9" differential in a 2nd Gen - Chevy Nova Forum
Old 30th-October-2012, 10:01 PM   #1
charley7
(OP)
charley7's Avatar
Nova(s): 1966 2dr hardtop Ls 6.0L
Who has a 9" differential in a 2nd with leaf springs. Is it narrowed.
Charley
Old 31st-October-2012, 12:01 PM   #2
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): To be determined...
width would depend on wheel backspacing & if it's stock, mini tubbed or really tubbed.
Miles
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 31st-October-2012, 12:17 PM   #3
Nova 404
Nova 404's Avatar
Title: Supporting Vendor
Nova(s): 1967 Nova SS
I have a 9 in my 67 and its 1 inch each side narrower than stock.It was in the car when I bought it.Allows for a deeper rear wheel,which looks good.The down side it the brake backing plates are very close to the springs.Parking brake on some rear discs might pose a problem.
Member of the NorCal Brotherhood!
Old 31st-October-2012, 12:36 PM   #4
charley7
(OP)
charley7's Avatar
Thanks Brian I was wondering on that.
Old 31st-October-2012, 05:45 PM   #5
Twisted6
Twisted6's Avatar
Nova(s): 64 SS chevyII
I have a 9 in my 6SS and the car is Tubbed.But still on the stock 64 springs.
T6R }[oooooo]
Larry /aka Twisted6
Old 31st-October-2012, 05:50 PM   #6
charley7
(OP)
charley7's Avatar
Twisted6 are you leafs moved in or stock location.
Old 31st-October-2012, 06:43 PM   #7
PldBryan
PldBryan's Avatar
Nova(s): 1963 Nova SS 383
Garage
There are a few 9" rears that will go under a stock 1st or 2nd gen without being tubbed or the rear being narrowed. They can be found under the Early Broncos, Lincolin Versallies/Granadas, certain Mavericks have an 8" and I believe a 9" from an early Mustang is close as well.
The chart below shows most of the different manufaturers outside wheel mounting surface to opposite Outisde wheel mounting surface dimensions. You will have to deal with spring pad relocation as well. You can account for some differences in width by playing with the backspacing on your wheels
[LIST]
Outside
Width Year Model
56.50 1969-1977 Maverick 8"
57.00 1974-1978 Mustang II 8"
57.25 1957-1959 Ford, Ranchero, Station Wagon
57.25 1965-1966 Mustang
58.00 1966-1977 Bronco
58.00 1964-1965 Falcon
58.00 1977-1981 Granada/Versailles
58.50 1977-1981 Versailles
59.25 1967-1970 Mustang, Fairlane, Comet, Cougar
60.00 1967 Cougar
60.00 1958-1960 Edsel
61.00 1964-1971 Ford Full Size
61.00 1949-1951 Mercury
61.25 1957-1972 Ford F-100 Pickup
61.25 1960-1964 Ford Full Size
61.25 1971-1973 Mustang
61.25 1967-1973 Torino, Ranchero, Fairlane
63.00 1970-1979 Ranchero & Torino
63.00 1972-1979 Ford Full Size & Intermediate
63.50 1967 Fairlane (Coil Springs)
65.25 1973-1986 Ford F-150 Pickup
65.25 1978-1986 Bronco
65.25 1973-1986 Ford Van 3/4 Ton
68.00 1972 Ford Van 3/4 Ton
69.25 1977-1986 Ford E-150 Van
Chevy Outside
Width Year Model
54.25 1983-2004 Chevy S10 2WD, GMC S15 2WD
57.75 1962-1964 Chevy II/Nova
57.75 1965-1967 Chevy II/Nova
58.00 1978-1988 Chevy Malibu, Monte Carlo
59.50 1968-1982 Corvette
60.00 1955-1964 Chevy Car
60.00 1967-1969 Camaro
60.25 1968-1979 Chevy II/Nova
60.50 1984-1995 Corvette
60.50 1964-1967 Chevelle
62.00 1955-1959 Chevy Pickup
62.50 1968-1972 Chevelle
62.50 1970-1981 Camaro/Firebird
Mopar Outside
Width Year Model
55.60 1960-1976 7 1/4 A-body
55.60 1973-1976 8 1/4 A-body
55.60 1966-1972 8 3/4 A-body
55.60 All 8 3/4 A-body
56.00 1932-1934 All Mopars
57.40 1963-1972 7 1/4 A-body
58.54 All 8 1/4 F-body
58.54 All 8 1/4 M-body
58.54 All 8 1/4 J-body
59.00 1935-1936 All Mopars
59.14 1966-1970 9 3/4 B-body
59.20 1962-1970 8 3/4 B-body
60.00 1937-1948 All Mopars
60.70 All 8 3/4 E-body
60.70 All 9 3/4 E-body
62.00 All 8 1/4 B-body
62.00 1971-1974 8 3/4 B-body
62.00 All 9 1/4 B-body
63.40 All 8 1/4 C-body
63.40 1971-1974 8 3/4 B-body S.W.
63.40 All 9 1/4 C-body
PLDbryan
1963 SS
383 Forged Bottom/AFR top/Solid Bullet Cam in the middle
Muncie 4spd
F@&^ 9" Rearend
Old 31st-October-2012, 07:58 PM   #8
charley7
(OP)
charley7's Avatar
Thanks. There's a lot of good info.
Charley
Old 1st-November-2012, 05:24 PM   #9
Twisted6
Twisted6's Avatar
Hello charley
Yes the frame has been moved.The rails sit around 29&1/4 apart.And I still have a back seat.Also my 1/4 windows still go down about 90% ,Trunk lid still uses the stock rods/bars as well.
T6R }[oooooo]
Larry /aka Twisted6
Old 1st-November-2012, 07:10 PM   #10
65 Post
65 Post's Avatar
Nova(s): 65 Post
I did a 2" mini tub in my 65 and also moved the perches in the same amount. I bought a Moser 9" with the mono leaf perches on the housing and also had Ford bearing hubs with the 10/12 bolt bolt pattern so I could use my original backing plates. I did a LOT of measuring with wheels and tires, backing plates etc, and ordered it on a Monday. The rear, axels and bearings all ready on the axels were on my porch Wednesday. Popped it in and everything fit perfect. Can't say enough about Moser service. that was with a 15x8, 4 1/2 backspace Weld wheel with 5/8 studs. I have a 295/65-15 MT radial in the well and can slide my hand between the tire and body. Dave
"Are you the hunter, or the prey?"
65 Post 11.59 @ 115mph
2002 GORDY 150" RED, 7.91@ 167
Old 4th-November-2012, 12:00 AM   #11
gg63
I'd recommend 65 Post's route. I did the Versailles' 9inch route. It works but after all the money I put into it I wish I would have bought something new and made to fit from Moser or Currie. The pricing is hard to beat once you really add up what you have to put into it.
difference between "acetone" "paint thinner" and "mineral spirits"? Scooter Body and Interior 11 19th-April-2015 03:55 PM
3rd Gen Differential "Track width" and various questions LeftCoast Carl Drivetrain & Performance 7 27th-September-2011 09:53 PM
Can someone ID this differential for me? lttleric Drivetrain & Performance 6 26th-June-2011 11:54 PM
Stock 8.2" differential kit? Evil Box Drivetrain & Performance 0 15th-January-2009 05:38 AM
