Starting my winter project, front disc brake install - Chevy Nova Forum
Old 23rd-January-2012, 09:27 PM   #1
65Coupe
65Coupe's Avatar
Nova(s): Gone, but not forgotten.
Thumbs up Starting my winter project, front disc brake install
Hey guys, after quite a bit of research the past few months I'm ready to start the front disc brake conversion on the Nova. I'm going with the CPP 6467WBK-S kit, Right Stuff complete front/rear brake lines and manual master cylinder/prop valve. I'm also installing a Hellwig front sway bar while I've got the car layed up for a bit. All parts are on order, so I should be in business in a week or so.
The Right Stuff Detailing master cylinder/prop valve has the connections facing the passenger side, and the brake lines are evidently designed to match right up. Time will tell, and I'm hoping everything goes together smooth. One thing going from a single pot mc to the new dual pot, I wanted to going ahead and replace all the lines on car.
I'll keep you guys updated through the project. Wish me luck!
Old 24th-January-2012, 02:07 PM   #2
elpibedc
elpibedc's Avatar
Title: Nova Newbie
Good luck. Make sure to post some photos and tips for the install. Thanks!
Old 24th-January-2012, 02:21 PM   #3
the FLYER
the FLYER's Avatar
Nova(s): a B Pillar of Society
being the conversion you're doing will require bleeding the brakes, why not upgrade/replace the rear brake hose too?
i'm sure if it hasn't been addressed it is showing signs of degradation.
good luck on your upgrades...
the Flyer Special
'64 411 377-Tko600-3:73's
Old 24th-January-2012, 03:46 PM   #4
65Coupe
65Coupe's Avatar
D'oh, forgot to mention that I'm rebuilding the rear drum brakes as well. Nothing special, just a stock rebuilt with new drums, cylinders, shoes and hoses.
Old 24th-January-2012, 03:54 PM   #5
the FLYER
the FLYER's Avatar
good job, i'd hate to see you inoperable because of an existing worn part.
good thing to do complete system and not halfway.
the Flyer Special
Old 24th-January-2012, 03:54 PM   #6
klean63
klean63's Avatar
Nova(s): 1963 SS-Sold
I just put these same parts on my car this past weekend, they matched up great. Just be patient fishing the lines in if the engine is in the car, mines out so it was a piece of cake.
Old 24th-January-2012, 04:47 PM   #7
65Coupe
65Coupe's Avatar
Thanks for the info! The brake lines were the one thing I was a bit nervous about. I contemplated bending/flaring my own lines, but in the end decided to just replace all the lines with their kit.
Are you running manual or power brakes?
Old 24th-January-2012, 11:25 PM   #8
asteeler4life
asteeler4life's Avatar
Nova(s): 1962 'VERT 1966 SS
YOU GOT PICS OF THE RIGHT STUFF LINES IN THE CAR OR LOOSE? PT#'s
62
INLINE 6 GROUP
66 NOVA SS COUPE INC.
Old 25th-January-2012, 09:15 AM   #9
65Coupe
65Coupe's Avatar
The parts haven't arrived yet, but I'll snap some pics when they do. Maybe someone else can chime in here with pics.
Old 25th-January-2012, 08:48 PM   #10
65Coupe
65Coupe's Avatar
Well the brake line kit and mc/pv setup came from Right Stuff today, and I'm skeptical at best. Right off the bat no instructions or diagrams. That's pretty cool, maybe they're catering to those of us who like a challenge possibly.
Anyway, the "8 piece" front brake line kit only contained "5 pieces" - unless they're counting the rubber boot covers as "pieces" (yes I'm incredibly sarcastic). Looks like its missing at least the line from the wheel well junction to rubber hose piece. I've looked at the front kit 6 ways to Sunday, and I don't see how this is going to fit but what do I know. Also not included are the lines that run from the mc to the pv, thought that would be a given to include.
So I'm going to call these guys tomorrow and figure out what's going on, maybe even ask for (dare I say) some diagrams or instructions. I know, I know I'm one of those "hard to please" customers.
Wish me luck.
Old 25th-January-2012, 08:53 PM   #11
the FLYER
the FLYER's Avatar
you may need to adjust the length of the pedal actuating rod on the booster unit so the rod & clevis are the proper length for your car...
don't be upset by this modification, it's somewhat of a universal part and sometimes these things are needed to properly fit the part "to your car"
the Flyer Special
Old 25th-January-2012, 09:01 PM   #12
65Coupe
65Coupe's Avatar
I'm not sure if I mentioned this before, but I'm staying manual. No booster needed here, just master cylinder/prop valve.
Think it was asked what part# I ordered, here they are:
XKT6268 "8 Piece" Front Brake Line, Std Disc Conv 62-68 Nova
XIN6266 2 Piece Front to Rear Brake Line, Std Disc Conv 62-67 Nova
XRA6202 2 Piece Rear Axle Brake Lines, 62-65 All Cars
DBMC18 Master Cylinder 1" Bore
PVK71B Prop Valve Kit for Bottom Mount
Old 25th-January-2012, 09:02 PM   #13
the FLYER
the FLYER's Avatar
ahhhh... ok
the Flyer Special
Old 26th-January-2012, 10:40 AM   #14
65Coupe
65Coupe's Avatar
Anyone have a diagram of the factory brake line routing of a 64/65? From what I understand, 64 and 65 were the same routing up around the cross member. I'm trying to explain to Right Stuff my setup (which is factory stock) so they can let me know which lines go where.
Old 26th-January-2012, 10:57 AM   #15
bugguy357
bugguy357's Avatar
Nova(s): 65 Nova SS
Easy to do! I did this to my 65 last year and its to bad you bought everything my CPP kit will be for sale in a couple of weeks. The only difference is I used there CP31500-C master with built in valve.
Tires rubbing after Disc Brake Install RichP Steering, Suspension, and Chassis 54 8th-December-2011 06:09 PM
Finished rear disc install + a front end shot The Tubduck 1st & 2nd Generation Chevy II/Nova's 7 22nd-March-2011 01:07 AM
CPP 4 Wheel Disc Brake Install With Pictures batman09 Steering, Suspension, and Chassis 34 6th-February-2010 07:55 PM
Help with Disc Brake cap install Motoboy Steering, Suspension, and Chassis 2 13th-June-2009 01:29 AM
Rear disc brake install, need help my72nova Steering, Suspension, and Chassis 1 17th-August-2008 08:56 PM
