A/C, replace POA with newer system - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Electrical
Old 11th-February-2012, 05:12 PM   #1
mpv72
(OP)
mpv72's Avatar
Nova(s): 1972 SS Clone
I have the remnants of the old POA system in my nova, really only the evaporator and POA valve I have reconditioned and capped of years ago. I prefer to upgrade to get rid of the POA valve in favor of a new system using the small radial or Sanderson type compressor.
I read somewhere to weld/braze the bleed from the POA and hook everything up and all should work? (greatly simplified) I still need to know where to wire what.
I have a complete system from a 79 Chevy truck, I know I'll have to get some hoses made, Is this feasible.
I'm old and tire of a hot summer ride.
Any help appreciated.
Old 11th-February-2012, 06:26 PM   #2
Philip
Philip's Avatar
Title: Moderator
My 72 El Camino was converted using parts from an 89 Camaro. The CCOT evaporators will fit in the stock box and gives a place to install the orifice tube. Not sure what the pipes on the truck evaporator look like, if oriented correctly it will be a bolt in. If not look into buying an evaporator from a 77 - 79 Nova.
When converting the Nova the factory cycling switch was removed and replaced with a multi function cycling switch. The orifice tube replaced with one for 134A. The evaporator and condenser were flushed, the accumulator, hoses and compressor were all new.
Photos of the El Camino and the Nova, both use 134A and work well.
El Camino
Nova
64 Nova 400 series 4 door
SOLD 01/15
Old 17th-February-2012, 12:51 PM   #3
Droptop 63
Nova(s): 1963 Nova, vert alston cl
Garage
Late Model AC
I have to agree this is the way to go. I did a lot of AC work, back when I did have an automotive shop, and this style of GM AC is great because it has a lot of built-in safeguards (low press. switch, high press., CCOT, and others that will prevent a total meltdown of your system. The only minor drawback to this type of system is if you should have the compressor go out, it scatters small metal compressor system pieces and most end up in the Accumulator or the CCOT. Replace both of these, new compressor, flush system, vac system and you are back in business. By the way, if you can avoid it, use a gm compressor. They cool a lot better than the Sanden or similar but both are pretty durable.
Old 17th-February-2012, 10:30 PM   #4
sedandan
sedandan's Avatar
Nova(s): 67 sedan
POA eliminator / update kit
This might help. http://www.nostalgicairparts.com/air...minator-45.php
newer 12 bolt in a 71 my T mouse Drivetrain & Performance 2 19th-January-2012 02:04 PM
Newer AZ guy MaximumBob Member Introductions 4 21st-January-2011 12:27 AM
swapping out the i6 for newer i6 Gatsby Drivetrain & Performance 4 18th-June-2010 11:23 AM
