1/4 mile guess with my new set up?? - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 6th-July-2012, 06:24 PM   #1
Gregs72
Nova(s): 1972 Chev Nova
I am going to the track tommorow to find out just wondering what you all though
355 small block
Flat tops
comp 292 cam (.501/.501 lift)
Angle plug camel hump heads
Edelbrock Performer RPM Air Gap
Holley 750 HP
Coan 4500 stall, fully built TH350
8.5" with 4.11 posi
will be running 28x9 Hoosier slicks
ina 72 Nova stock weight
I am hoping for a 12.5ish
The best 60' the car has done is a 1.697
1972 Chev Nova
12.76@104.48mph 1.74 60' with 8.13@85mph 1/8th mile
New best 1/8th Mile 8.01@87mph!
Old 6th-July-2012, 06:40 PM   #2
carjai
carjai's Avatar
Nova(s): 73 nova
Low 12s from what I seen with other combos that's similar, if not mid 12
Old 6th-July-2012, 06:45 PM   #3
MBZTECH
MBZTECH's Avatar
Nova(s): 1971 SS L48 383
Cool
Low 12s looks like a good round number. Have fun and keep all parts intact.
Old 6th-July-2012, 07:16 PM   #4
cdahl383
cdahl383's Avatar
Nova(s): 1972 Nova
Somewhere in the 12's seems right to me. I'm jealous, I want to go to the track! Haha! Good luck and have fun!
Carl
12.66 @ 110.8 mph
Old 6th-July-2012, 07:35 PM   #5
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova -383
High 11's to low 12's. Tried a 26' tire with it?
Old 6th-July-2012, 07:39 PM   #6
sevenzeronova
sevenzeronova's Avatar
Nova(s): 70
If it hooks nice, 11.90s
Old 7th-July-2012, 12:16 PM   #7
Seattle_Mike
Seattle_Mike's Avatar
Title: Moderator
My guess is take it out and see what it does. There's way too many variables to take a wild guess and they typically end up with the racer building unrealistic expectations and going away disappointed. Concentrate on having fun and a good learning experience to go forward with.
33 Ford 3 Window 468ci BBC
68 Camaro ProMod 846ci Reher-Morrison Nitrous
www.yvonnelucasracing.com
Old 7th-July-2012, 12:43 PM   #8
Lugnut79
Lugnut79's Avatar
Nova(s): 67 Chevy II
I say low 12's as well. My combo is similar but I have more compression and more cam. I also run 4300 stall Coan with a glide, 4.56's and 28" drag radials. Let us know how you make out.
Camel Humped 355 best, 11.55 @ 116
http://s609.photobucket.com/albums/tt179/Lugnut79/Car/
Old 7th-July-2012, 07:02 PM   #9
MANGOPUPPY
MANGOPUPPY's Avatar
Nova(s): '72 476 14:1, 8", 4:10 sp
355 small block
Flat tops
Holley 750 HP
8.5" with 4.11 posi
11.70's @ 111 hooking dead w/ 3200# , if heavier, 11.90 @108. i agree with mike. take it out and see.
Car Pix Just Idling
Old 8th-July-2012, 05:40 PM   #10
Lugnut79
Lugnut79's Avatar
He did take it out yesterday he just wanted to see what others thought it would run before he went. I think your guess for mph is off for et's as well. 108 mph is more like 12.20-12.30's. I hope I don't stick my foot in my mouth when he reports back with results.
Old 9th-July-2012, 11:34 AM   #11
HockleySS
HockleySS's Avatar
Nova(s): 1969 SS 350
Well Greg... How did you make out?
GM CANADA DOCUMENTED 1969 SS (350)
Old 9th-July-2012, 06:24 PM   #12
Gregs72
I made out pretty poorly......
13.08@104mph
The motor starts to break up at 5500rpm....it sounds all ignition
People at the track told me I should not have had my MSD Blaster 2 Coil mounted Horizontally.....and you could see some oil dripping out....i have been battling this same issue for 2 years with 3 different engines.....I have put in 2 different pro billet distributors and 4 different MSD Box but never thought to change the coil....
So i have a brand new coil and i am going to mount it vertically like the instructions say.....
Also its not valve float i have brand new valve springs....it sounds almost like hitting the rev limiter
BUT i did have fun had not been to the track since last September
1972 Chev Nova
Old 9th-July-2012, 08:08 PM   #13
cdahl383
cdahl383's Avatar
Nova(s): 1972 Nova
Thats still not too bad for having issues, I'm sure when you make the changes you'll get into the 12's no problem.
It looks like you hooked pretty good though based on your ET and MPH. What was your 60 ft time?
Main thing is you had fun! I'm hoping to take my Nova to the track this Wednesday. We'll see how it runs as long as the weather holds up.
Carl
12.66 @ 110.8 mph
Old 9th-July-2012, 09:38 PM   #14
carjai
carjai's Avatar
Nova(s): 73 nova
Your 60ft says a lot. U should be in the mid 12s with that mph
Old 9th-July-2012, 10:03 PM   #15
carjai
carjai's Avatar
Nova(s): 73 nova
I myself can't wait to get back. What rpm are you leaving at
63 HT at the 1/4 mile Bucknaked Racing Drag Racing Forum 20 16th-November-2011 08:35 PM
which is better fo1/8 mile 1973novaman Drag Racing Forum 8 30th-March-2011 08:10 PM
Guess 1/4 mile time Limegreen70 Drag Racing Forum 5 28th-November-2009 04:08 PM
61,000 mile 72 SS stupesnova Ebay, etc. Discussion 0 15th-August-2007 12:45 AM
Low mile 78 Novajay Ebay, etc. Discussion 1 14th-May-2007 09:39 AM
