Mono leaf to multi leaf swap - Chevy Nova Forum
Old 13th-November-2012, 10:50 PM   #1
NovaNick70
NovaNick70's Avatar
Nova(s): 1970 350ci project
I am looking to buy new leafs for my 70 nova. It has factory monoleafs that are toast. I want to swap the factory monos for some eaton multi leafs. My question is two fold: 1.what additional hardware will I need (shackles, bolts, everything)? And what is expected if I go +2"? Any photos you have of Novas with any eaton leafs would be appreciated.
Old 14th-November-2012, 11:10 AM   #2
NovaNick70
NovaNick70's Avatar
Thought i would refresh, posted this late for the east coast guys. Any feedback? Anybody with Church Boys rear springs? Any picks?
Old 14th-November-2012, 11:48 AM   #3
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova -383
U bolts, isolator pads if using them along with poly bushings in the springs and correct or new shocks.
Did that to my last 71 Nova. I probably got those springs from Classic Industries for stock height.
72 Nova -383, AFR 195s, Lunati #60113, 11.70s, next pass will be an 11.50
Old 14th-November-2012, 12:19 PM   #4
NovaNick70
NovaNick70's Avatar
Thanks for the help! do you happen to have any photos of the stance for that one? I am trying to get an idea of what "stock" height is!
Old 14th-November-2012, 12:22 PM   #5
65Coupe
65Coupe's Avatar
Nova(s): 1965 Chevy II Nova 400 HT
Call up Eaton Detroit Spring and they'll send you all the hardware you need to upgrade to multi's including u-bolts, pads, shackles, and bushings. I upgraded my mono's to Eaton multi's last year and they made all the difference in the world. Plus, their quality is second to none.
Old 14th-November-2012, 01:10 PM   #6
jimys72
jimys72's Avatar
Nova(s): 72 Nova, 78 Elcamino
I changed mine out about ten years ago with ones from Paddock. seems i had an issue with the locater pin on the new leafs. I now that i made spacer blocks so the brackets wouldnt over bend. Good luck.
Old 14th-November-2012, 01:22 PM   #7
sbc1320
sbc1320's Avatar
I had a 3/8" shank drill bit in my tool that enlarged the hole in the spring perch perfectly. You could also take a die grinder to the hole or grind the locating pin smaller. I drove mine to my shop where I work and did the change over and drove it home.
Old 14th-November-2012, 01:24 PM   #8
sbc1320
sbc1320's Avatar
Old 14th-November-2012, 01:32 PM   #9
NovaNick70
NovaNick70's Avatar
Thanks for all the help guys, definitely need to get on the horn with Eaton and see what they say!
Old 14th-November-2012, 02:06 PM   #10
xten57
xten57's Avatar
Nova(s): 69 2dr sedan
spring swap
I swapped from mono's to multi's, but I went with a 5-leaf set up. If you use one of the 2- or 3-leaf mono replacement kits from Eaton it will probably have everything you need.
The initial ride height, and how it looks, will change after driving the car for a while because the springs will settle. How your car looks compared to others' may also differ depending on your tire and rims, so take that into consideration.
When I replaced my worn out stock mono's with multi's it raised the rear end about two inches just because the old springs sagged so much. If you like you can PM me and I'll send you a couple of before and after pics.
Old 27th-November-2012, 09:27 PM   #11
MrJoshua
Title: Nova Newbie
I am doing the same thing to my 72. It originally had the mono and I bought a set of multi leafs (4 leafs). I also ordered new shocks for the multi set up. The shocks are the same length as the ones for the mono. What is different about the shock is the way it mounts to the shock plate. The shock plates are different. You may need to order the multi leaf shock plates as well. If I'm wrong about this please let me know cause I'm about to order new shock plates.
The spring purches on the axle tubes are a little different. They are deeper. You will have to make up two spacers to fill the gap between the mono purches and the spring plate that is formed due to the added spring height from the leafs. Also the multi purches have a hole in the middle for the locating pin. The mono's had the locating pin on the bottom and it went through the shock plate.
Hope that helps.
Mono Leaf to Multi Leaf Springs novaconv63 Steering, Suspension, and Chassis 17 11th-June-2012 11:04 PM
mono leaf to multi leaf conversion sttc6307 Steering, Suspension, and Chassis 2 17th-November-2010 12:12 AM
Converting 1972 Nova from Mono Leaf to Multi Leaf springs bryanw47 3rd Generation Chevy II/Nova's 3 5th-November-2010 06:01 PM
Difference bewteen mono leaf srping and multi leaf spring?? 73NovaMan Steering, Suspension, and Chassis 7 30th-October-2009 12:47 AM
stock mono leaf or multi leaf? grega Steering, Suspension, and Chassis 11 14th-July-2009 10:03 AM
