sparks from alternator and white smoke from starter :( - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 6th-November-2012, 03:55 PM   #1
wolfmantough
Nova(s): 1973 4 door
so, i was hooking up the wiring under the hood… with plans to start my car for the first time with the new engine when i hit trouble.
double checking the wiring (after connecting my battery) i noticed the nut on the post on back of the alternator was a little loose.
i slid a small wrench behind it and tightened it, and the second i did i got a ton of sparks from that post and then a puff of white smoke from (i think) my dang brand new performance mini starter.
what happened?!
i could have sworn my wiring was correct, and i've got fresh batt cables and fresh clean grounds.
im pissed and confused!
Old 6th-November-2012, 04:07 PM   #2
Rich74custom
Rich74custom's Avatar
Nova(s): 74 Nova Custom
So you must have grounded out the alt, which also is connected directly to the starter. Did you not remove the power wires from the battery first?
Besides always removing battery cables before almost any repair. you need to check your alt and starter before hooking new cables back up. Take them to an auto parts store and have them tested, It could have been that the alternator was grounded internally through the post. But most likely the wrench did that.
Old 6th-November-2012, 04:12 PM   #3
wolfmantough
thats such crap! what a set back. all because i was rushing.
Old 6th-November-2012, 04:19 PM   #4
wolfmantough
im pretty sure the smoke i saw came from an old fusible link that was SOAKED in old grease. either way i have to replace it… doing that now!
Old 6th-November-2012, 06:27 PM   #5
71nova355
71nova355's Avatar
Nova(s): '71, mild 355, t10, 10 bo
it might be alright, just get them tested to be sure. even tho you have a lil extra work ahead of you now. I would think you have something wired wrong cause you should be able to touch that post without causing harm.
Speed, Hot Girls, and Family
Old 6th-November-2012, 09:25 PM   #6
wolfmantough
i think the ring terminal on the starter post was very close to the ignition source spade terminal… im thinking they touched too.
Old 6th-November-2012, 09:51 PM   #7
PCPete
PCPete's Avatar
Nova(s): '72 Nova 383/TH350
Oh....not good
I hate doing anything around the alternator post. chances are you didn't do anything to the starter itself because the solenoid would be the only part grounded and depending on how long the sparks went on it may not be hurt either. That's the beauty of fusable links. I'm thinking the white smoke was from the wire insulation - not that I've EVER had that experience, oh, yeah, the '59 Corvette. It burned wires all the time.
Have both units checked out. BTW, you can buy the electrical components, like the diodes at NAPA and the install pretty easily. Instructions are all over YouTube.
Pete
http://s1230.photobucket.com/albums/ee490/pcpete1/
'lo ocifer, it's run what ya brung. Got a beer?
Old 6th-November-2012, 10:02 PM   #8
wolfmantough
i replaced the old style fusible link with the large white link rubber insulation thing with some new style fusible link WIRE i got from advance auto.
ive actually never seen this kind before… hopefully the nova likes it.
Old 7th-November-2012, 05:12 PM   #9
wolfmantough
well...now I have no power when I turn the key. help!
Old 7th-November-2012, 05:19 PM   #10
ces63ss
ces63ss's Avatar
Nova(s): 63 nova ss
I well say the obvious, check your all your fuses.
Old 7th-November-2012, 06:28 PM   #11
wolfmantough
replaced them… still no power. wow what a pain in the A. so much for breaking in the cam shaft this week.
Old 7th-November-2012, 07:19 PM   #12
ces63ss
ces63ss's Avatar
Nova(s): 63 nova ss
check a couple things and lets see what we can figure out:
1. good batt. voltage
2. power to the ignition switch
3. power at the horn relay
4 firewall connectors in correctly
5. power at the starter
Old 7th-November-2012, 08:39 PM   #13
wolfmantough
alright...i now have power at everything except the horn, including 12v at the dist... not sure what's up with the horn.its too late here to start it and break in the cam... hopefully it starts on my next day off!
Old 9th-November-2012, 02:05 AM   #14
wolfmantough
why check for power at the horn relay? what would that show? i mean… my horn isnt working now so i dont think im getting power to it.
Old 9th-November-2012, 09:54 AM   #15
gary427
gary427's Avatar
Nova(s): 1970 468/4speed/sets stoc
There mite be more fuse link back down at the starter. Disconnect the battery again and inspect all fuse links. Sometimes the wire inside the fuse links burn and leave the insulation, so pull on all of them to see if they are open. A good wiring diagram will show you where all the fuse links are, if the wiring is factory.
I believe you trouble is open fuse link under the hood supplying power to the inside of your ride. Gary
sparks from alternator ccvair Electrical 2 20th-January-2012 08:39 AM
White smoke ? 67SHOEBOX Drag Racing Forum 16 25th-May-2010 02:54 PM
White smoke?? 4doornova Drivetrain & Performance 10 23rd-July-2007 10:43 PM
white smoke NAQ Drivetrain & Performance 3 17th-October-2006 09:02 PM
white smoke uhh-oh mark slocumb Drivetrain & Performance 1 22nd-June-2006 01:09 PM
