Best street and strip gear for a 1969 big block - Chevy Nova Forum
Old 9th-February-2012, 11:13 PM   #1
jeep2001
(OP)
Title: Nova Newbie
Nova(s): 1969 nova
I have a 1969 Nova with a 454 that is bored 60 over. I have a 280 magnum cam, 1970 open chamber heads, C 396 maniford, Holley 650 and a turbo 400 with a 2500 stall. The gear ratio is a 472 and I would like to install something a lot smaller. How small can I go with out hurting performace? The car is driven mostly on the street but I plan on going to the track a few times this year. The motor seems to stop pulling about 5200 RPMS so I think the 472 gear is too big for the 1/4 mile run. Any suggestions will be great?
Thanks Mike
Old 9th-February-2012, 11:17 PM   #2
novajoe1973
novajoe1973's Avatar
Nova(s): 73 nova 383 th350 3.73
Garage
From what I understand, big blocks don't require a lot of gear to get off the line quickly like a small block would. I would say 3.42-3.73 gear would be fine for your application.
383 solid roller/th350/3.73
10.85 @ 122mph on pump gas through the mufflers
Old 9th-February-2012, 11:44 PM   #3
batman09
batman09's Avatar
Nova(s): 1967 LS3 & 1962 LSX wagon
Garage
3.73 is the way to go!!
1962 Nova wagon-----Lsx/4L60e
1967 Nova---LS3/4L70e
Old 10th-February-2012, 12:45 AM   #4
JBimmolate
JBimmolate's Avatar
Title: Moderator
Nova(s): To be determined...
Depends on tire diameter in most cases 3:42-3.73 are the most common. Like said above.
Miles
Sent from my Autoguide iPhone app
" The Resident Differential Guy, Have A Question? Just Ask! "
11/2016 FastEddie, he will be missed
Old 10th-February-2012, 01:42 AM   #5
jeep2001
(OP)
Title: Nova Newbie
Nova(s): 1969 nova
I have 255x60-15 street tires and also have 28x10.50-15 slicks.
Old 10th-February-2012, 08:30 AM   #6
ccvair
ccvair's Avatar
Nova(s): 1970 ss 396 1974 ss 350 1
Garage
If your combo is all done at 5200 your most likely to hit max rpm before the end of the 1/4 with 3.73 gears. That being said from what you describe of your combo the 650 carb is way to small. You should be running a 750 minimum maybe as big as a 850.That small carb might be whats holding you back. Id try a bigger carb even if you have to borrow one and see if it falls off still. If it picks up a couple hundred rpm you should be ok with a 3.73 gear. When it falls off does it just nose over or does it go into valve float? That cam should see 6k easy without falling off real badly.
Old 10th-February-2012, 08:53 AM   #7
photoman
photoman's Avatar
Do you have a 12 bolt rear axle? If so, the 3.55 might be a nice choice. The back tires are on the tall side so you might be happy with 3.73. Just depends on how much highway driving you do.
1969 Nova
350
TH400
8.5" 10 Bolt
Old 10th-February-2012, 02:17 PM   #8
jeep2001
(OP)
Title: Nova Newbie
Nova(s): 1969 nova
The motor pulls good to 5200 RMP after that it pulls a lot slower. It will pull to about 5500 or 5600 before it stop pulling. I have a Ford 9'' in the car. With 373 gears what RPMs should I have to get down the 1/4 mile? Will rejetting the 650 carb help or is it just too small?
Thanks Mike
Old 10th-February-2012, 02:27 PM   #9
69LT1Nova
69LT1Nova's Avatar
Nova(s): 1969 Nova, grandma fresh.
That is one steep gear for a big block! Even saying that, I'd first get a bigger carburetor, 650 is too small. Even with re-jetting you won't get the flow (CFM) you need to supply the air needed to support upper RPMs. Your combo needs air.
3.42 gear after the carb.
Build:
LT1 baby!
Old 10th-February-2012, 02:28 PM   #10
novajoe1973
Garage
It depends. What is your 1/4 mile speed right now with 28" tires?
Old 10th-February-2012, 03:36 PM   #11
ccvair
ccvair's Avatar
Garage
swap the carb first 3.73 should be close to 5800 in the traps.
Old 10th-February-2012, 03:41 PM   #12
Clean 65
Clean 65's Avatar
Nova(s): 1965 SS
Garage
This calculator might give you an idea:
http://www.kabamus.com/garage/gears.html
"Objects in mirror are losing!"
Old 10th-February-2012, 03:48 PM   #13
taz3
taz3's Avatar
Title: Moderator
Nova(s): 2 69 SS BB L78's & 69 4dr
I just changed my rear gear this year to a 373, and it's perfect for my 69 BB, it can reasonably drive an hour or 2 and still goes like a bat outta hell!!!
The fuel milage is still within reason too! My car is fairly mild with about 430-450hp .030 over 402 on pump gas.
3 69's, 2 L78's, 51 Fathom & 71 Lemans #'s match both w/4spds & 69, 53 glacier blue 4 door
Old 10th-February-2012, 03:52 PM   #14
jeep2001
(OP)
Title: Nova Newbie
Nova(s): 1969 nova
I can get a Holley 750 vacuum secondary to try, if thats helps would I be better with a double pumper than the vacuum secondary carb with both carbs being the same cfm size?
Thanks Mike
Old 10th-February-2012, 04:02 PM   #15
ccvair
ccvair's Avatar
Garage
That 750 vac secondary should be just fine just make sure the jetting is close.
395 ci strip /street levisnteeshirt Drivetrain & Performance 195 7th-April-2013 09:25 PM
65 2d street/strip my66post Ebay, etc. Discussion 1 17th-May-2011 12:12 AM
415 SBC street/strip, Help with gear ratio? marks1972 Drivetrain & Performance 16 2nd-September-2010 09:12 PM
Street/strip 75 Junkyard Dog 75 Drag Racing Forum 16 22nd-November-2009 03:15 PM
