
Nova(s): 1973
Don
The more I read about that kit, the more I want it!
However, I only have a budget of $2000 for my front suspension upgrade and that kit would eat up half of it..... plus they don't guarantee fitment with stock or other tubular control arms.
What size front wheels are you running? backspacing?
No........
Old 20th-November-2012, 04:00 PM   #7
carguy502
I have a kinda an oddball setup. The wheels are Edelbrock 454 17X8 with 4.25" BS, but the rear has been narrowed 1" on each side and an ECI front brake kit that narrows the front end 1" per side. Basically tag 1" onto the back spacing figures and the wheel fitment should be close to what you need to run.
I plan to upgrade to 17X9 with 275-40-17 on all four corners this winter.
Best,
Don
Old 20th-November-2012, 04:44 PM   #8
jakeg214
Title: Nova Newbie
Nova(s): 1972
No........
Thanks. Funny thing, I went over to ridetech's site also and started to think this is the way I might go with my front end rebuild. But just as you it kills my budget, since I have to do the rear as well.
I think I'm going to go with lowering springs for now, and think about ridetech down the line. It looks like a really nice setup but I need to get on the road.. I just have too much to I want do.
Old 23rd-November-2012, 11:22 AM   #9
jakeg214
Title: Nova Newbie
Nova(s): 1972
If thats true, then aftermarket A-arms would be required to use the spindles, as I believe ride-tech requires their a-arms to be used with their drop spindles.
I'm not sure if Fatman or Heidts requires the use of their A-arms with their dropped spindles.
CPP says you can't go more than 4" of backspace with their dropped modulars. I ran into an old thread on lateral-g or camaro where someone had asked heidts and fatman and neither would say how much BS could be used with their spindles. Wheel size would probably also come into play. It seems most people are using 4.25 BS with 17's on 3rd gen's with stock spindles.
Old 26th-November-2012, 01:55 PM   #10
jakeg214
Title: Nova Newbie
Nova(s): 1972
Murf, I realize you are asking about the fatman spindles, I sent them an email and I have not heard back.
I also sent a email to Heidts about their 2" tall spindle and Mike Hawley responded saying that a maximum of 5" of backspace can be used with a 17" wheel with their spindles.
Maybe that will help? I'm still going back and forth on spindles or springs.
Old 27th-November-2012, 01:49 AM   #11
mr.murf
mr.murf's Avatar
Nova(s): 1973
I keep going back and forth myself. I'm trying to figure out if the heidts spindles would work with my stock disc brakes up front. I'm not sure if the bracket would work or not.
I think I might just save my money and keep my stock spindles with some drop springs for now... because i'm gonna be out of money after I buy my 500 series steering box, new master/booster and tubular control arms.
Let me know what you decide for you setup.
Good to know the spindles are good up to 5"... i'm planning on going 4.5"
Old 30th-November-2012, 06:16 PM   #12
mr.murf
mr.murf's Avatar
Nova(s): 1973
Looks like i'm going with the Heidt's tall drop spindles after all. I just got off the phone with Brian at Heidts and he said they will work with stock 11" disc brakes and ANY tubular control arms.
Just thought i'd share.
Old 2nd-December-2012, 12:16 PM   #13
jakeg214
Title: Nova Newbie
Nova(s): 1972
Thanks for the update. Did he happen to mention anything about tie-rod clearances? I'm leaning to springs still but I have not yet purchased.
Old 4th-December-2012, 12:51 AM   #14
mr.murf
mr.murf's Avatar
Nova(s): 1973
You said in a previous post that you asked heidts and they said you can run up to 5" backspacing with a 17" wheel. That answers our question about tie rod clearance, correct?
Right now I have a 17x7 with 4" backspacing, but when I get new wheels I plan on going 17x7 with 4.5" backspacing so I should still be good.. that is if what they told you is true about being good up to 5".
Am I missing something here?
Old 4th-December-2012, 04:00 PM   #15
jakeg214
Title: Nova Newbie
Nova(s): 1972
That is what I was told was 5" of BS on a 17" wheel. I didn't know if other details about this were discussed when you spoke with them.
Anyone with a pic of 5 lug spindles please. PldBryan Steering, Suspension, and Chassis 0 22nd-April-2011 12:24 AM
Changing from older spindles/discs to newer spindles/ discs nova64000 Steering, Suspension, and Chassis 21 13th-April-2011 10:57 PM
air bags with 2" drop spindles or stock spindles? Skraps Steering, Suspension, and Chassis 10 27th-May-2010 02:15 PM
spindles cranker Parts for Chevy II/Nova/Acadian 0 26th-January-2010 04:39 PM
