Warning lights! Do you trust them? - Chevy Nova Forum
View Poll Results: Do you trust the in-dash warning lights?
I do not trust them at all. I run all gauges. 18 66.67%
I run a gauge in place of two of the lights. 4 14.81%
I run a gauge in place of just one of the lights. 3 11.11%
I trust the lights completely. 2 7.41%
Voters: 27. You may not vote on this poll
Old 31st-July-2012, 05:33 PM   #1
Nova1963T
(OP)
Nova(s): 1963 Chevy Nova
Do you guys trust these lights? If one went off would you have enough time to diagnose a problem before serious engine damage occurred?
-Tom
Old 31st-July-2012, 05:38 PM   #2
carjai
carjai's Avatar
Nova(s): 73 nova
Yes if u catch them in time. Which light are you referring to?
Old 31st-July-2012, 05:42 PM   #3
Nova1963T
(OP)
Particularly the oil and temp lights. The gen light though important would not cause engine damage.
I run a gauge just for oil pressure only but I nearly left it stock..
I'm just curious what everyone is doing. I've heard they were bogus before and I've heard others say they were good enough protection. I was debating whether to add a temp gauge.
Old 31st-July-2012, 05:56 PM   #4
letrbuk67
letrbuk67's Avatar
Nova(s): 67 nova sedan
Nothing but gauges for me .
Bill
Old 31st-July-2012, 05:58 PM   #5
Vinco
Nova(s): 64-400
I've always called them "idiot lights", because when it comes on, all it means is, "You just blew up your engine, you idiot."
Old 31st-July-2012, 06:33 PM   #6
654door
654door's Avatar
Nova(s): 1965 Chevy II, 4 door sedan. 194cuin 6
Had those lights in my '65 4 door, but bought a complete dash assembly from John Piccola,('65 SS) and now have all gauges. I still have my light setup if I go back to original. Gauges are the only way to go.
Old 31st-July-2012, 06:52 PM   #7
64SSOwner
64SSOwner's Avatar
Nova(s): 1964 Nova SS
I had them in my chevelle 300 deluxe. I was really in tune with everything about that car though. I had turned pretty much every nut and bolt on the engine and replaced the sensors with new. I also checked all my fluids regularly before I drove it. It got warm once going over the mountains on the way back from LA. The temp light came on, i pulled over and let it cool down. Got back on the road and made it home. Ended up replacing the radiator with a 3 core. The original was just shot. I guess I never had a problem with them.
My
Old 31st-July-2012, 07:58 PM   #8
Jackel
Jackel's Avatar
Nova(s): 70 Nova SS I bought new.
Originally Posted by Nova1963T View Post
Do you guys trust these lights? If one went off would you have enough time to diagnose a problem before serious engine damage occurred?-Tom
Tom, I TRUST THEM A LOT not to work...Jack
Retired Bum...The transition was easy
Old 31st-July-2012, 10:47 PM   #9
1quik69
1quik69's Avatar
Title: Moderator
Nova(s): 1972w/408,
I run lights and gauges.
Old 31st-July-2012, 11:23 PM   #10
Philip
Philip's Avatar
Title: Moderator
If you are not watching the gauge it does no good. Having both is ideal as a light coming on will get your attention.
64 Nova 400 series 4 door
SOLD 01/15
Old 31st-July-2012, 11:35 PM   #11
Ryan V64SS
Ryan V64SS's Avatar
Nova(s): 64 SS, 63 Sedan
On a stock to mild engine I have used then with zero worries. The senders are cheap so put new ones in to be safe. Its pretty simple system and all the lights should come on at key on engine off so if a light is out you will know.
I dont like gauges in my drivers unless they are in the dash but even then I prefer the simple look of the stock cluster.
Street strip car has gauges though...
64 SS Street car. 10.60's on pump gas and 235 radials
Old 31st-July-2012, 11:53 PM   #12
S.Humrich
S.Humrich's Avatar
Nova(s): 65 ss 63 wagon
Garage
X2^^^^^^
Old 1st-August-2012, 04:41 PM   #13
mikeorwan
mikeorwan's Avatar
Nova(s): Boring 11 sec. 350
Gauge for oil pressure and temp......other than that dont care....lol.
I reject your reality and substitute my own!
1.587 60', 11.615 1/4
Old 2nd-August-2012, 05:56 PM   #14
chui1980
chui1980's Avatar
Nova(s): 1970-72
There is nothing worse than a late email. I run gauges for just about everything. I have oil, gas, temperature, volts, vacuum, rpm and I will be installing soon a tranny temp gauge. It is very important to know just how she is doing. It also looks good.
Old 2nd-August-2012, 08:01 PM   #15
Nova1963T
(OP)
I guess the general consensus is that gauges are important! I will put a T and run both gauges and lights for the oil. I replaced the temp sender so hopefully I can trust that warning light.
-Tom
Dash Warning Lights... 72 JeffersonC Electrical 1 14th-February-2010 10:31 PM
Tail Lights: Running Lights, Brake Lights, and Reverse. Planning my lights out... 63nova9sec 1st & 2nd Generation Chevy II/Nova's 2 22nd-November-2009 12:33 PM
warning lights to guages 654door Electrical 4 28th-November-2008 11:18 PM
Questions on Warning Lights/Senders (idiot lights) Bscman Electrical 2 5th-September-2007 01:20 AM
