My 66 build - Chevy Nova Forum
Go Back   Chevy Nova Forum > Non-Technical > 1st & 2nd Generation Chevy II/Nova's
Old 1st-May-2012, 05:36 PM   #1
edge04
My 66 build
Moving this thread over here and will post here now. Going to start final assembly and will be asking opinions etc.
Swapping out the front rotors and calpiers to 14 inch 6 pistons, then sub frame connectors and then will install engine and trans and work around from there. Got some ideas on the interior and some changes to exterior as well.
http://www.stevesnovasite.com/forums...d.php?t=173656
Old 2nd-May-2012, 04:36 AM   #2
asteeler4life
asteeler4life's Avatar
Nova(s): 1962 'VERT 1966 SS
I'VE BEEN FOLLOWING THIS BUILD, AND YOU'RE NEARLY THERE!
62INLINE 6 GROUP
66 NOVA SS COUPE INC.
Old 2nd-May-2012, 06:09 AM   #3
edge04
thanks, the fun starts now. for those running LS motors, are most of you using the F-body front acc system or corvette? I need to keep as much room up front as possible.
Old 2nd-May-2012, 07:53 AM   #4
TomM
TomM's Avatar
Nova(s): 66, 67 Coupe
It's a mix really, I used f-body, Chuck used CTS I think, Burke has done two with truck accessories, so there is no real limiting factor as far as pans or room. I think even Corvette will work, but can't remember seeing one.....you should have plenty of room. having said that, truck pans are too deep, and I don't think a vette bat wing pan will work, at least I haven't seen one....
Burke moved his engine forward an inch, and so did I. It is tight, but there is clearance......and it all fits..
T,
Old 2nd-May-2012, 08:57 AM   #5
edge04
I'm using an F-body pan. Why move the engine forward? My first thought was to move it down and as far back as possible. I plan on running a
4l80e so wonder if moving forward helps with that? TCI claims that their plates move the motor down and back as much as possible. I also plan on running the a/c compressor low on the passenger side, I would think moving it forward would help with that as well. Just like the look of it back. Do you have any pics you can share, thanks.
NVM, I see you thread!
Old 2nd-May-2012, 12:48 PM   #6
TomM
TomM's Avatar
I moved it forward to give me room to do the low A/C bracket, more tunnel room for the trans, and be able to hide some wiring behind the engine.......
Pretty sure you are going to have to split the tunnel at least. That 80E is a big sucker.....
You can only go so far forward, I think 1" is about it. As for going down, you are going to have some ground clearance issues if you go more than an inch or two, no matter what exhaust you run..
T,
Old 2nd-May-2012, 01:14 PM   #7
edge04
T,
My reason for moving back is that I am running a twin turbo so need room for the IC and RAD.
That will help with ground clearance as well.
I'm hoping to get away with not having to cut the tunnel and jus beating it with a hammer.....but moving it back isn't going to help my case.
I have a core trans so I should start lowering it in and seeing where I stand soon.
Old 25th-May-2012, 01:41 PM   #8
edge04
not a lot of progress as I was waiting for my new rotors to come in which they finally did. Couldn't move the car around with out them.
Exchanged my SS 12 inch rotors with 4 piston for these badass 14 inch with 6 piston! What do you think?
got some other parts so I can set the engine and trans in. Those are dirty dingo adjustable plates
Old 28th-May-2012, 11:39 PM   #9
1bd63nova
1bd63nova's Avatar
Title: Nova Newbie
Nova(s): 1963 ss prostreet
nice so what did you use for a pan?
Old 29th-May-2012, 09:20 AM   #10
edge04
F-body. Should drop engine and trans in next week
Old 29th-May-2012, 04:36 PM   #11
EdwardsSS
Nova(s): Two '63s and a '55.
Trans mount looks good...where did you pick that up, and what brand is it?
Thx,
Ed
Old 29th-May-2012, 05:57 PM   #12
edge04
Thx,
Ed
From TCI. It is for their 4 link I installed. Hope it works with a 4l80e!!
Old 1st-June-2012, 12:40 AM   #13
1bd63nova
1bd63nova's Avatar
Title: Nova Newbie
nice I'm doing a 6.0 in a 63 I'm trying to get 25 post so i can post pics.
car looks bad azz
Old 1st-June-2012, 12:45 AM   #14
S.Humrich
S.Humrich's Avatar
Nova(s): 65 ss 63 wagon
car looks bad azz
Ryan comment on a bunch of threads and post some pictures or text them to me and I'll post them for you
Old 6th-June-2012, 11:41 PM   #15
asteeler4life
JUS' WHEN I THOUGHT YOU WERE DONE! YA GO DO THIS .......
BADASS MAN BADASS!!!
62INLINE 6 GROUP
383! to build or not to build? nitrus5 Drivetrain & Performance 24 9th-November-2011 10:56 PM
my 489 build ss396rat72 Drivetrain & Performance 5 27th-December-2010 11:07 PM
want to build a 391 ci sbc !!!!!! chevyIIheavy Drivetrain & Performance 31 12th-September-2009 07:15 PM
540" re-build/build shawn Drivetrain & Performance 16 30th-December-2008 07:32 PM
You couldn't build it for this! stupesnova Ebay, etc. Discussion 0 21st-February-2008 10:39 PM
