big block rpm? - Chevy Nova Forum
Old 10th-February-2012, 06:22 PM   #1
Shauns BB70
(OP)
Shauns BB70's Avatar
Nova(s): 1970
big block rpm?
my car has a 1970 396 (402) not sure if its a 4 bolt main or 2. My question is how many rpm can a stock 2 blot main big block handle. The guy who built the engine said the cam should make power to 6500 rpm. I shift at 5300 cause im not sure if the bottom end will handle 6500. I cant remember if he said it was a 4 bolt or two. I know its a cast crank. Also I have a steel crank from a 427. can I make this work in the 396? Thanks guys!
Shaun
Old 10th-February-2012, 06:35 PM   #2
MANGOPUPPY
MANGOPUPPY's Avatar
Nova(s): '72 476 14:1, 8", 4:10 sp
396/427 strokes are the same. I have a "STOCK" 2 bolt block (454) that I have no problem twisting to 7200. There are many more important parts giving the ability to get there. A steel crank is a good idea. You may never need to wind it up to the redline, but the dyno will tell no lies (well, sometimes). That would be a good place to start anyway.
In short, yes it will go there. Many folks get the wrong idea about 4 bolts vs 2 bolts. If I happen to get a deal on one, great. If not, great. Machine work quality is key. What type of cam is it? I'm assuming it is hydraulic.
oh yeah, I'm pretty sure its not a fourbolt. That's not too common..
Old 10th-February-2012, 07:04 PM   #3
koreyss
koreyss's Avatar
for a stock bbc 5,400 rpm would be the max I would go...if you want more ya gonna have to pay more... Crank, rods, push rods, etc... I would be glad to help but together a nice "Rat" !! Depends on your budget! but its soo easy to get power out of a BBC!!!
Old 10th-February-2012, 07:55 PM   #4
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
I twist my 402 2 bolt, cast crank to 7500 rpm!
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 10th-February-2012, 08:00 PM   #5
rhorne12
Nova(s): 1962 Nova
If you have just stock but good condition parts and proper assembly, 6500 should be no problem at all. Valve springs would be my only reservation and if they are correct for the cam, you should be good to go.
I have done many, many BBCs and even 496 with stock two bolt mains have gone 7000+ with never any main or block issues. Not even mild supercharged.
You can't fix stupid but you can fix ignorance
62 Chevy II Turbo 6
66 Corvair Turbo
84 El Camino
Old 10th-February-2012, 08:19 PM   #6
taz3
taz3's Avatar
Title: Moderator
^^X2^^ That's where I spent money knowing the bottom end was solid.
Old 10th-February-2012, 08:32 PM   #7
levisnteeshirt
Nova(s): shopping for the 6th one
a 396, 427 ,,, 7500 used to be the standard rpm for 'em ,,lol ,,, a 2 bolt with a 4 speed i'd kinda worry about ,,, many many old write ups of tests with BBC's with 2 bolts going to 7500
one i remember the most was a stock 396 PHR mag built ,, they went stock everything , then they put a Lunati 268 @ .050 solid cam in it , a scorpion intake and a 850 and made 501 hp ,,, then they put a 125 NO2 kit on it ,, 2 bolt main ,, then they put a tunnel ram and 2 750 DPs on it ,,, winding it to 7500 ,, 538 gear in a Vega with 14 x 32 slicks ,, old school
Old 10th-February-2012, 08:35 PM   #8
koreyss
koreyss's Avatar
I don't know guys 6500 and 7,500 rpms is kind of pushing it with those skinny stock push rods and stock everything...High rpms and sinking hp and tq, the dyno will show...
Old 10th-February-2012, 08:37 PM   #9
Tommy
Tommy's Avatar
Nova(s): 1968
Hey Paul,open your tach up and switch it to 8 cylinder.....
Tommy
Old 10th-February-2012, 08:41 PM   #10
koreyss
koreyss's Avatar
Hope you got a backup motor!! LOL these guys are pushing you!!! if you hear a loud pop!! call a tow truck!! LOL!!
Old 10th-February-2012, 08:47 PM   #11
nukledragger
Nova(s): '68 L78, and others
Wow! Really? Then I bet Grumpy hates that he did all that research and development on steel cranks!!
Old 10th-February-2012, 09:07 PM   #12
taz3
taz3's Avatar
Title: Moderator
Tommy
Come up, and you can reset it while I shift!!
I knew an engine builder up here that was light years ahead of his time, he set an NHRA record in an Pontiac Astro. He used to do all my BB's and man did he know his stuff!
I love the look from passengers, when they see the tach at 7-7500 as I grab the next gear, it's like
Old 10th-February-2012, 09:33 PM   #13
Tommy
Tommy's Avatar
Nova(s): 1968
Come up, and you can reset it while I shift!!:devil
That would be easy if your still trying to shift with that muncie shifter.... I'll fix your tach while your under the car getting the trans back out of gear
Tommy
Old 10th-February-2012, 09:37 PM   #14
Tommy
Tommy's Avatar
Nova(s): 1968
You really need to fix that tach Paul....
Tommy
Old 10th-February-2012, 09:39 PM   #15
taz3
taz3's Avatar
Title: Moderator
Tommy
The secret is I'm not racing when I'm shifting that high, so it don't have to power shift it. 2 ways to break a Muncie, hard launches and 7000+ rpm power shifts.
Tommy
Nope, go big or go home!!
ChevyII, old-style block, to modern block Front Sump oil pump pickup modifications jjj5757 Best of the 1st & 2nd Generation 11 18th-January-2015 12:37 PM
69 NOVA small block to big block conversion Hydrochild Drivetrain & Performance 5 17th-August-2011 03:28 PM
small block nova with big block coil springs nova805 Steering, Suspension, and Chassis 1 30th-January-2009 12:29 AM
Switching from a small block to a big block heater core? slickman Drivetrain & Performance 19 19th-October-2007 07:59 PM
