3790721 Block - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 13th-May-2012, 01:45 PM   #1
CRJ
Nova(s): 1963 coupe 1963 ragtop
3790721 Block
Hey guys, just picked up a 721 engine yesterday. I need help with the codes. The info on the block is as follows.. Cast date is I243 whick I believe is Sept. 24, 1963. The Stamping on the front pad is FI002DE which I think is Flint Michigan plant. Assembly date of Oct. 2 1963 and DE is 1964 Nova with powerglide. I dont have any decoding books so this is the best I could come up with. Any help would be greatly appreciated. Thanks! Chuck
Old 13th-May-2012, 02:24 PM   #2
BZ65
Nova(s): 1965 SS
Try this: http://novaresource.org/index.htm
Old 13th-May-2012, 03:39 PM   #3
CdnL79 Registry
CdnL79 Registry's Avatar
Title: Moderator
Nova(s): See my signature.
Not much to add to the correct information you've indicated above. The 721 was the primary block used for the 283CID 1964 Chevy II. Later it was used for Chevy II 327 applications until the 362 block came along in fall of 1965. Even some very early 1966 L79s had 721 blocks.
Bob
62 Acadian cvt sold
63 Nova SS cvt sold
66 Cdn. Nova SS L79 sold
70 Nova SS L78 sold
Old 16th-May-2012, 12:09 AM   #4
tburgchevy
Title: Nova Newbie
Nova(s): 1965 Nova SS
So is the 721 block a 283 block or 327 block?
Frank
Old 16th-May-2012, 12:56 AM   #5
BZ65
Nova(s): 1965 SS
Chevy II specific block used for both 283 and 327. Different size cyl. bore.
Old 16th-May-2012, 01:27 PM   #6
CRJ
Thanks for the info guys, I just tore this thing down. Looks like the block is at .030 over but it had a fresh rebuild. I still see crosshatching on the bores. Im taking the block in to my machinist to have it checked out. Ive had severeal 194 blocks thru the years and still have one in my 63 coupe but this is the first 721 Ive had. I paid $400 for it from intake to pan including the Nova specific exh. manifolds. He even thru it an extra intake that turned out to be for a 1960 corvette 283. This engine is slated to go into my SS vert.
Old 16th-May-2012, 01:44 PM   #7
CRJ
Also, since this is the same casting as the 327 ,can this block be safely bored out to 4 inches? Im not finding anything concrete about that. I dont want to make a 327 out of it, I just want to know if I have much more room to play with if the block needs anymore cyl. work:
ChevyII, old-style block, to modern block Front Sump oil pump pickup modifications jjj5757 Best of the 1st & 2nd Generation 11 18th-January-2015 01:37 PM
Engine blocks 3790721 and 3791362 II4TheRd 1st & 2nd Generation Chevy II/Nova's 21 11th-October-2013 09:12 AM
69 NOVA small block to big block conversion Hydrochild Drivetrain & Performance 5 17th-August-2011 04:28 PM
small block nova with big block coil springs nova805 Steering, Suspension, and Chassis 1 30th-January-2009 01:29 AM
Switching from a small block to a big block heater core? slickman Drivetrain & Performance 19 19th-October-2007 08:59 PM
