72 nova weight - Chevy Nova Forum
Go Back   Chevy Nova Forum > General > Drag Racing Forum
Old 18th-March-2012, 12:09 AM   #1
72nova620
(OP)
72nova620's Avatar
Nova(s): 8.90 index drag race car
72 nova weight
Anyone have an idea what my nova car will weigh ? it has fiberglass pro front end, fiberglass hood and doors. Steel deck lid, fiberglass rear bumber. lightweight rack and pinion, front dis, glass front and back but lexan in the side. disk brakes , manual brakes no power, backhalfed 4 link with a dana 60 32x16 slicks, weld draglites, 25x 4" front runners on draglites. no back seat, alum floor behind drivers seat over backhalf, 2 poly raing seats. 14 point cage with door sills and x bars, dash bar and xbracing in rear hoop supports. BBC Dart block, alum heads and intake. power glide tranny 9" convertor. ALum radiator and elect fan. factory floor board and firewall, factory dash but mostly gutted. I was thiinking around 3100, needs to be less than 3200. I plan to run 8.90 iindex class.
Old 18th-March-2012, 05:38 AM   #2
lktna
lktna's Avatar
Nova(s): 1971 Nova SS- sold 62 Ch
Really it is one of those things that you will have take your car and have it weighed to get a true number. Just guessing I would say you are around 2900 to 3200 range but again it is a guess.
Old 18th-March-2012, 08:19 AM   #3
Real McCoy
Real McCoy's Avatar
Title: Moderator
Depending on the materials used to build the cage and do the back half, factory disc brakes and control arms or aftermerket and how big the motor is I bet you're going to be pushing 3200 unless you built it to be light. I added 200 lbs to my car going from a stock block 468 to a good 565 motor with a heavier trans case and internals and bigger converter so stuff wouldn't break.
God Bless America, land that I love
2010 PRTA 5.30 Index Champion
Old 18th-March-2012, 09:18 AM   #4
onecarnut
onecarnut's Avatar
Nova(s): 1968 Chevy II
It appears that the heaviest Nova in 72 was 3,199 lbs. You could do a good estimate of how much you have eliminated/added.
However, a truck stop weigh station would be a better option. You can get front/rear/total weights.
From Novaresources.com:
MODEL VEHICLE TYPE SHIPPING WEIGHT CURB WEIGHT
Code Base Engine Description Front Rear Total Front Rear Total
11327 250 L6 2-Door Coupe 1668 1313 2949 1620 1412 3032
11427 307 V8 2-Door Coupe 1748 1335 3083 1732 1434 3166
11369 250 L6 4-Door Sedan 1639 1343 2982 1623 1442 3065
11469 307 V8 4-Door Sedan 1750 1366 3116 1734 1465 3199
Gone but not forgotten
Old 18th-March-2012, 11:19 AM   #5
65 Post
65 Post's Avatar
Nova(s): 65 Post
Are you planning on running the Renegade series at Thompson, Quaker, etc?
Should be a fun class. Dave
"Are you the hunter, or the prey?"
65 Post 11.59 @ 115mph
2002 GORDY 150" RED, 7.91@ 167
Old 21st-March-2012, 11:17 PM   #6
71 Chevy
some input
http://www.yellowbullet.com/forum/sh...d.php?t=427132
Old 24th-March-2012, 10:36 PM   #7
72nova620
(OP)
72nova620's Avatar
asking for opinions
kinda of hard to weigh something thats not together, just trying to figure out how much I will have to slow it down, via restirctor plate to run 8.90 index class. I will have the actual weigth in 2-3 weeks, But im guessing our estimate is within 100-200 lbs. 69 chevy thanks for your input.
Old 25th-March-2012, 10:31 AM   #8
Big Tire Deuce
Big Tire Deuce's Avatar
72, we have a '68 much like yours that ALSO runs in 8.90 index in Canada.
Now specs are. Steel roof and quarters, rest is "all 'glass". OEM glass windshield rest lexan. 2x3 chassis car front to back. A arms up front, alum rad, alum int. plastic buckets, alum firewall/floor, alum dash. short deck BB merlin block alum heads, T400 trans, disc brakes up front, drum rear. 4 link Dana 60.
So as you see were much like yours. Pump gas it DID run 9.10 on motor, and video is a little faster. BUT WE COME IN JUST OVER 3200LBS. Driver is like 270lbs.
Old 31st-March-2012, 08:16 PM   #9
72nova620
(OP)
72nova620's Avatar
Fiberglass gone
I traded all my fiberglass away, will now have steel doors, steel front clip, fiber hood, trunk lid and fornt bumper. I will have the exact weight by Wed evening, so I will post then, Just got my NHRA 8.5 cert today at Summit Racing.
Old 31st-March-2012, 10:42 PM   #10
nawlins-tim
nawlins-tim's Avatar
Title: Nova Newbie
Nova weight
This is some good info. And by the way I , myself , is just a fan and not a Nova owner. The Nova weight is very interesting. Didn't kno they were that light. And if this is correct they are lighgter than I thought. Here goes
The curb weight on a 72 nova will be.
250 L6 engine 2 door 3032 lbs
250 L6 engine 4 door 3065 lbs
307 V8 engine 2 door 3166 lbs
307 V8 engine 4 door 3199 lbs..
Here's a weight list for the options on that year as well.
Front Bucket Seats + 23
External Vinyl Roof + 5
Air Conditioning + 95
Front Power Dics Brakes + 20
Power Brakes + 12
L14 307 Cu.In. V8 Powerglide - 3
TH350 + 28
L22 250 Cu.In. L6 Powerglide - 3
L48 350 Cu.In. V8 4-speed +162
TH350 +168
L65 350 Cu.In. V8 3-speed + 44
TH350 + 72
Power Steering L6 + 40 V8 + 30
E70-14-4 White Side-Wall Tire + 13
Deluxe Wheel Trim Covers + 26
AM Pushbutton Radio + 7
AM/FM Pushbutton Radio + 8
Rally Package + 17
Custom Interior + 27
Custom Exterior + 10
Rally Wheels + 24
Old 1st-April-2012, 03:24 PM   #11
novaracer
novaracer's Avatar
Nova(s): 68 nova SS
My 68 Nova was on the scales last weekend it was 3654 (1894 front) w/210 lb driver.
SB alum. heads
4L80E transmission/12 bolt
F1R Procharger (a/a cooler)
4 wheel disc (12in rotors)
10 pt CM cage
Complete interior with newer power seats (less rear seat)
Stock body/Bumpers (no fiberglass) Stainless steal tank.
Old 8th-April-2012, 08:02 PM   #12
72nova620
(OP)
72nova620's Avatar
72 nova weight results
ok i traded some of my fiberglass away, put all oem glass back in car, front fender and doors back to steel. hood and deck lid hinged fiberglass, front and rear bumpers are glass. factory dash,factory wiring,no radio, no heater core or box but controls in dash, carpet, headliner. 2 poly seats, driver adjustable, 12 pt 8.50 cert. cage, 4 link back halved dana 60, 33x16 slicks w/tubes weld wheels. front mount rack, front wildwood disk. 5 gallon fuel cell full of fuel, magnafuel pro star 500, 10 an braided line all the way up 620 cubi inch tall deck dart block, bmf alum heads, alum intake, 1300 cfm pro systems carb.. alum radiator w elec fan, miezere 55 gpm water pump. ati super dampner, lemon 2 1/2" headers with 5" race mufflers and turn outs and downs. power glide tranny. no driver car weighed 2820. front/ rear ratio 54/46% 240 lb driver fully geared with race gear and helmet race ready total weight 3070.
Thanks guys for your help, I had to make some assumptions along the way on total weight, couldnt wait until total tofind the weight out
Old 16th-December-2012, 03:56 PM   #13
71 Chevy
good information. mine is similar except lexan and ls1 engine. Im hoping I can get it to 2700 without driver. Im going to put it on the truck scales this week to find out
Old 16th-December-2012, 04:02 PM   #14
sbc1320
sbc1320's Avatar
Nova(s): 1972 Nova
Haven't weighed this one, but my last 71 Nova at Houston Raceway was at 3450 lbs. with me in it. I weigh 180 lbs.. Car was a small block with aluminum heads, fiberglass hood, Weld Draglites, full interior w/bench seat, full tank of gas, factory bumper jack and jumper cables.
72 Nova 383
72 Nova 383(11.70s)
71 Nova 406(11.60s)
71 Nova 350
70 Nova 350
Old 19th-June-2013, 11:22 AM   #15
71 Chevy
did you ever get it weighed?
I bet it was way under 3200 lbs
weight of your nova big dog ss 3rd Generation Chevy II/Nova's 1 27th-April-2011 02:24 PM
what is the weight of your nova 72 ss 1st & 2nd Generation Chevy II/Nova's 6 19th-May-2010 03:25 PM
62-65 nova weight ajs Drag Racing Forum 3 11th-May-2007 09:32 AM
Nova weight Daddy'O Drivetrain & Performance 9 10th-April-2007 05:07 PM
