75-76 Nova SS Grille Emblem - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 4th Generation Nova's
Old 19th-June-2012, 06:37 PM   #1
zat
(OP)
zat's Avatar
Any ideas where I can get one of these? I broke the tabs off our only one and 77Concours is giving me all kinds of grief.
They were on Ebay but I can't find one anywhere.
Thanks !!
Old 19th-June-2012, 08:40 PM   #2
zat
(OP)
zat's Avatar
Follow Up
Any ideas to glue, weld, ???? anything so we can attach to grille ??
Getting desperate...
Old 19th-June-2012, 10:34 PM   #3
racerex1
racerex1's Avatar
Nova(s): 78 SS Clone
Drill and tap it? 6-32 or so screw size... just throwing it out there. I am going to have to figure something out as well...I have 1 stud left.
Old 19th-June-2012, 11:11 PM   #4
dlezama
dlezama's Avatar
Nova(s): 76Concours 77MalibuRally
If you have the old stud or another from another emblem, maybe gouge the back of the emblem and glue with epoxy resin and fiberglass cloth. A couple of layers would be best. Set for 24 hours. Then attach nut with moderate pressure... I cant think of anything else.
There is/was a plastic repro on Ebay (kenoregon) but it looks pretty lame... look it up. The good metal repros seem to have dried up.
Old 19th-June-2012, 11:58 PM   #5
76 SS
76 SS's Avatar
Nova(s): custom 4th gen,72 project
Give philip some time, he can make them out of black plastic & once painted you can't tell the difference & they have the bigger 79 rally studs that fit tighter in the grille & its the only ss emblem that truely fits a 75-79 grille because it has longer studs necessary to fit a 79.
Old 20th-June-2012, 09:30 AM   #6
76 SS
76 SS's Avatar
Here's another trick, flip the cup shaped nuts over & go again, you have to use pliers on the nuts because of the flange around the edge of the nut is now towards the outside. You should still have an 1/8 stud left since the nuts were cup shaped. Done it several times myself, works great.
Old 20th-June-2012, 05:20 PM   #7
zat
(OP)
zat's Avatar
That looks like that may work for us. We need to get it back on for the GM Nationals this weekend.
Old 21st-June-2012, 09:13 PM   #8
GenuineSS
GenuineSS's Avatar
Nova(s): 1975 Nova SS
After countless hours of attempted restoration of my '75 SS emblem (which had also been painted silver) I FOUND A PERFECT REPRODUCTION! Now, I just have to remember where! When I do, I will let you know. Its a million times better.
1975 Nova Custom SS, 350, 4 Barrel, Flowmasters, Persimmon Metallic, Buckets, Console Gauges, Posi
Old 21st-June-2012, 09:46 PM   #9
ProNova
ProNova's Avatar
Nova(s): 1976 Pro Street SS clone
Francis I hope you and Adam have a blast, I am staying closer to home this year and going to harrington show and hanging with 4GOTTEN1 Hope you both do well there
Bruce NNN Member #41221 Prostreet Fraternity
Old 22nd-June-2012, 07:17 PM   #10
zat
(OP)
zat's Avatar
You'll be missed Bruce ! We were hoping you would attend.
Old 22nd-June-2012, 07:55 PM   #11
ProNova
ProNova's Avatar
Maybe see you guys at Nationals
Old 23rd-June-2012, 01:44 PM   #12
GenuineSS
GenuineSS's Avatar
Found my answer. If your are looking for the emblem, the parts place has one for $49 it looks great
http://thepartsplaceinc.com/ocatalog...chPart=EM1971N
Old 23rd-June-2012, 10:01 PM   #13
dlezama
dlezama's Avatar
If that's the metal one, I have one of those. The workmanship is really outstanding. Only difference from original is that is has no part number in the back. Otherwise probably even better quality than OEM.
Just in case, you should check with the store if its the metal one, not the plastic one.
Old 24th-June-2012, 08:18 AM   #14
zat
(OP)
zat's Avatar
MANY THANKS !!!!!!!!
Old 27th-June-2012, 03:11 AM   #15
dlezama
dlezama's Avatar
Maybe I shouldnt post it this way, but its NOS and you all have been looking for it... looks like one time only chance
http://www.ebay.com/itm/nos-1975-nov...207322&vxp=mtr
65 Grille emblem? CGM Originality 2 25th-July-2011 12:04 PM
ss grille emblem GMPartsman 3rd Generation Chevy II/Nova's 1 20th-January-2007 11:52 PM
