Am I Missing Something Here? - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 4th Generation Nova's
Old 9th-November-2012, 09:14 PM   #1
kimrobertson
kimrobertson's Avatar
Nova(s): 1979 Pontiac Phoenix
Question Am I Missing Something Here?
My front seatbelt/shoulder harness setup has no guide from where they mount on the floor just behind the driver'sseat. It's just bolted on and hanging. I have gotten the guides for the top of the headrests (not installed yet) but wonder if I'm supposed to have guides from the back floor too. Anyone know if I should have these? If so any pictures of what they look like? What years would work right in my 79? I've included 2 pictures of my setup-one from inside and one from outside.
FROM INSIDE
[/IMG]
FROM OUTSIDE
[/IMG]
Old 9th-November-2012, 11:03 PM   #2
mg79
Nova(s): 1979 Nova
Checked my 79. There isn't a guide. The shoulder belt goes up from the floor, through the headrest guide, then to the roof. Sorry no pics, but looks just like yours.
Hope this helps.
Mike
Old 9th-November-2012, 11:21 PM   #3
racerex1
racerex1's Avatar
Nova(s): 78 SS Clone
My 78 is the same as yours.
Old 10th-November-2012, 07:03 AM   #4
kimrobertson
Okay that's good to know. Thanks guys!
Old 10th-November-2012, 10:31 AM   #5
1977Chad350
1977Chad350's Avatar
Title: Moderator
Nova(s): 1977 Nova 1978 Nova
I just went out and looked at mine. Yours looks the same. My bolts are painted black where it bolts to the floor.
1978 Nova 2 door Gen V 454 crate engine 350th Transmission 8.5 10 bolt locker
1977 Nova 2 door coupe
Old 11th-November-2012, 11:27 AM   #6
dlezama
dlezama's Avatar
Nova(s): 76Concours 77MalibuRally
I believe Philip once xplained that the 78 and 79 are bolted direct to the rocker as yours. Prior to 78 there was one retractor on top and another on the floor. The headrest or seat-side guide is just there to keep it tidy and easy to reach without twisting back. Its also useful if you have the original seat adjuster plate (the plastic transparent one), as it butts with the guide when in use and prevents the belt from chafing your neck or shoulders.
Old 11th-November-2012, 03:04 PM   #7
kimrobertson
Okay thanks Daniel. I know its on the solid piece with the recessed hole in it but is there a particular position those guides/retainers screw onto the headrest? Any pictures?
Old 11th-November-2012, 08:45 PM   #8
dlezama
dlezama's Avatar
Do you mean you have the bases already on? You first have to slip the guide on the belt in the correct side of the guide. Then ust snap in the guides with the belts inside them in the big hole, with the leading edge of the guide to the front of the car.
If the guide is tight, youre good. If the guide is loose and snaps easily off, you have to insert a very small Philips screw in the little hole in the middle to open it up slightly. I believe this depends on a slight variation in plastic manufacturing quality.
To remove guide, carefuly pry it off with a small flat screwdriver.
Check the Nova catalogue for 76 and 77 they have pretty good pics. They have them at novaresource.com
Old 12th-November-2012, 09:00 PM   #9
kimrobertson
Thanks Daniel! Looked it over and see what you mean. Also found a couple helpful pictures on google. It didn' t have any guides at all when I bought the car so I bought new ones and wasn't sure how they go on. Now I see. Question: Once installed, is the guide supposed to pivot slightly as the shoulder harness is moved or just be stationary?
Old 12th-November-2012, 09:13 PM   #10
Philip
Philip's Avatar
Title: Moderator
Nova(s): 1977
It will pivot a little normally. There is a stop on it.
77 Nova
"WORRYING does not take away tomorrow's TROUBLES;
it takes away today's PEACE."
Old 12th-November-2012, 09:40 PM   #11
kimrobertson
Okay thanks Philip...I didn't realize there was a stop.
Am I missing something??? motone82 Body and Interior 6 3rd-July-2011 07:43 PM
What's missing from this Q-jet? socalconcours77 Drivetrain & Performance 8 10th-March-2011 09:05 PM
Am I missing something here. KDee Ebay, etc. Discussion 9 25th-January-2011 08:14 PM
Am I missing something? L79Fan Drivetrain & Performance 2 5th-January-2009 11:59 PM
Am I missing something: Professor Fate Ebay, etc. Discussion 11 5th-July-2007 01:34 AM
