Rust and pitting around rear windshield area.. - Chevy Nova Forum
Old 26th-September-2012, 11:53 PM   #1
sc2dave
Nova(s): 1966 nova, 194c.i.d.
how do i fix this? do they sell sheetmetal for the sides and bottom of the rear windshield? '66 coupe
Old 27th-September-2012, 12:06 AM   #2
Fredsgarage
Fredsgarage's Avatar
Nova(s): 65 Coupe 63 Mo-Door
Mine is bad in the same way. Do you have a picture?
I plan to use POR15 putty on mine.
I'll attach picture tomorrow, and we can compare.
Scraps 65 HT- 355 4bolt/ TH350-BOP trans
MO-Door 63-4dr 400 Series inline/glide
Nor Cal Novas NPHNP
Old 27th-September-2012, 10:52 PM   #3
sc2dave
Any pics yet?
Old 27th-September-2012, 11:07 PM   #4
Fredsgarage
Here is what mine looks like. The PO used silicon to stop rust! It acts like an acid and ate thru the metal.
I ordered POR15 putty and will try it here.
James
Nor Cal Novas NPHNP
Old 27th-September-2012, 11:19 PM   #5
sc2dave
it's something like that also and mine is around the sides too.. Anyone have a fix?
Old 28th-September-2012, 08:01 AM   #6
67nova73
67nova73's Avatar
Nova(s): 73 and a 67 Nova
I have a 67 194 coupe and the sides of it ( like below it ) are like thru it.....
Looks about a half dollar or bigger at the ends of the corners on the trim....
The fix for it: Im trying to find some NOS Quarters ( I have a few leads to on them ) and should no in a few weeks..
With yours, its looks like the piece between the windshield and the trunk.
And I think thats called a Deck something panel ah Deck Filler Panel...
http://www.goodmarkindustries.com/p-...11-710-66.aspx
Also shop around they range in price too...
Old 12th-November-2012, 09:37 PM   #7
sc2dave
Here's my rust; , anyplace that i can get metal for this?
Old 13th-November-2012, 10:33 AM   #8
PCPete
PCPete's Avatar
Nova(s): '72 Nova 383/TH350
Options
Seems like lots of PO's do what they can to make the problem worse. Mine did a "repair" with fiberglass.
There are several ways to fix the mess and most involve some welding. I was able to fix mine with fill welds and small repair patches cut from 18 gauge steel. Worst case is to replace the whole flange from a donor car and a new upper trunk panel. After repairing mine I smoothed the surface with Met-All filler
Pete
http://s1230.photobucket.com/albums/ee490/pcpete1/
'lo ocifer, it's run what ya brung. Got a beer?
Old 13th-November-2012, 10:41 AM   #9
nitroman812
nitroman812's Avatar
Nova(s): 72 nova rally sky top wit
I fuxed mine with a welder and patch pannels put in from under neath from the trunck i cut out randome peace of extra mettal and wellded it in then bondow and rust enhibtor
Old 13th-November-2012, 11:48 AM   #10
letrbuk67
letrbuk67's Avatar
Nova(s): 67 nova sedan
The rear deck filler panel would be the way to on it ,(IMO)
The sides ,or top if you don`t have to replace the 1/4s i would cut out a section and either make the piece or go to a metal shop and have them bend a piece in the same contour that you have , then start cutting out the old and welding in the new. Just make the pieces extra long that you make or have made , then start welding them in , Good luck on what ever you do and keep us posted .
Cowl Drain / Kick Area Rust TheBandit 3rd Generation Chevy II/Nova's 5 25th-August-2011 01:21 PM
Rust in tailgate weather strip area novaBRO Body and Interior 15 30th-July-2010 08:49 PM
Rust around the windshield NOVA1958 Body and Interior 18 24th-December-2009 10:31 AM
Windshield Install in LA/OC area sixtysixdeuce South Western US 1 3rd-September-2007 01:54 AM
Windshield Frame Rust Bluesman 3rd Generation Chevy II/Nova's 11 1st-October-2006 09:59 AM
