Ls376/525 - Chevy Nova Forum
Go Back   Chevy Nova Forum > Body, Chassis and Mechanical > Drivetrain & Performance > LSx Forum
Old 31st-January-2012, 06:17 PM   #1
novanutcase
(OP)
novanutcase's Avatar
Title: Moderator
Ls376/525
Anyone have any experience with this engine in stock form? How streetable is it? The dyno chart is pretty impressive and it looks like it will work perfectly for what I want to achieve.
I'm also thinking for a grand less it might be better to go with the 480 hp model.
John
Build Pics(No Comments)
Old 31st-January-2012, 08:40 PM   #2
Novaman Oscar
Novaman Oscar's Avatar
Nova(s): 72
you talking about these two bro??
LS376/480 HP
http://www.crateenginedepot.com/stor...9-P2218C2.aspx
LS376/525HP
http://www.crateenginedepot.com/stor...3-P9949C2.aspx
Finishing the nova for you dad
Old 31st-January-2012, 09:44 PM   #3
Pragmatist
Pragmatist's Avatar
Garage
Below five grand (RPM) there's not much difference besides the one grand out of pocket. If they were from any other supplier I would be skeptical but I don't think you can go wrong either way.
66 & 67 hard top,
My 1980 avatar pic.
Old 31st-January-2012, 11:16 PM   #4
photoman
photoman's Avatar
Man that is some impressive stuff. Zora would be proud!
1.4 HP per cubic inch and comes with a 50,000 mile warranty. That's insane! Man I wish I had some money to burn...
1969 Nova
350
TH400
8.5" 10 Bolt
Old 1st-February-2012, 01:39 AM   #5
novanutcase
(OP)
Title: Moderator
Originally Posted by Novaman Oscar View Post
Originally Posted by Pragmatist View Post
Below five grand there's not much difference besides the one grand out of pocket. If they were from any other supplier I would be skeptical but I don't think you can go wrong either way.
Yup! I'm thinkin' the 480 will work out on the open course and when I'm killin' cones! I can spend the grand that I save on a trick drive system like the one from Eddy Motorsport.
John
Old 1st-February-2012, 01:46 AM   #6
Novaman Oscar
Nova(s): 72
ether one will be a hell of a blast!! but true you gotta save where ya can and use it else where
Old 1st-February-2012, 09:25 AM   #7
Shane65
Shane65's Avatar
Title: Moderator
Nova(s): 63 & 65 wagon 64 hardtop
John
I think $1000 will be going to tires too!
64 hardtop, 63 wagon
Old 1st-February-2012, 09:25 AM   #8
wcraig
wcraig's Avatar
Nova(s): 1966
Here is my first start-up of LS376/515 that we did during the thanksgiving weekend. It's a healthy motor
Old 1st-February-2012, 09:42 AM   #9
novanutcase
(OP)
Title: Moderator
Very Nice!!!!
I was a little sad when I sold my LS7 but this is exactly what I was waiting for!
How is she running so far? I noticed you have the circle track version. Is it any different than the 480 or 525 as far as power band?
John
Old 1st-February-2012, 12:38 PM   #10
wcraig
wcraig's Avatar
Nova(s): 1966
It is my understanding that the 515 and the 525 use the same ASA cam. The 480 has a different cam I believe. I am using a 1050 cfm holley three barrel carb with modified boosters to provide the correct carb signaling. You can see the modified venturi boosters in the below photo. The original ones are to large to give the carb correct velocity/signalling.
Old 1st-February-2012, 12:49 PM   #11
wcraig
wcraig's Avatar
Nova(s): 1966
LS376/515 TECH SPECS:
Part Number: 19244552
Engine Type: LS Series Gen IV small-block V8
Displacement (cu in): 376 cu in (6.2L)
Bore x Stroke (in): 4.06 x 3.62 (103.25 x 92mm)
Block (P/N 12584727): Cast aluminum with 6-bolt, cross-bolted main caps
Crankshaft (P/N 12597569): Nodular iron
Connecting Rods (P/N 12617570): Powdered metal
Pistons (P/N 19165089): Hypereutectic aluminum
Camshaft Type (P/N 12480110): Hydraulic roller
Valve Lift (in): .525" intake / .525" exhaust
Camshaft Duration (@.050 in): 226 intake / 236 exhaust
Cylinder Heads (P/N 12598594): LS3 rectangle port, as cast with 68cc chambers
Valve Size (in): 2.16 int / 1.59 exhaust
Compression Ratio: 10.7:1
Rocker Arms (P/N 12569167 int): Investment cast, roller trunnion
Rocker Arms (P/N 10214664 exh): Investment cast, roller trunnion
Rocker Arm Ratio: 1.7:1
Recommended Fuel: 92 octane
Maximum Recommended rpm: 6600
Reluctor Wheel: 58X
Balanced: Internal
LS376/525 TECH SPECS:
Part Number: 19259233
Engine Type: LS-Series G en I V Small-Block V-8
Bore x Stroke (in): 4.065 x 3.622 (103.25 x 92mm)
Block (P/N12623967): Cast aluminum with 6-bolt,
Connecting Rods (P/N 12607475): Powdered metal
Pistons (P/N 19207287): Hypereutectic aluminum
Camshaft Type (P/N 88958770): Hydraulic roller
Valve Lift (in): 0.525" intake / 0.525" exhaust
Camshaft Duration (@0.050 in): 226 intake / 236 exhaust
Cylinder Heads (P/N 12629063): Aluminum L92-style port; as cast
with 68cc chambers
Valve Size (in): 2.165 intake / 1.590 exhaust
Compression ratio: 10.7:1
Rocker Arms (P/N 12569167 int): Investment cast, roll trunnion
Rocker Arms (P/N 10214664 exh): Investment cast, roll trunnion
Maximum Recommended RPM: 6,600
Reluctor Wheel: 58X
Balanced: Internal
LS376/480 TECH SPECS
Part Number: 19213229
Engine Type: LS Series Gen IV Small-Block V-8
Block (P/N 12584727): Cast-aluminum with 6-bolt,
Pistons (P/N 19168089): Hypereutectic aluminum
Camshaft Type (P/N 88958733): Hydraulic roller
Camshaft Duration (@.050 in): 219 intake / 228 exhaust
Cylinder Heads (P/N 12615879): Aluminum L92 style port;
Valve Size (in): 2.165 int / 1.59 exhaust
Rocker Arms (P/N 12569167 int): Investment-cast, roller trunnion
Rocker Arms (P/N 10214664 exh): Investment-cast, roller trunnion
Reluctor Wheel: 58X
Balanced: Internal
Old 2nd-February-2012, 12:00 AM   #12
hookemdevils22
hookemdevils22's Avatar
Nova(s): '71 LSx/T56
$7500 is a lot to pay for no accessories or harness/ecu. Find a 6.0L with accessories and harness for $2,500, put some L92 heads ($600) and LS3 intake ($250) on it, and toss in a decent cam ($500), and you'll hit 500 hp easy. Hell, you can find an LY6 (6.0 VVT motor w/ L92s) for pretty cheap, and then you just need a cam and intake. Here's an example -- LY6, LS3 intake/injectors, Vengeance Stage II LS3 cam (227/239 .614/.624 115+3), stock lifters, valves, rocker arms. He put down 400 lb-ft and 414 hp through a 4L80e (an absolute power hog). That's a conservative 500 hp and 480 lb-ft at the crank.
Old 2nd-February-2012, 12:38 AM   #13
dealer-deuce
dealer-deuce's Avatar
Nova(s): A FAKE 63 NOVA
6.2 litre
I have the LQ9 6.2 in my 2010 silverado 1500 ltz 400 horse version I cannot
fathom what these engines will do in a early nova I have to keep the traction
control on all the time or I will get into trouble I have the 6 speed automatic
also. these engines are so smooth!! 3:42 rear gear ratio you can really suprise
people out of the hole!! revs quick and pull really hard and this in a pickup.
I have 63 nova with l-79 327 motor wicked built scary fast!! I cannot imagine
that 6.2 litre under the hood hope you have really good seatbelts and big budget
for rear tires!!
Old 2nd-February-2012, 09:28 AM   #14
wcraig
wcraig's Avatar
Nova(s): 1966
Yep, My 66 should rock with the LS376/515 hp engine. Look at that torque curve.
Old 2nd-February-2012, 11:21 PM   #15
novanutcase
(OP)
Title: Moderator
Hmmm...not a bad idea.....I already have a set of L92 heads,LS7 dry sump pan and an intake. All I would need to do is take the timing chain cover off and replace the LS3 oil pump with the LS7 one along with using the dry sump pan rather than the LS one. That and replace the stock heads with the L92's I have. The only thing I would need to buy would be a cam then.....
John
LS3 vs LS376 with hot cam 1floho LSx Forum 6 22nd-June-2011 08:52 AM
